Old 10-12-2009, 12:49 PM   #1
Standard
Drives: 2010 ABM Camaro 2SS
Aftermarket Shifters - will any have "stops"?
I've had a B&M Ripper on my old LS1 from the start. Very useful piece of kit. One aspect was the peace of mind of having the adjustable "stops" that allegedly prevented overtravel.
I see that the shifter design is different on the 2010, and that there are some aftermarkets. Will such a design still be possible?
Tangent: How do the 2 I see available (MTI, Hurst) compare?
Standard is offline   Reply With Quote
Old 10-12-2009, 12:54 PM   #2
THUMPER20X
GM fix my PAINT U suck!
THUMPER20X's Avatar
Drives: 2010 Black 1SS/RS 6Spd
Im sure B&M will bring out the Ripper for them. Its what I had in the 93Z and I will wait till its released for this car.
THUMPER20X is offline   Reply With Quote
Old 10-12-2009, 01:39 PM   #3
subzero05
Drives: 2010 tbd
as of right now there are no plans to release a B&M unit for the car unless demand changes
subzero05 is offline   Reply With Quote
Old 10-12-2009, 04:01 PM   #4
clubbdawg
clubbdawg's Avatar
Drives: 2010 Camaro 2SS/RS - A6
Most modern manual transmissions have internal "stops" . . .
This is the case with the T-56 in my '95 mustang. I did not install the shifter's added stops (at the recommendation of MGW). If not set correctly, they may prevent the shifter from fully engaging resulting in abnormal gear wear or popping out of gear under hard acceleration.
I am no expert, but "stops" on newer shifters are more marketing than necessity.
Just my $0.02.
clubbdawg is offline   Reply With Quote
Old 10-12-2009, 08:50 PM   #5
Standard
Any confirmation of this in the 6-speed that is in the 2010 SS? That it specifically has internal stops?
That would help take away an issue/concern. . . .
Old 10-12-2009, 11:16 PM   #6
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
The tremec transmission does have internal stops. Its all been covered before. There are 3 or 4 aftermarket shifters currently out, one of them has stops I think its ripshift but not sure. It was mentioned in an old thread when a shifter was advertising their product. There is no need for them in this tranny, i have the hurst shifter and absolutely love it.
jpsuperman81 is offline   Reply With Quote
Old 10-12-2009, 11:26 PM   #7
subzero05
Drives: 2010 tbd
exactly what is said above. The tremec has internal stops built in.. There is NO need for shifter stops anymore.
Aftermarket Gauges and shifters? Blood Cosmetics and Lighting Modification Discussions 0 10-06-2009 10:20 PM
Aftermarket Exhausts Kinetic Kev HWSE 2013 USA - New England 1 10-01-2009 09:55 PM
Any word on the Hurst shifters? caverman V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 08-21-2009 04:48 PM
Aftermarket LT1/LS1 Camaro vs. Aftermarket Mustang GT MrCool 4th Generation Camaros 0 07-03-2009 11:04 PM
