autoguy
Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 10-09-2009, 09:37 AM   #1
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
gm tech 2 with 2010 camaro
just to let everyone know the gm tech 2 will work with the 2010 camaro for engine and trans, and some other modules, i own my own tech 2 with candi module and i also have a MDI unit for the modules the tech 2 wont communicate with
but for tuning and watching data the gm tech 2 works great
Old 10-09-2009, 11:17 AM   #2
Kirk@VectorMotorsports
Drives: G8 GT
Our Tech 2 will not connect unless we build the vehicle as a 2009 G8 GXP. Then it works great.
Kirk@VectorMotorsports is offline   Reply With Quote
Old 10-09-2009, 11:28 AM   #3
camaro1
camaro1's Avatar
yup that is the trick
Old 10-10-2009, 10:10 AM   #4
Drives: G8 GT
BTW, sweet car you have there.
Old 10-10-2009, 11:47 AM   #5
camaro1
camaro1's Avatar
thanks, its going to get put away for winter storage soon, i have a few things to get over the winter
-fast lsxr 102mm intake(maybe a nick williams 102mm electric t/b)
-kooks header back 3" system
-GEARS(hopefully someone has gears by spring time) otherwise i will pick up a complete diff from a LS3 car and gain a little better rear gear
Old 10-10-2009, 02:26 PM   #6
BigFish
BigFish's Avatar
Drives: 1971 Z28
That's good news...
BigFish is offline   Reply With Quote
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Cosmetics and Lighting Modification Discussions 29 03-11-2010 09:36 AM
Vortech Supercharger Systems for 2010 Camaro Official Release Brian@Vortech Forced Induction - V8 99 02-19-2010 11:04 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
Camaro (concept) Press Release!! Pencil.Fight 5th Gen Camaro SS LS LT General Discussions 4 07-21-2008 03:33 PM
