BeckyD@RodgersChevrolet
General Automotive + Other Cars Discussion Come chat about other cars.
Old 06-17-2008, 10:35 AM   #1
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
Exclamation The 3,000 Mile Oil Change Myth
By Bill Siuru, provided by: Greencar.com
According to a recent study by the California Integrated Waste Management Board, 73 percent of California drivers change their oil more frequently than required. This same scenario no doubt repeats itself across the country. Besides wasting money, this translates into unnecessary consumption of $100-a-barrel oil, much of it imported.
Using 2005 data, the Board estimates that Californians alone generate about 153.5 million gallons of waste oil annually, of which only about 60 percent is recycled. Used motor oil poses the greatest environmental risk of all automotive fluids because it is insoluble, persistent, and contains heavy metal and toxic chemicals. One gallon of used oil can foul the taste of one million gallons of water.
It’s been a misconception for years that engine oil should be changed every 3000 miles, even though most auto manufacturers now recommend oil changes at 5,000, 7,000, or even 10,000 mile intervals under normal driving conditions.
Greatly improved oils, including synthetic oils, coupled with better engines mean longer spans between oil changes without harming an engine. The 3000 mile interval is a carryover from days when engines used single-grade, non-detergent oils.
For several years, automakers like General Motors, BMW, and Mercedes-Benz have installed computerized systems that alert drivers via an instrument panel light when it’s time to change oil. As an example, the General Motor Oil Life System (GMOLS) analyzes the engine temperature, rpms, vehicle speeds, and other driving conditions to calculate the rate of engine oil degradation. Then, software calculates when the oil needs to be changed. Other systems work similarly.
Because of the many external conditions and parameters that have to be taken into account, calculating the precise maximum service interval using mathematical models alone is difficult. Now, Daimler AG has developed a more direct and precise way to monitor oil quality directly on board a vehicle.
Daimler uses a special sensor integrated into the oil circuit to monitor engine oil directly. Oil doesn’t wear out, but rather dirt and impurities cause oil to lose its ability to lubricate properly, dictating the need for a change. Daimler uses the oil’s “permittivity,” that is, the ability to polarize in response to the electric field. If the engine oil is contaminated by water or soot particles, it polarizes to a greater extent and its permittivity increases.
To evaluate the quality of the oil, permittivity is measured by applying an AC potential between the interior and exterior pipes of an oil-filled sensor to determine how well the oil transmits the applied electric field.
Because not all impurities can be measured with sufficient precision via the electric field method, Daimler also measures the oil’s viscosity to detect any fuel that may have seeped into the oil. Daimler researchers measure viscosity while the vehicle is in motion by observing the oil's side-to-side motion in the oil sump. The slower the oil moves, the higher its viscosity. This movement is registered by a sensor and the viscosity is calculated on this basis.
A single sensor, along with the information already monitored by on-board computers, is sufficient to determine the various parameters of the engine oil. Daimler will likely use the technology first on its commercial vehicles. Here, large oil reservoirs mean larger quantities of oil can be saved. Plus, a predicted 25 percent increase between service intervals and reduced downtime will be of interest to fleets, and thus justify the added cost of installation.
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 06-17-2008, 10:51 AM   #2
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
Before this thread explodes:
1. BITOG is the generally accepted authority on what really works
2. Seriously, who ever has a problem that could have been prevented by more frequent / better oil? Most cars go to the junkyard with any of a million other problems, never anything that can be attributed to oil habits, even among those who follow the manufacturer's recommended schedule instead of using $10/quart oil every 3000 miles.
One data point does not a trend make, but my truck has 170,000 miles on it and runs great -- and I've been pretty awful with oil changes. I've had a few different mechanics, each of whom probably uses a different brand; never used synthetic or special high-mileage formulations. I've usually changed it when the idiot light goes on, which generally has been 6,000 to 7,000 miles. If I said all that without telling you how many miles I have, a bunch of people would post that my engine will seize before 100,000 miles. I don't get any smoke, I've got all the power to tow my 6,000 pound camper, etc...
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 06-17-2008, 10:54 AM   #3
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2012 Camaro ZL1
I listen to my car. I'll let it tell me when to change the oil.
60-something% life still? And I'm already over 5000 miles on the stuff.
"Keep the faith." - - Read Before You Post.
Old 06-17-2008, 10:55 AM   #4
Chevyrocker
Weekend Rockstar
Chevyrocker's Avatar
Drives: Depends on the day...
The Oil Life Monitor system from GM works pretty well...I didn't know that Diamler Chrysler was building one that was that superior...I love technology.
