JDP Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
1st & 2nd Generation Camaros 1967-1969 Camaros / 1970-1981 Camaro
Old 10-10-2009, 08:14 PM   #1
Zieke
Camaro Deprived
Zieke's Avatar
Drives: 78 Camaro, 00 Tahoe, 10 Cobalt
Send a message via MSN to Zieke
Need some advice with 78 front brakes
While i was on leave back home my dad and i replaced almost the entire rear brakes.
heres some pics:
and yes, i had been driving this car for over a year with the breaks like this. glad the fronts worked good enough.
What i need help with is what to do with the fronts now.
The parts we used on the rear were ones my dad has had since before 94'.
What brand of parts would be best to use for the front brakes. Im going to be replacing basically everything.
My posts are of my opinion most of the time.
I am young and inexperienced. Please don't hate on me for it.
Joined Active Navy: 10-28-08
Zieke is offline   Reply With Quote
Old 10-11-2009, 07:19 AM   #2
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Did you replace the emergency brake cable at the rear? I would if I were you. I bet you a doughnut the cable was sticking.
You will want to get some rebuilt calipers and probably some pins. The hoses are a good idea at this time at this time. The master cylinder might be still functional but they are cheap to replace and you already have the system apart so give that some consideration. Turn the rotors if they are still within spec. There isn't any sense replacing them if they are still serviceable. The bearings and seals - I am on the fence here. The bearings you can get today are not as good as the originals in my opinion so if the bearings look good enough you can just clean and repack them. Get a new National Oil Seal grease seal and a handfull of cotter pins while you are at it. Pads - just get some organic pads, I think the number id D-52 but it has been a long time.
Do not give back the cores untill the job is done and the brakes work as intended. This will help you to ID a problem if the parts are wrong in some way. JMO.
Hope this helps.
-Mark.
Old 10-11-2009, 08:27 AM   #3
Zieke
Camaro Deprived
Zieke's Avatar
thanks for the info Mark.
my dad and i have already replaced the master cylinder as well.
and the front rotors do need to be replaced. they're below min. thickness.
New! Retractable Front License Plate Frame/Holder! Hide your front license plate! RPI Designs Exterior Parts & Accessories 67 03-16-2013 07:19 AM
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 12:40 PM
New! Retractable Front License Plate Frame/Holder! Hide your front license plate! RPI Designs Exterior Parts & Accessories 8 03-24-2010 04:25 PM
Need Police Advice... FenwickHockey65 Off-topic Discussions 25 07-22-2009 03:13 AM
Pricing/optioning guesstimate KILLER74Z28 Camaro Price | Ordering | Tracking | Dealers Discussions 156 02-24-2008 04:33 PM
