Rick@Livernois
Old 10-07-2009, 06:16 PM   #1
7CAMARO7
7CAMARO7's Avatar
Drives: Slow 4th gen
Lightbulb Save Money on Oil and Oil Filters!
I recently had an oil analysis done on my 2002 Camaro SS. I've got full boltons with a tune. This car is raced occasionally and driven daily. It gets a pretty good amount of highway miles. I always do my oil changes my self and somehow got heart enough to put faith in my ols(oil monitering system). This was the first time I did it. I read online while researching that in the owner's manual of fleet cars, gm says to only change the oil when the oil change light comes on. What's different about their car than mine? Nothing, exactly!
I got my results and here they are.
They said everything looks GREAT!
LIONEL: Nothing unusual showed up in this initial sample from the 5.7L in your '02 SS. Universal averages
show typical wear levels for this type of engine after about 4,100 miles on the oil. This oil was run longer
than that and wear metals still read nice and low, so there are no evident problems developing inside your
engine. The 2.4 TBN shows some oil additive still active (1.0 is the low cutoff for extended oil use). Low
silicon and insolubles show sound air and oil filtration. The viscosity was 5W/30 and no contaminants were
found. Try ~8,000 miles next oil fill.
09/29/09
02 SS
Gasoline (Unleaded) Citgo Ethanol Free93oct
Pennzoil Platinum 5W/30 K&N Oil Filter
1 qt added
10/7/2009
GM LS-1 5.7L 346 CI V-8
6,439 Miles
My car had 96,674miles on it when I changed the oil btw
You guys should be able to get a way longer oil change interval than I can since you've got larger oil pans.
Somebody tell me how to post the copy on here.
7CAMARO7 is offline   Reply With Quote
Old 10-07-2009, 07:03 PM   #2
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
My last Blackstone lab analysis stated my 168K LS1 could go 6k between oil changes.
Nothing unusual, wearing great.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 10-07-2009, 09:11 PM   #3
7CAMARO7
7CAMARO7's Avatar
that's great! they did mine too. What oil and filter were you using?
Old 10-07-2009, 09:18 PM   #4
Banshee
Banshee's Avatar
Pennzoil Platinum 5w and Mobil1
Old 10-07-2009, 09:21 PM   #5
7CAMARO7
7CAMARO7's Avatar
good stuff, huh? That's what one of my professors says all the time lol
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
