Cold Air Inductions
Old 10-13-2009, 04:44 PM   #1
Bentley78
Rice Cooker
Bentley78's Avatar
Drives: Avalanche Z/71, 2010 Camaro2SS
Gearbox/Driveline noise???
After car has been sitting awhile, overnight, at work, when i first throttle up through the gears (manual) i hear a static or water/fuel noise somewhere under the console or gearbox, maybe even floor board.
Not sure if this is normal or not? Not coming from speakers as they are turned off and all wires in the console are unplugged. Even my wife could hear it. Anyone else getting this???
Bentley78 is offline   Reply With Quote
Old 10-13-2009, 04:59 PM   #2
kelleyperformance
kelleyperformance's Avatar
Drives: DD- 15' Chevy SS Sedan
its the heater core, theres a bulliten for it. take it to your dealer, its a half hour fix.
kelleyperformance is offline   Reply With Quote
Old 10-13-2009, 06:32 PM   #3
Infern0
Bring It
Infern0's Avatar
Drives: '17 Camaro ZL1 (M6)
Ahhh I bet you this fits perfectly in with this thread
http://www.camaro5.com/forums/showthread.php?t=30514
Is there a way to see these bulletins or do you have to be GM employee?
Infern0 is offline   Reply With Quote
Old 10-13-2009, 06:51 PM   #4
ffrcobra_65
one of 2 things or both.
#09-01-37-001: Gurgle Type Noise Coming from Instrument Panel (IP)/Heater Core Area (Perform Repair as Outlined) - (Jun 24, 2009)
this also sounds like rice krispies in milk. Noise coming from behind passenger side dash.
or
#09-01-38-003A: Moisture from Center HVAC Vent When A/C is On, Front and Back Floor Carpet Wet (Realign A/C Drain Tube) - (Aug 5, 2009)
This could be your problem. If the rubber drain tube (located above the tranny area) is pinched, condensation from the A/C can't drain and eventually, moisture spit from the air vents, wet driver side floor mats, and water slosh noise. You can easily do the test. next time you pull into the garage, leave the engine and A/C running and look under the car, you should see water droplets on the floor. If not, rubber drain tube is pinched. Take it to the dealer for easy fix.
Old 10-13-2009, 06:57 PM   #5
Infern0
Bring It
Infern0's Avatar
Ha that's also a perfect description, rice krispy noise haha. You have any further information on what about the heater core is causing that? Is something actually broken or damaging occurring or is it as simple as a rattling part? How did you pull that info?
Old 10-14-2009, 08:40 AM   #6
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
Look at the following link. The TSB is posted.
http://www.camaro5.com/forums/showthread.php?t=46740
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 10-14-2009, 09:53 AM   #7
Infern0
Bring It
Infern0's Avatar
Nice, Thanks!
Old 10-14-2009, 12:11 PM   #8
Bentley78
Rice Cooker
Bentley78's Avatar
Wow rice krispies, thats just what it sounds like, almost sounds like its coming from the floor board now.
2SS M6 Transmisson noise gtjacket 5th Gen Camaro SS LS LT General Discussions 15 12-16-2009 09:24 PM
ticking noise and high pitched hum strshp5 5th Gen Camaro SS LS LT General Discussions 13 10-21-2009 05:04 PM
QC missed something-- AC Compressor making a whining noise under engine load Kyle.Gilmour Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 10-09-2009 11:42 PM
Weird Air-Leaking noise... a_Username Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 09-03-2009 10:25 AM
ticking noise and high pitched hum strshp5 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-10-2009 10:09 AM
