Old 06-20-2008, 05:27 PM   #1
Shadowsong
Drives: 2014 Mustang
Will the v6 be Peg legged?
The mustang v6, is peg legged, meaning that only one of the rear wheels spins, you have to buy a T-loc and install it if you want power going to both wheels.
Will the Camaro v6 be like this?
Shadowsong is offline   Reply With Quote
Old 06-20-2008, 05:31 PM   #2
MAC
Iroc-Z <3'r
MAC's Avatar
Drives: '87 5.7L Iroc-Z
Yar matie!
lol i dunno really, i just couldnt resist..sorry..
"Camaro Z/28 is back. Gentlemen, Don't even bother to start your engines."
MAC is offline   Reply With Quote
Old 06-20-2008, 05:39 PM   #3
Blizzard
Searching for the truth
Blizzard's Avatar
Drives: 85 K-10, 13 1LE
Most likely we wont get a posi trac with the camaro.
2013 1LE 1SS RS TPW 4/29
Blizzard is offline   Reply With Quote
Old 06-20-2008, 06:55 PM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
actually, i believe we will, i feel that GM to save production costs will throw the same rear end (save for different gear ratios) in both the v-8 and v-6 models
I piss excellence
and fart awesomeness
Old 06-20-2008, 07:07 PM   #5
Blizzard
Blizzard's Avatar
Yeah I agree but it will be limited slip not posi trac. Posi trac is rare now days, but would love to have it tho. Just love having that rear end kick out hard when both wheels grip.
Old 06-20-2008, 07:45 PM   #6
CamaroSpike23
Truth Enforcer
posi trac and limited slip are the same....
gm first coined the positraction and positive traction terms, but it is just their way of referring to it.
I piss excellence
Old 06-20-2008, 07:50 PM   #7
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
I thought posi was chrysler and limited slip was GM. . .lol both the same thing but two totally different names for two different brands.
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 06-20-2008, 08:56 PM   #8
Blizzard
Blizzard's Avatar
Yes and no.
Yes GM did call their limited slip rear ends posi trac, but real posi trac is different from limited slip. True posi track has power to both wheels at all times where as limited slip transfers power from one wheel to another.
Old 06-20-2008, 09:11 PM   #9
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
If I were to guess, it will have the Eaton G80 locker as an option like they do on their trucks.
Sterling is offline   Reply With Quote
Old 06-20-2008, 09:14 PM   #10
CamaroSpike23
Truth Enforcer
Yes and no.
yes and no.
Theres 3 types of rears
You have the open rear (single wheel pulling)
posi/limited slip rear (both wheels, more power is sent to wheel with least amount of traction)
Locked rear. Theres quite a few forms of lockers. Each does the same, but made for diff useage. Like you have a full spool, mini spool. These are straight line type rears, that dont like to turn sharp.
Then theres the detroit locker, and now even more streetable lockers like the powertrax no slip, and lock right. It's a gear/teeth/spring set up that locks together on the straights or hard throttle, then unlocks around turns.
The locked rear gives the same torque to both wheels un like stock posi/limited slip rears
I piss excellence
Old 06-20-2008, 09:19 PM   #11
Blizzard
Blizzard's Avatar
yes and no.
Ahhhh now I see. Well I dont thin we will get any type of locking rear saddly.
Old 06-20-2008, 09:26 PM   #12
CamaroSpike23
Truth Enforcer
yeah, but thats easily overcome with a air locker posi from the aftermarket. or you could weld the spider gears... old school trick
I piss excellence
Old 06-20-2008, 10:53 PM   #13
Sterling
Sterling's Avatar
I don't know why they wouldn't offer the G80 locker if it is offered in some of it's other RWD vehicles as an option.
Old 06-20-2008, 10:57 PM   #14
1GTEC
1GTEC's Avatar
Drives: GMC Sierra
Torque management would probably kill most of the ability for the V6 to do burnouts anyways.
1GTEC is offline   Reply With Quote
