Camaro Forum - 2011 Camaro 2010 Camaro / Camaro Z28 SS Forums - Camaro5.com
JDP Motorsports
Go Back   Camaro Forum - 2011 Camaro 2010 Camaro / Camaro Z28 SS Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 10-10-2009, 02:28 PM   #1
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
DIY: GFX Outlets add Wire Mesh and Paint, Muffler Delete
Hey this is my first DIY write up so give me a little slack.
Before Pics
Items Necessary:
lift
something to cut off your muffler (a saw will work if you don't have anything fancy)
Muffler Dump tips
Welder
The wire mesh you want
Cardboard
Sharpie (marker that works on paint)
Tin snips/shears (big heavy duty sicissors)
Rough, medium and fine sand paper
Flat black rust proof paint (anycolor you want actually)
Weird Screw head and driver (see below picture)
Ratchet, and ratchet adapter to accept the weird screw head.
Plyers (something to grab and hold still the little screw piece while you screw it in)
Step 1: Delete your mufflers (this is simple enough to do yourself but you can pay a muffler shop and they'd do it for around 40 usd... don't pay more than that)
Cut and remove, Not difficult but I'd have someone there to help you hold it up while you cut.
Each one weighs about 18 lbs so that's 36lbs of weight loss.
Here's where to make the cuts (you can go closer to the cats if you want but I did it here to keep it simple:
Step 2: weld on some dump tips
Step 3: remove your outlets using one of these screw heads on the 4 screws located on the outlets. (I don't know what the screw head is called someone help me out here)
Step 4: Lay down your outlet on the cardboard and trace the inside opening for your cardboard template. Cut it out and place inside to see if it fits, you will more than likely have to trim certain spots to get it to fit. Also, the same template might not work for both so you should one for each outlet. They will be pretty close though.
Step 5: Trace the outline of your template on the wire mesh and then cut out with your tinsnips and sand the edges down with the rough grit till they fit flush inside your outlets. (NOTE: This is probably the most difficult part of this project, you have to insert it at an angle then lay it flat and figure out which points aren't letting you press it down all the way then remove and sand down those points. I used the sharpie again to make marks where these pressure points were so I could sand those spots a little extra till it fit nice and snug) When you have the mesh inserts fitting nicely, sand the front and back faces with the medium grit sand paper
Step 6: Sand the Outlets (only where it will be visable on the GFX with medium then fine grit sand paper. (unless you don't want to paint them then skip this step).
(NOTE if you don't want to paint your outlets or inserts you will have to tape off your outlets where it will be visable with lots of masking tape or painters tape due to the specks of liquid metal from making the welds before doing the next step. OR you could do apoxy or JB weld, I wouldn't do that though)
Step 7: Weld mesh inserts in place then sand off any of the metal specs with the medium sand paper followed by the fine grit (if it's a big speck you can poke it off with a flat head and a hammer then sand)
Step 8: Paint, allow to dry, paint, and allow to dry (repeat till you feel good about it, 4 for me)
Step 9: Install outlets back on your GFX. This can be done from a driveway but your neck will be sore the next day (I did). Use your weird screw head tool and your plyers. (Note this part can be a little tricky since now you have wire mesh in the outlet the top screw to the outlet is a little harder to reach. I slid the weird screw tool through the wire mesh and ratcheted it in. If you make some scratches on your wire mesh you can just make some touchups with a q-tip and your paint)
Enjoy the awesome new look of your GFX (these pics were done b4 I did the touchups so you can see where I slid the weird tool in there)
This took me about about 4 hours worth of work prior to painting. Then about another half our to reinstall and 2 minutes to do the touchup.
I hope this helps... PM me with any questions. I'd be glad to help you out.
Li0nel1234 is offline   Reply With Quote
Old 10-28-2009, 04:02 PM   #2
yubman
Drives: 99 Miata
Looks good. Always thought the tips inside the ground effects looked kind of redundant.