Chevyrocker is offline   Reply With Quote
Old 06-17-2008, 12:10 PM   #5
Bumble Bee '77
AutoBot Scout
Drives: 2002 ZRS Camaro
Hmm funny you should bring this thread up , I just changed my oil a few weeks ago and filled it with 4 1/2 quarts of 5w30 Royal Purple and now recently when i start the car the change oil light comes on. And I know I haven't driven 5k since the change. The light goes out after about 10 minutes. Could the sensor be messed up?
Bumble Bee '77 is offline   Reply With Quote
Old 06-17-2008, 12:30 PM   #6
theholycow
theholycow's Avatar
Did you reset the counter? It doesn't measure viscosity and conductivity like the Chrysler system described by the OP. It just calculates how badly the oil should be aging based on load / temperature / miles / etc, and must be reset when you change the oil.
Edit: That's assuming you're talking about your 2001 Camaro.
Old 06-17-2008, 12:36 PM   #7
ToneyTone
ToneyTone's Avatar
Drives: 07' Sunburst Cobalt SS/SC
5k is the longest i'll go between changes.
ToneyTone is offline   Reply With Quote
Old 06-17-2008, 01:49 PM   #8
Silverado
GM Guy For Life
Drives: 2010 GMC Yukon XL
I've been changing oil every 5K for 12 years now....
But, I don't do the kind of driving that breaks down oil too quickly either.
Silverado is offline   Reply With Quote
Old 06-17-2008, 05:33 PM   #9
chadrcr
to Z or not to Z
chadrcr's Avatar
Drives: 99 S10 ZR2
Besides the cool computers tellin you when to change the oil......
try checking the oil on occasion, say around 2/3000 miles and then every 1000 miles or so after that. Try comparing the consistency/ cleanliness of the oil in your engine, to the oil you would put in it..... if the oil in the motor looks clean etc... wait to change the oil. If it looks black or dark brown, change it and start checking a lot sooner.
99 S-10 ZR2
06 GMC Z71 - - - sold...
getting ready for my Camaro
02 Z28 - - - sold :( miss it!
chadrcr is offline   Reply With Quote
Old 06-17-2008, 06:01 PM   #10
MerF
Go Rays!
MerF's Avatar
Drives: 03 Trailblazer
Dude my Trailblazer had me all sorts of weirded out, I thought it was broken because it was taking forever to tick down to below 15%! I got it changed today because we're about to drive to Florida and didn't want it ticking down on the road trip, so I changed it at 22% but its' the first oil changed we've done on it since buying it in NOVEMBER!
MerF is offline   Reply With Quote
Old 06-18-2008, 12:37 PM   #11
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I change oil when its recomended, I trust that the engineers who designed the engine know better than I do about when its time to change the oil.
Quote: In 2014 the camaro will have ... a twin turbo v6 ... around 350 to 360HP
No. Let me repeat that. No. FbodFather
Camaro5 Fest III Information
Camaro5 Fest III pre-registration
Old 06-18-2008, 03:45 PM   #12
Bumble Bee '77
AutoBot Scout
yeah im talking about my 2001and yeah i reset the counter.
Old 06-18-2008, 06:01 PM   #13
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
who knew....
I always hit the autozone soon as the light comes on
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Old 06-18-2008, 07:05 PM   #14
The_Blur
Moderator, USN
The_Blur's Avatar
Drives: 2000 Firebird Formula NHRA SE
When I had my Cobalt, I obeyed the sensor every time. It usually went over 7k miles. If more people were aware of this, we could lower oil costs.
newborn gifts
Old 07-17-2008, 08:46 PM   #15
gladiatoro
gladiatoro's Avatar
Drives: 1981 Z28 Camaro
AMSOIL is the answer
Have you guys ever heard of AMSOIL they basically invented synthetic oils years ago before anyone else had it. 100 % full synthetic motor oil , I use it in my Mercedes and it is good for 25.000 miles per oil change, GUARANTEED amazing product they can even test your oil say at 20.000 miles by a independent lap to prove it is still good, but you do need a special oil filter with nano fiber technology that can handle the extended drain cycle which AMSOIL also makes. If everyone used these SUPER OILS our oil prices would go way way down . Not only that they are much better for your engine since synthetic oils almost totally eliminate engine wear due to there extreme anti friction properties , I was in Germany on holidays a few years a go and I rented a brand new BMW for the autobahn anyways the digital computer said next oil change in 30000 km , the oil is full syntetic right from the factory when it is built thats why ...
gladiatoro is offline   Reply With Quote
Old 07-18-2008, 02:31 AM   #16
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: THRSS #2 / CGM#1
^Nice. I wouldn't mind doing an oil change every 30K miles. Too bad it would prolly cost an arm and a leg. But.....
