Emblempros
Old 10-05-2009, 03:44 PM   #1
bilydean
bilydean's Avatar
Drives: One of the rare ABM camaros
door unlocked but won't open
I have had this happen a couple of times and not sure if this is a "feature" or do I really have an intermittent issue.
If I remote unlock both doors and open the passenger side door first, the drivers door won't open from the outside. The lock is up, but when you pull on the handle, nothing happens. I have to go thru the passenger side and open the driver's door from the inside.
So the question, is it supposed to do that?
thanks
Dean
2000 5/23
3000 5/27
3400 6/20 TPW of 6/29
3800 7/3
4D00 7/8 interned at QC
4B00 7/16 Released from QC
4200 7/20
8/5 We picked up the car
bilydean is offline   Reply With Quote
Old 10-05-2009, 03:49 PM   #2
Brokinarrow
Brokinarrow's Avatar
Drives: 2012 Honda NC700x
No, I would definitely take that in to the dealer and get it checked out
Brokinarrow is offline   Reply With Quote
Old 10-05-2009, 04:13 PM   #3
Dan3
Captain of the Failboat
Dan3's Avatar
Drives: 2010 IBM Camaro 2SS/RS
Time to see the dealer.
2010 Camaro 2SS - Imperial Blue w/Black Leather Interior
Ordered - 22 June 2009
Produced - 10 August 2009 : #34143
Delivered - 25 August 2009
Dan3 is offline   Reply With Quote
Old 10-05-2009, 08:16 PM   #4
bilydean
bilydean's Avatar
Thanks guys.
Dean
2000 5/23
3000 5/27
3800 7/3
4200 7/20
Old 10-06-2009, 04:24 AM   #5
Warr3nc
Drives: 1969 Camaro
#PIT4931: A Door May Not Open With The Outside Handle And/Or With The Inside Handle - (Sep 23, 2009)
Subject: A Door May not Open With The Outside Handle And/Or The Inside Handle
Models: 2010 Buick Lacrosse
2010 Cadillac SRX
2010 Chevrolet Camaro and Equinox
2010 GMC Terrain
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Concern 1:
Some Customers may complain that intermittently they may not be able to open a door from the INSIDE door handle.
Concern 2:
Some Customers may complain that intermittently they may not be able to open a door from the OUTSIDE door handle.
Both of these concerns may be caused if the linkage on the door latch is not allowed to fully return to its relaxed position. For the outside door handle, the outside release handle rod can be assembled incorrectly to the outside release lever on the latch resulting in a pre-load condition. For the inside door handle, this may be caused by a kink in the cable, or the cable is not fully seated to the inside door handle assembly.
For vehicles equipped with passive entry, it should still be possible to open the door from the outside handle.
For concerns related to the rear side doors, check to ensure that child security is not engaged.
Recommendation/Instructions:
If the door will not open, it may be possible to open it by applying inboard pressure to the door while pulling on the outside handle.
As the guys above said take it in to the dealer. In the later part of that bulletin it states there might be a clip that needs to be repositioned. Nothing major wrong there, except the fact you can't get in.
Warr3nc is offline   Reply With Quote
Old 10-06-2009, 01:12 PM   #6
bilydean
bilydean's Avatar
The problem though is it only happens if I open the passenger door first. It seems as though there is a setting of some sort that needs changing. When I unlock the doors, the drivers side always works, so long as it is the first one opened.
Dean
2000 5/23
3000 5/27
3800 7/3
4200 7/20
Old 10-09-2009, 02:09 PM   #7
bilydean
bilydean's Avatar
2010 Cadillac SRX
2010 GMC Terrain
Condition/Concern:
Concern 1:
Concern 2:
I took it in this morning and it really was the clip. The passenger door thing was all pure coincidence. It now works like a charm.
Dean
2000 5/23
3000 5/27
3800 7/3
4200 7/20
Camaro won't start unless door is open Evokatana Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 22 07-01-2010 08:50 PM
3rd Annual Corvette Open House at MacMulkin Chevrolet-WELCOMES the ALL NEW CAMARO!! MacMulkin USA - New England 10 06-09-2009 05:14 PM
Camaro unveil open house robby 5th Gen Camaro SS LS LT General Discussions 25 04-21-2009 09:11 AM
3rd Annual Corvette Open House at MacMulkin Chevrolet-WELCOMES the ALL NEW CAMARO!! MacMulkin USA - New England 2 04-11-2009 10:16 AM
