Old 10-08-2009, 02:42 PM   #1
chevy454
chevy454's Avatar
Drives: '69 Yenko Camaro - 11.73 @ 118
Nitto 555 drag radials: 305 or 275?
For the stock 20" wheels on our '10, will we need the 275/40R20 or the 305/35R20? I'm assuming the 275??
chevy454 is offline   Reply With Quote
Old 10-08-2009, 04:28 PM   #2
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Based solely on rim width for the stock 20's, you'll want the 275's. Stock rim width is 9". The 305's need at least a 10" rim width.
rolnslo is offline   Reply With Quote
Old 10-08-2009, 09:22 PM   #3
chevy454
chevy454's Avatar
Ok, thanks! Our car is the 1SS/RS w/20" wheels...anyone out there have a 10" wide wheel that'll match the factory fronts?
Old 10-08-2009, 09:42 PM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
i have the Nitto 555 drag radials, 305's on my factory rims for at the track and they work great, 1.7 60' time with a very short burn out,
they fit fine on the stock 9" rim
Old 10-08-2009, 10:15 PM   #5
Sleestack
Sleestack's Avatar
Drives: '07 SRT8 SuperBee, '09 GT500
This is probably a judgement call on your part. The Nittos all run narrow from the factory, so the 305 is really like a 295. However, they are still out of SPEC for a 9inch wheel. Like the other poster said, they WILL fit, and probably not bulge too much. However, they likely will not wear evenly if you spend much time on the road.......so.... if your car is a daily driver, I would NOT go with the 305's. If your car is a garage\weekend car and you want sticky tires that you realize may wear out after 6k miles, go for it......
Sleestack is offline   Reply With Quote
Old 10-09-2009, 05:35 AM   #6
chevy454
chevy454's Avatar
I'm gonna throw them on a spare set of rear wheels (20"), so it sounds like the 305s should be fine...?
Old 10-09-2009, 06:49 AM   #7
camaro1
camaro1's Avatar
i drove mine for over 2000 miles with no issues on the factory 9" rims
you will need a tune to correct your speedometer, it will be off 2 mph with the nitto's
Goodyear jumps into Drag Radials radz28 Dragstrip and Launch Techniques Discussion 4 09-30-2009 08:36 PM
ET Drags vs ET Drag radials TC Dragstrip and Launch Techniques Discussion 7 09-23-2009 05:33 PM
Rims and Drag Radials RickyTheStorm Wheels and Tires Talk Sponsored by The Tire Rack 17 09-10-2009 08:15 PM
Drag Radials TC Wheels and Tires Talk Sponsored by The Tire Rack 12 08-11-2009 07:38 AM
