sjm autoprod
Old 10-09-2009, 11:29 AM   #1
paulm85
Red Jewl
paulm85's Avatar
Drives: 2010 2SS/RS, M6
V8 maual tranny oil
Hey guys, I have tried to search and can't really find anything, so I am sorry if it has been talked about already.
What kind of oil is the V8 manual tranny, I am thinking of changing mine early just to flush it out and put in new for storage over the winter.
It doesnt really give a spec for it in my owners manual, just a GM part number. So I guess what I am asking is, what Kind of gear oil will it take and what are some good oils to go back in?
Thanks
2010 Camaro 2SS/RS Red Jewel/CGM stripes vin #38202
Permagrin started on 9/12/2009
paulm85 is offline   Reply With Quote
Old 10-17-2009, 10:08 PM   #2
LT1Jeep
Ecstatic Camaro SS Owner
LT1Jeep's Avatar
Drives: Jeep(s) [1in pieces] and 2010 SS/RS
i remember a thread on here about a complete teardown of a car that was being built into a racecar and they said the manual tranny fluid circuit was tied into the powersteering pump and cooler, so it is ATF, not actual gear oil. which is a lil weird but not uncommon. many transfercases in trucks uses ATF and some newer gen manuals are usign a specific MTL type lube in the 5w30 viscocity, not actual gear oil like 75w90.
LT1Jeep is offline   Reply With Quote
Old 10-17-2009, 10:10 PM   #3
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
Its a T-6 so maybe check Tremec. just a suggestion
lawdogg149 is offline   Reply With Quote
Old 10-18-2009, 12:41 AM   #4
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Read your owners manual.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 10-18-2009, 07:19 AM   #5
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
ATF dexron 3, not the new dexron 6, 3.6qts
Old 10-18-2009, 08:34 AM   #6
Ranger 75
Ranger 75's Avatar
Drives: 2010 Camaro 2SS IBM
Tremec 6060, Sealed Tranny (filled for life)
Ranger 75 is offline   Reply With Quote
Old 10-18-2009, 11:39 AM   #7
camaro1
camaro1's Avatar
that does not mean you cant change the fluid whenever you want too. they still have a drain and fill plug like any other manual trans., the auto cars have no dipstick for checking fluid level and are also filled for life, but i have changed the fluid in mine already.
Old 10-19-2009, 08:30 AM   #8
paulm85
Red Jewl
paulm85's Avatar
Umm I did read in the manual....thank you. All it says is a GM part number which when I went to the dealer the have it in stock and all it says for description on the label is "manual transmission oil."
I was looking for what weight it was so that part didn't help.
Thanks to the others for the information and not just telling me I am on my own.
Old 10-19-2009, 12:30 PM   #9
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
There is no way of knowing unless you can get ahold of some one with gm...I work at a dealership and there isnt even a way of me finding out sorry dude
WICKEDSS is offline   Reply With Quote
Old 10-20-2009, 09:34 AM   #10
paulm85
Red Jewl
paulm85's Avatar
Alright, thanks buddy. That was the problem with it, I couldn't even find out from my dealer.
Old 10-20-2009, 09:48 AM   #11
camaro1
camaro1's Avatar
the trans fluid is dexron 3, here is the story:
when gm switched to dexron 6 auto trans fluid they did not do the testing to see if dexron 6 is backward compatable with all the older transfer cases and manual transmissions that they had previously used standard atf(dexron3)trans fluid in, so the came out with what they now call "manual trans fluid" that is still made to dexron 3 specs
if you buy it from gm it is now called "manual trans fluid", it is just dexron 3 re-packaged
Old 10-20-2009, 01:19 PM   #12
OUR72GTO
OUR72GTO's Avatar
To answer the original question.........the GM part #. Change it as often as you like BUT why would you replace it with an unknown.? And possibly void the warranty.
Old 10-20-2009, 09:55 PM   #13
FirstLSK
Dude, I love my car !!!!
FirstLSK's Avatar
Drives: 2010 Black 2SS/RS white rally
From the owners manual:
Manual Transmission (V8 Engine):
Manual Transmission Fluid (GM Part No. U.S. 88861800,
in Canada 88861801).
FirstLSK is offline   Reply With Quote
Old 10-20-2009, 09:58 PM   #14
camaro1
camaro1's Avatar
its just plain old dexron 3 ATF
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
