BORLA
View Poll Results: DOHC/OHC vs. OHV
DOHC/OHC 14 26.92%
OHV 38 73.08%
Voters: 52. You may not vote on this poll
Old 06-14-2008, 10:42 AM   #1
smokn'
Drives: Banana boat
DOHC/OHC vs. OHV
which one would you like 4 the camaro v8(or maybe it's future gen V)? 4 me, the DOHC/OHC.
smokn' is offline   Reply With Quote
Old 06-14-2008, 11:21 AM   #2
MerF
Go Rays!
MerF's Avatar
Drives: 03 Trailblazer
"For".
Thanks.
MerF is offline   Reply With Quote
Old 06-14-2008, 01:00 PM   #3
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I don't care which config it has. I really don't. GM's proven time and again that you don't need OHC/DOHC to have a world-class engine...
So as long as it does it's job well, I couldn't give a rat's behind what configuration they use.
Mr. Wyndham is online now   Reply With Quote
Old 06-14-2008, 01:35 PM   #4
wildpaws
wildpaws's Avatar
Drives: 1999 Blazer
Ditto, performance is far more important to me than configuration!!
Clyde
wildpaws is offline   Reply With Quote
Old 06-15-2008, 05:28 PM   #5
Jinx
Owner of Shunt
Jinx's Avatar
Drives: 2001 Mustang GT vert
After working with current Mustangs, I dont want a Camaro to get a OHC/DOHC. Ive had enough of it. Its more expensive and time consuming to do mods. Not to mention aftermarket is slower. Thats the main attraction I have with LS engines, besides the superior power numbers.
Most old school wrench jockeys can do a cam swap on a LS anywhere, but with SOHC or DOHC most of them guys dont even want to help even with a case of beer. With Mustangs the only option you have is third party port work or hope Ford comes out with a better design soon. With LS engines or most OHV engines; you have a hand full of aftermarket companies producing head.
OHC is great if the car is going to stay stock or get nothing more than bolt-ons and supercharger. But I miss having a car that can be brand new and still be tinkered on and even your friend have fun helping. Maybe I am biased and have been scarred by Mustangs.
Support the "JINX CAMARO FUND" at http://www.zazzle.com/jinxdesign
Jinx is offline   Reply With Quote
Old 06-15-2008, 09:54 PM   #6
ihc95
ihc95's Avatar
Drives: BMW 335i E92
doesn't OHV engines usually have more torque than DOHC/OHC engines? OHV engines are also cheaper to make, so OHV.
ihc95 is offline   Reply With Quote
Old 06-15-2008, 10:19 PM   #7
z28collection
waiting for 5th gen
z28collection's Avatar
Drives: 99 z28 6 speed, 81 z28 auto
OHV
give me a pushrod motor anyday much easier and cheaper to work on.
speed kills-drive a ford and live forever
http://www.myspace.com/ashleyjfowlkes
z28collection is offline   Reply With Quote
Old 06-15-2008, 11:02 PM   #8
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
yes, but thats because its easier to make more rpms with (d)ohc than ohv. so they tend to use that.
still, i'd rather have ohv, they are smaller, simplier and lighter
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
DGthe3 is online now   Reply With Quote
Old 06-15-2008, 11:05 PM   #9
The_Beast_
THE GoldMember
The_Beast_'s Avatar
Drives: '92 Pathfinder A.K.A The BEAST
I'll say OHC cause theyre genrally lighter and can produce higher engine speeds than that of OHV 's can. Not to mention better engine performance and even better design flexiblity.
So the Goldmember has spoken, So shall it be done.
_________________________________________________
AUGUST 2009 AURORA HITSS THE SSTREETSS!!!!!
