Old 10-10-2009, 06:06 PM   #1
OrangeChevyII
Drives: 2010 RS/SS2
Big Day tomorrow
Going to try and raise the bar on the record for the fastets N/A pass, swapped the rear brakes out today and put a underdrive pulley on the crank.
To my knowledge no one has ran any faster then my 11.37 pass, going to try and see if I can break into the 10 second barrier tomorrow with out the bottle. I had full intentions of pulling the heads off this week and having them milled but we were too busy at the shop to mess with it.
This Texas weather is perfect for drag racing, tomorrow's high is 63 and the DA currently is less then 600 ft. We'd go tonight but ODRA has the track rented:(
2010 SS/RS SIM
First to run 11's (11.83)on a stock long block.
First to run 11's cam only
First to run 11's all motor
First to run 10's (10.96) and did it with a 100% bonestock long block and a power adder (nitrous)
First to run 10's (10.55) on motor in 2010 Camaro
First to break into the 5's (5.97) 1/8th mile
First to cut a 1.5X sixty foot
First to cut a 1.4x sixty foot
First to car to cut a 1.3x 60ft
OrangeChevyII is offline   Reply With Quote
Old 10-10-2009, 06:08 PM   #2
rodimus prime
Drives: Cargo van.
Good luck bro. Show the haters what a 3900 pig can do.
rodimus prime is offline   Reply With Quote
Old 10-10-2009, 06:08 PM   #3
1320junkie
Drives: The Imperial Army
Cant wait to see the results
Old 10-10-2009, 06:11 PM   #4
OrangeChevyII
Drives: 2010 RS/SS2
I dropped another 61.5 pounds of rotating weight just from the rotors, I forgot to weigh the calipers.
Edit:I cant add
2010 SS/RS SIM
Old 10-10-2009, 06:12 PM   #5
1320junkie
Originally Posted by OrangeChevyII View Post
I dropped another 45 pounds of rotating weight just from the rotors, I forgot to weigh the calipers.
Thats awesome..wow
Old 10-10-2009, 06:16 PM   #6
OrangeChevyII
Drives: 2010 RS/SS2
I ordered some spacers for the rear that bolt on to clear my 16" CCW's, they are the 10" Classics and they rub the control arm with no spacer on them. If they were the 9" wheels, they would fit now. Thats another 30 pounds of rotating weight saved!
2010 SS/RS SIM
Old 10-10-2009, 06:18 PM   #7
1320junkie
Man you need to do a weight loss thread
Old 10-10-2009, 06:26 PM   #8
OrangeChevyII
Drives: 2010 RS/SS2
I know pretty much what everything has weighed vs what I put back on it. Car should weigh in at 3780 w/ driver tomorrow, I need to drain the tank.......it's full. Bad weather here all this week.
2010 SS/RS SIM
Old 10-10-2009, 06:35 PM   #9
Sam88gta1
Drives: 2010 Camaro SS / 2006 CC Duramax
It ended up being 20.5 lbs lighter with the v6 rear brakes.The calipers weigh the same and each rotor was 10.25 lbs lighter.
Sam88gta1 is offline   Reply With Quote
Old 10-10-2009, 06:37 PM   #10
OrangeChevyII
Drives: 2010 RS/SS2
So 61.5 pounds of rotating weight.
2010 SS/RS SIM
Old 10-10-2009, 06:41 PM   #11
Sam88gta1
What ever it takes to go fast!
You are going to be in the 10's on motor before anyone else gets there with a power adder.
Old 10-10-2009, 06:42 PM   #12
1320junkie
He has already been in the 10's on spray
Old 10-10-2009, 06:43 PM   #13
Sam88gta1
I am aware of that. I was talking about him running 10's on nitrous and 10's on motor before anyone else.
Old 10-10-2009, 06:44 PM   #14
freemaSSon
Pat @ ADM PERFORMANCE
freemaSSon's Avatar
Drives: CGM SS/RS M6
Myself and Number_9 plan to be there tomorrow.....
We'll see if I can 60' with a clutch.....Been paying close attention to what you and Sam have been doing out of the gate....We'll see if I can pull it off with the P-ZERO's....
I'd be happy with a SUB 2.0 but if I could get in the 1.8X range then all the better !
"old age and treachery will always overcome youth and ambition"
author unknown
"There are two types of racers: cheaters...and losers."
Smokey Yunick
freemaSSon is offline   Reply With Quote
This site is like crack. You know you're addicted to Camaro5 when... GameOver620 5th Gen Camaro SS LS LT General Discussions 463 01-03-2011 03:28 PM
COLLEGE FOOTBALL THREAD...R U ready for Some football? hb-rocks The Sports Lounge 150 10-17-2010 12:05 AM
The big day is finally here. croyal1974 5th Gen Camaro SS LS LT General Discussions 8 07-07-2009 04:11 PM
May 27th, 2009 - A Historic Day!!!!! CamaroScotty 5th Gen Camaro SS LS LT General Discussions 50 05-28-2009 02:19 PM
Big day tomorrow! REVIEWS coming StlRomAniaN 5th Gen Camaro SS LS LT General Discussions 13 03-19-2009 03:59 PM