My dealer finally told me 5,000 miles between oil changes with fully synthetic.
The build of THRSS #2
Old 07-18-2008, 05:12 AM   #17
Emher
Pillaging Viking
Emher's Avatar
Drives: Saab 9-5 '99 (Hey it's a GM!)
Send a message via MSN to Emher Send a message via Yahoo to Emher Send a message via Skype™ to Emher
I hope the Camaro has an information center that tells me when to change the oil because I don't know anything about this kind of stuff Although in all fairness I'd probably learn it all to keep the Camaro running as long as possible.
"Fifty years from now, when you're looking back at your life, don't you want to be able to say you had the guts to get in the car?"
Emher is offline   Reply With Quote
Old 07-18-2008, 08:32 AM   #18
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
I have my own opinion based on facts and research done years and years ago that I can't find so I'll just paraphrase.
Oil isn't what needs to be changed that often, Its the filter. Filters are usualy only good for 3000 miles before they start backing/letting particles through.
My rotation is the following
Real oil - filter change at every 3000 miles complete change every 5k miles.
Synth oil - Filter change at every 3000 miles and complete oil/filter at 8k miles.
My wifes truck gets whatever Toyota wants done to it cause when/if it breaks they will be paying for it.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
The_Stache is offline   Reply With Quote
Old 07-18-2008, 09:12 AM   #19
Mr. Wyndham
I don't change it until the car tells me to. But I check the oil at 3000, and every 1000 after that until I get the alert, or my checking reveals crappy oil.
Old 07-18-2008, 09:17 AM   #20
Muscle Master
SS Lightning
Drives: An SRT8
I been meaning to look for a good proformence filter
Old 07-18-2008, 10:51 AM   #21
gladiatoro
gladiatoro's Avatar
Is your dealer a oil expert probably not , anyways do your own research , yes oil filters are the main problem this is why AMSOIL has special filters with NANOTECHNOLOGY that are capable of extended drain usage. I have noticed my car has more power and starts much nicer now using these high tech oils. If been using AMSOIL for years now the price is probably the same or less considering you get 5 times longer miles out of one oil change vs cheap oil , and think of all the time saved too from not having to do all those oil changes , plus it's much better for your cars engine anyways ...
Old 07-18-2008, 11:10 AM   #22
Txturbo
Keeper of the Faith
Txturbo's Avatar
Drives: 2001 Z28 Agressively
We bought our 03 Avalanche new. I only change the oil when it tells me to, and that is normally between 5k and 8k miles. It now has over 160000 miles on it and still runs great, no smoke, and doesn't burn any significant amount of oil between changes.
2010 Camaro SS R6P
2001 Camaro Z28
1969 Camaro SS clone
Txturbo is offline   Reply With Quote
Old 07-18-2008, 11:19 AM   #23
Chevyrocker
Weekend Rockstar
it definitely will. The DIC (driver information center, feel free to let the jokes roll in because your car has a DIC) is becoming very standard in the new Chevy's. Even the Aveo will have it in '09...
Old 07-18-2008, 11:26 AM   #24
The_Blur
Moderator, USN
The_Blur's Avatar
My Subaru has been able to handle late oil changes without any performance issues. I think the shops just want us to believe this myth so we come in more often and they can charge us more frequently. As a business approach, that's a great way to make a few extra bucks.
newborn gifts
Old 07-18-2008, 01:11 PM   #25
Navy Blue
Future Camaro Owner
Drives: 2001 Chevy Impala
as a younger guy i really didnt know much about cars til about 2 years ago i started learning parts, what they do,.. until 1 year ago i started checking my car's oil regularly, rotating my own tires, its simple stuff that shops charge alot for, i'm in the proccess of learning to change my brakes, they say its easy, but i wanna make sure, theese are the brakes after all..if i screw up it could be bad, but staying with the thread, when my oil starts getting dirtier or darker i give it a few more miles, when i see its a bit darker i change it, theres alot of construction by my house on main roads i use, so my oil gets dirty fast, air filter too, so i can'y really wait for my light to come on as instructed in the manual, i just change my oil and filter when i see its time to.
Navy Blue is offline   Reply With Quote
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 12:20 PM
Huge offshore oil discovery KILLER74Z28 Off-topic Discussions 36 11-14-2007 06:14 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
