Tom Henry Racing
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 10-04-2009, 05:56 PM   #1
ryeguycamaro
ryeguycamaro's Avatar
Drives: 1969 RS/SS 2010 SS/RS
exhaust question
Does anyone know if the black plate below the factory exhaust is necessary? I just put Borla cat back exhaust on and drove it and after awhile it must have started to sag a bit and it rubs vibrates on that plate. I was wondering if I need it and if it serves a function or if I can just take it off. I know I can readjust the exhaust also but just wondering about this. I have a hoist in my shop so it really isn't a big deal.
ryeguycamaro is offline   Reply With Quote
Old 10-04-2009, 09:15 PM   #2
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
if its rubbing the exhaust is not mounted correctly
firestone_ss is offline   Reply With Quote
Old 10-05-2009, 07:21 AM   #3
ryeguycamaro
I adjusted it and it is fine now but I am still wondering about the black plate under the car. Is it necessary or can it be removed?
Old 10-05-2009, 12:34 PM   #4
rolnslo
Farewell 2010 1LT/RS...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Not sure how "necessary" it is but GM doesn't spend money making parts for a new model when there isn't a purpose for it...It's there for a reason and it's not just to keep your exhaust pipes from falling on the ground.
Just an FYI, there is already a company making an upgraded version of that part: http://www.camaro5.com/forums/showthread.php?t=45046
#1: 2010 1LT/RS Victory Red M6 - July 2009-Oct 2011 (SOLD). #2: 2011 2SS/RS Synergy Green A6 - Oct 2011.....
rolnslo is offline   Reply With Quote
Old 10-05-2009, 01:52 PM   #5
Brian2SS/RS
Giggity
Brian2SS/RS's Avatar
Drives: 2009 Malibu 1LT
So how does it sound? I've ordered the same exhaust so that when my car gets here i will be ready.
Brian2SS/RS is offline   Reply With Quote
Old 10-06-2009, 12:30 AM   #6
Badbee
Drives: 04 Z06
Congrats, do you have a sound clip & is there any DRONE??
Thx.
Badbee is offline   Reply With Quote
Old 10-06-2009, 08:24 AM   #7
ryeguycamaro
Sounds great. no drone at all up to 75, but with the cruise on and in sixth gear when it starts to go up a hill it has a little drone. Not that bad at all. It is what I was looking for in sound and it is simple to put on. I had everything mounted free of touching anything and drove it 30 miles and it must have shifted a bit, just put it on the hoist and readjusted and retightened everything up, it is just fine now. My only complaint is I bought the Borla aggressive exhaust kit for the Camaro with ground fx and it has no tips on it at all. I will put something on it. The pipes look a little small in the diffuser. Even on the stock diffuser as I just put my gfx on last night.
Old 10-06-2009, 08:38 AM   #8
97one
97one's Avatar
Drives: 1LT RS w/polished 19"rims
Why would you want to remove it ?..................
It's there to help keep the under side more rigid, helps tie the right to the left.
97one is offline   Reply With Quote
Old 10-06-2009, 08:51 AM   #9
ryeguycamaro
I was thinking about removing it because it is so cheap. I was thinking of fabricating my own but I see BMR already has it. I was only going to have it off for a short time untill I made one. Just didn't know the importance of having the piece off for a short time. I know it ties the car together, right to left and stiffens it up but why isn't it more rigid? I think it would be way better with BMR's design.
Old 10-06-2009, 09:28 AM   #10
firestone_ss
personally i love the one that came with my MBRP exhaust has a big bow tie cut-out
Old 05-22-2010, 12:10 PM   #11
camaroLT1
camarobobby
Drives: LT1 imperial blue
Is it possible to have different mufflers welded on? The last person I talked to said there isn't enough room. What's the best thing to do to give my V6 a little more rumble without decreasing gas mileage or voiding the warrenty?
camaroLT1 is offline   Reply With Quote
DIY Noweeds exhaust diverter installation CanadianCamaro Camaro DIY & HOW-TO instructions & discussions 12 05-11-2013 03:17 PM
RATING HEADERS??? SAUCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 12-02-2011 08:21 PM
Question about potential exhaust setup. Xanthos Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 22 07-29-2011 10:59 AM
Exhaust question ElManny Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 01-02-2009 09:41 PM
2SS exhaust, 2 part question. HELP!! 2SS is mine!! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 11-16-2008 06:51 PM
