SDTW Custom Wheels & Tires
Old 10-05-2009, 12:34 PM   #1
DFollis
DFollis's Avatar
Drives: 2010 Black 2SS
What Oil.... Help!
Ok check it out i have read/heard so many different things about what oil to use for after the break in period... To my Understanding it comes from the factory with Mobil1 Synthetic 5-30????
Ok so then i hear that the synthetic is too slippery to get a good seat on the rings.... Then why did it come from the factory this way? Car has about 800 miles on it and im kinda getting nervous as i broke the car in pretty hard trying to seat the rings. Should i change the oil now, and if so what oil do i go with a good convetnional or stay with a Synthetic.
Any input is much appreciated!!!
Black 2SS M6 "Thing is Awesome"
D.L.F.
DFollis is offline   Reply With Quote
Old 10-05-2009, 12:49 PM   #2
anthonybyram
anthonybyram's Avatar
Drives: 1972 Z28, torch red,454
You worry too much.... put Mobil 1 back in it! Jezzzz. Is this your first car?
anthonybyram is offline   Reply With Quote
Old 10-05-2009, 01:42 PM   #3
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
You're absolutely right, there is tons of speculation on what oil is best. The best advice is to read the owner's manual and stick with what it says. Just take note that the owners manual specifically states to use an oil certified to the "GM4718M" standard (different standard for the V-6). In fact, the manual even says that if you sustain engine damage and did not use a GM4718M certified oil, that it "could" void the engine warranty. In my search for engine oil, I noticed that the Royal Purple stuff did not say anything about this GM4718M on the bottle, so I'm not using it. However, the AMSOIL High-Performance stuff did list the GM4718M, but at $9.00 a quart it's too expensive for me! As the previous poster says, just stick with the regular Mobil 1 Synthetic (not the extended performance stuff). That's your safest bet.
blazzin1 is offline   Reply With Quote
Old 10-05-2009, 01:45 PM   #4
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
I changed my oil at 890 miles after hard driving and alot of metal was found in the filter and drained oil. This is normal on hard break in.
Some people take out the new oil and replace it with dyno or Royal Purple for break in. And some continue dyno up until they are happy.
I have changed my oil at 890 and 2900 and have 6005 on odo.
You will be just fine changing now and again when you feel comfortable as in using the OLI. But if important, check out Blackstone labs and send them a sample of the oil you drain and be directed by their recommendations.
There is alot of loose metal and sealants (and hard break in) during the first oil change. Thats why I changed it at 890 miles and again at 2900.
I personally use Pennzoil Platinum and Mobil1 filters. I have had great luck with the oil analysis in all my LSX engines (3) OVER 200K
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 10-05-2009, 01:57 PM   #5
Wild Bill
Wild Bill's Avatar
Drives: Camaro 2015 RS CRM
I use the same.
IOM 2SS/RS manual
1100 - 4/7/09
3000 - 5/27/09
6000 - 7/17/09
See my Thread in New York Metro Area.
http://www.camaro5.com/forums/showthread.php?t=33878
Wild Bill is offline   Reply With Quote
Old 10-05-2009, 04:18 PM   #6
Hector LS3
Hector LS3's Avatar
Drives: SS1/RS M6
my brother just blew up his '07 Z06 20k miles on it.....and he kept running 5-30.
ima go with 10-30
Wheatley Tuned LS3
Hector LS3 is offline   Reply With Quote
Old 10-05-2009, 05:57 PM   #7
Banshee
Banshee's Avatar
ima go with 10-30
And the reason for the engine failure was the oil viscosity of 5w30?
I highly doubt that.
With the tight tolerances of the LS engines, 10w is thicker and would do more damage to the engine (in theory) if in fact the oil viscosity was the issue.
I am not going to belabor anyone with a full blown response about the differences between the two weights. If your brother lived in Las Vegas and in summer (100-120 degrees), 10w may be a more suitable choice. Any other place, 5w is the weight of choice unless you have a high mileage engine over 100k.
5w protects the engine better on cold start up because of it's flow and viscosity. If in a sub zero climate, 0w30 or 0w20. In extreme hot climates, 10w30.
Old 10-05-2009, 08:18 PM   #8
camaroincarolina
camaroincarolina's Avatar
Drives: 1SS Aqua Blue Metallic
I am running Amsoil. I hear it is great! My dad swears by it in all his cars.....
camaroincarolina is offline   Reply With Quote
Old 10-05-2009, 11:23 PM   #9
duder4thgen
Drives: Bird
ima go with 10-30
I'm running 0-30... guess I should dive for cover next time I crank her up.
duder4thgen is offline   Reply With Quote
Old 10-05-2009, 11:37 PM   #10
Hector LS3
Hector LS3's Avatar
Drives: SS1/RS M6
#6 piston shredded to pieces....good thing is under warranty! i think 5w30 turns into water when u drive hard
Wheatley Tuned LS3
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
