| 5th Gen Camaro SS LS LT General Discussions General 5th generation Camaro topics not covered by other subforums. |
Thread Tools |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Black Camaro 2SS/RS Join Date: Aug 2009
Car "waking up" after oil change..is this due to the fuse pull?
I've seen various people stating their Camaro seemed to "wake up" after their first oil change. But I've also seen people state that there's no way simply changing out the oil could cause this. So I was wondering - are Chevy dealers automatically doing the fuse pull on Camaros they change the oil on? Is this the "wake up," or does the oil change in and of itself do this? Or is the "wake up" simply the result of the car being broken in, which happens to coincide w/ the mileage the oil is being changed at?
I've got 900 miles on the car and I'm contemplating having the oil changed, but I'm hearing conflicting stories. Some say a brand new car's engine needs an early oil change to remove the metal shavings of break-in; some (including the owner of an oil change business that I do payroll for) are saying that's a thing of the past, and today's engines don't need this done. Either way, if the oil change amps performance, I would do it early - I guess my question is - does it? |
most bang for your buck
Drives: 2010 2SS/RS CGM/BLK RALLYS Join Date: Jun 2009
i believe the 'wake up' that people are referring to is the reprogramming of the computer. it adjusts ratios and timing according to your driving habits, to enhance performance and gas mileage. im not certain when exactly it kicks in, or if it does it at the same mileage for every car.
the oil change won't amp performance to the point where you notice it. when your boss says its a thing of the past, he's mostly right...building/filtering processes are better now, however there will always be contaminants in oil on every car. cant get around it 100% yet. that being said, i changed mine at 600. because i know whats in there, and it bugs me. lol so even though it wont make a significant difference either way good or bad, i know that it made a small unnoticeable difference toward the good. i guess i would say frequent oil changes prolong the overall performance and longevity of any engine, whilst infrequent ones will yield you only a small decline in performance/longevity. but i want it all.. just my .02
2G1FT1EW8A9142133 Delivered to me 09/22/09!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS RS M6 CGM/Black Rally Join Date: Sep 2009
Looking forward to the posts on this one ![]() I'm guessing it's not the oil change, but don't listen to me. Just when I think I have the whole break-in and when to change the oil thing figured out, I find a thread and I'm back in the land of clueless!
![]() ![]() ![]() ![]() Drives: 2007 Ford Fusion SE Join Date: Sep 2009
can someone point me to the thread on this whole fuse pull thing, and does the dealer do the reprogramming or an autoshop?
Ordered: 2LT/RS CGM, A6
![]() 1100 = Preliminary Order 10/1/09 2000 = Accepted By GM 12/31/09 3000 = Accepted By Production Control 1/7/10 (TPW: 2/1/10) 3400 = Broadcast 1/23/10 3800 = Produced 2/2/10 (2G1FC1EV6A9189068) 4150 = Invoiced 2/5/10 4200 = Shipped 5000 = Delivered To Dealer 6000 = Delivered To Customer |
#5 | |
#6 |
Institutionally Insane
If you look in the maintenance and break in threads, alot has been discussed about break in and metal.
I personally drove the hell out of my engine and changed the oil at 890 miles. I had quite a bit of metal in the filter, and a aluminum powdery sheen on the oil surface. I cut the filter open and it was impressive. I changed it again at 2900 miles. Some people who do the mandated "manual break in" have not reported the same characteristics I have. So, break in easy, no oil change required wheras, spirited driving, be a little more concerned. The other issue about fuse pulling and oil changes... Oil changing WILL NOT give you an actual performance gain. It is a percieved gain unless, at the dealer the techs are pulling the PCM fuses and letting it relearn the higher octane settings which would result in approximately 30-40 horses and a real actual gain. There is a few threads regarding this and possibly a TSB about that issue. Quite a few people have pulled fuses and been happy. Oil changes alone do not do anything magical.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what? Ordered 2/5/09 1100 2/5/09 2000 4/9/09 2500 4/15/09 3000 4/15/09 3100 4/19/09 3300 5/01/09 3400 5/08/09 3800 5/20/09 VIN 10620 4200 5/22/09 Delivered 5/28/09 |
#7 | |
Snow White can be naughty
I agree; however, my break-in was somewhere in the middle. Did the oil change at 1,700 miles. Couldn't tell any significant difference; but, I sleep a lot better. I get performance improvements by making sure my tires are properly inflated. This creature gets a bit pudgy with even a 4psi drop from the recommended pressures.
| Thread Tools | |
| Oil Changes | Dave McFly | Off-topic Discussions | 6 | 05-18-2010 04:50 PM |
| gas prices. | Congoman775 | General Automotive + Other Cars Discussion | 65 | 05-28-2008 12:20 PM |
| "The car of the future may turn out to be no car at all." | Scotsman | General Automotive + Other Cars Discussion | 2 | 11-03-2007 12:22 AM |
| Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