~MY SSCHEME: BLACK W/GOLD BUMPER 2 BUMPER Z-28 SSTRIPESS.~
^In the wise words of Pink, "NO NOT MUSTANG GOLD"
Forget a automatic, a MUSCLE car needs STICK! To bad I'm getting auto
Originally Posted by The Lonely Island
IM RIDIN ON A DOLPHIN DOIN FLIPS N' SHIT!!!!
May The Beast Rest In Peace. For Now.
The_Beast_ is offline   Reply With Quote
Old 06-15-2008, 11:18 PM   #10
Mr. Wyndham
They are, and can? I've always been under the impression that it's the other way around.
OHV's are lighter due to only having one Cam, etc.
And OHC's can rev higher due to the reduction in valve-float, etc.
Old 06-15-2008, 11:30 PM   #11
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Doesn't matter to me, personally. Then again, I'll be getting the V6 (not the V8) and the only modding I'll be doing will be a custom exhaust system.
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 06-15-2008, 11:30 PM   #12
Jinx
Owner of Shunt
Jinx's Avatar
You are correct. OHV are lighter due to less material overall. Just to get an idea I wish everyone would get the chance to see an LS# vehicle next to a Cobra with both hoods popped. That 4.6L DOHC will make an LS1 look tiny even though the LS1 would have over an liter of displacement over the cobra. OHV are simple and Gm uses it to there advantage. I hate hearing the arguement about the OHV being outdated. Its BS. The OHC design dates back about just as far. If GM can produce an engine with larger displacement, manage high 20s in gas mileage, and make mind bending power and potential; then I say dont **** with it.
Old 06-15-2008, 11:47 PM   #13
The_Beast_
THE GoldMember
The_Beast_'s Avatar
dont know last time i check OHC have better engine speeds.
Old 06-16-2008, 02:40 AM   #14
Jinx
Owner of Shunt
Jinx's Avatar
Each one has there pros and cons. Packaging is going to be an issue with a DOHC with larger displacement. So a small displacement with DOHC will prolly be chosen to do the same as an larger displacement with OHV. I think the engine bay is about the same size as the last gen camaro, so try to imagine a 6.2 with DOHC,.....it would be ****ing huge.
Plus, the ability for high engine speeds is great if if you need to spin the hell out of it to get the needed power. Thats not needed when you got an engine that makes its power in low and mid range and the displacement to spare do it in.
Perfect example of high revving to get bigger numbers from DOHC:
Lexus IS-F: 415hp @ 6600; 371tq @ 5200 (5.0L DOHC with DI)
BMW M3: 414hp @ 8300; 295tq @ 3900 (4.0L DOHC with DI)
Ferrari F430: 483 hp @ 8500; 343tq @ 5250 (4.3 DOHC)
These are all wonderful engines, but I like an affordable car too. If high revving is what you want, its going to take more than just heads. Its going to take an bottom end that handle the speeds to take advantage of that feature.
As for me I like low and mid range power from GM's current OHV offerings and at a price I cant argue with. Even if GM manage to squeeze a 6.2 DOHC into the engine bay and make 500+ hp; I dont think anyone in this decade or the next half decade will drive away with a under 40k Camaro.
Saleen managed to pull off 390hp with 5.0L SOHC. Ford made the Cobra R with 385 hp from a 5.4L DOHC. Hell I contemplated the idea of building a 5.4 based Ford Modular for my Mustang, but after some research it wouldnt be worth the money even with the best parts chosen for the build. I hate to say it, but I wouldnt bet on GM to build a larger displacement engine (6.0L +) with DOHC with power optimized in regular production cars anyway. Not because they cant, but because they have more cost effective ways to make the power (they are looking at forced induction, LSA, LS9). Not to mention the fact gas mileage is good on current OHV engines. So why change?
If it isnt broke, dont fix it.
If we are talking V6 and I4s then by all means use DOHC. Because I dont think we will ever see a 4.5L bastard OHV V6 in a Camaro, nor do I want to. Lol.
ZL1 Camaro 94blackcamaroz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 57 07-11-2008 12:09 AM