Without mufflers at all, your car must be very loud.
yubman is offline   Reply With Quote
Old 10-28-2009, 04:15 PM   #3
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Drives: SIM 2SS/RS M6
hmm interesting
SIM 6Spd. RS/2SS W/ CGM Stripes, Black Int.
5th_GEN_SS is offline   Reply With Quote
Old 10-28-2009, 05:06 PM   #4
CamaroSkooter
Hi! My Name Is Justin!
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
I didn't know you were just running turn-downs. Nice setup
Old 10-28-2009, 06:28 PM   #5
5thGen
Drives: Black 2LT/RS, jeep Wrangler
cool, not on your car ..
5thGen is offline   Reply With Quote
Old 10-29-2009, 02:06 PM   #6
Demon Hunter
SoCal C5 Family Member
Demon Hunter's Avatar
Drives: 2010 Black Camero LT
Any one know how legal this really is. I'd imagine it's pretty freakin' load. I'd assume that'd get you in trouble in most states. I'd do it if I knew I could get away with it in California.
Demon Hunter is offline   Reply With Quote
Old 10-29-2009, 02:11 PM   #7
Camaro509
Camaro509's Avatar
Drives: 2010 2SS/RS Black
It isn't that loud at all. Had this done to mine as well, cept straight pipes and factory tips reinstalled. It is of course louder without the mufflers, but it isn't so loud I'll get tickets for it.
Really like that mesh-look without the tips showing through.
Oh yea, that is called a Torx drive.
Understeer, Oversteer, Wheel Alignment (Camber etc), Torque, Horsepower, Camaro
Fold for team 11108 to help find a cure!
Folding@home Stanford's Research DC Program.
Camaro509 is offline   Reply With Quote
Old 10-29-2009, 02:13 PM   #8
GTAHVIT
Moderator
GTAHVIT's Avatar
Drives: #22 Tom Henry Racing 2010 2SS/RS
You can't get away with this in CA... Nor any state that has emmisions inspections....
But in FL.....
Old 10-29-2009, 05:09 PM   #9
5thGen
But in FL.....
bs . i rented a shelby in florida and got a ticket in a residential area cause the cops assumed we were going over 20 it was all the sound
Old 10-29-2009, 05:19 PM   #10
Li0nel1234
Li0nel1234's Avatar
? what does that mean?
Old 10-29-2009, 05:19 PM   #11
Li0nel1234
Li0nel1234's Avatar
It's legal here. As long as u don't remove the cats.
Old 10-29-2009, 05:46 PM   #12
GTAHVIT
Moderator
GTAHVIT's Avatar
you got a speeding ticket not a smog law ticket...
Old 11-07-2009, 10:03 PM   #13
qbert48
qbert48's Avatar
Drives: 2SS SIM 14846
But in FL.....
been to the guys here and good to go they said it's OK in TEXAS maybe i got a pass
2SS RS SIM gray leather stick shift ground FX
thank you gary richards @ classic chevy in sugarland
welcome home
1100 4-27-09
6000 6-27-09
yes i got to the dance late don't hate me
qbert48 is offline   Reply With Quote
Old 11-07-2009, 10:13 PM   #14
Indpowr
Camarostyle.com
Indpowr's Avatar
Drives: Corvette C6
I plan on adding mesh when we get our gfx kit.
www.camarostyle.com (FULL custom leather interiors/Wheels/Body Kits) My Garage http://www.cardomain.com/id/KandyCorvette2
Old 11-07-2009, 11:12 PM   #15
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: Jayden - Oh 10 VR SS/RS Man. 6 GFX
You need to lift the car to remove the bezels? Or can they be popped off easy?
Looks good btw.
Red 1SS/RS GFX Ordered - 8/4/09 & Joined Camaro5.com family
Old 11-16-2009, 03:59 PM   #16
Li0nel1234
Li0nel1234's Avatar
You don't need to for the outlets. You can from your driveway. I did but my neck was sore. I don't know if you can with the muffler still in place it might make it more difficult.
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
