Old 10-14-2009, 03:51 PM   #15
AdamCzap
AdamCzap's Avatar
Drives: '10 TT SS / '07 Escalade
Originally Posted by Longhorn SS View Post
Looks like they have some kind of extra heat shield inside the enclosure as well. Interesting. Wonder how effective that is? Any running vehicle temperature tests with and without that stuff?
Yes, the inside of the heat shield is lined with insulation! That's definitely an extra-mile type feature that performance minded individuals can appreciate :-).
During the install the temps were taken inside and outside the enclosure: they were getting 90 degrees Fahrenheit inside and 180 outside. That was WITH insulation.. no numbers w/o it. That was just at idle temps. The car was not moving. Obviously inside the enclosure should be lower when the car is driving down the road!
AdamCzap is offline   Reply With Quote
Old 10-14-2009, 03:52 PM   #16
futrocpd
P90X
futrocpd's Avatar
Drives: 2000 SLP SS VERT
probably either going to be this one or adm for me when i get mine. This looks really good. Will wait till sunday though for final judgment.
2000 Camaro SS/SLP
P90X changed my life. Want to know more, PM me for more info on changing your life for the better
futrocpd is offline   Reply With Quote
Old 10-14-2009, 04:01 PM   #17
4SD FED
4SD FED's Avatar
Drives: 2010 rs/ss camaro
The best part it also work with mpd1 cowl hood
4SD FED is offline   Reply With Quote
Old 10-14-2009, 04:29 PM   #18
Capstone
Capstone's Avatar
Drives: .
Another contender for the Jannetty Racing CAI bake-off??
I think so...
it's sharp looking.
Capstone is offline   Reply With Quote
Old 10-14-2009, 04:32 PM   #19
Abygale
Abygale's Avatar
Drives: .
It would be nice if they tested one on Sunday...that's for sure!
Abygale is offline   Reply With Quote
Old 10-14-2009, 04:34 PM   #20
AdamCzap
AdamCzap's Avatar
yeah, for sure! i think that is the plan, that's why they were so desperate to get me in to the shop; they had to have the instruction manual completed for the testing. hope the results are as good as the looks!
Old 10-14-2009, 04:50 PM   #21
4SD FED
4SD FED's Avatar
That also my understanding
Old 10-14-2009, 05:29 PM   #22
camarossrs2150
camarossrs2150's Avatar
Drives: abm2ssrs
we need numbers .we can post all day about cai but with no numbers nobody cares .
[SIGPIC]
camarossrs2150 is offline   Reply With Quote
Old 10-14-2009, 05:32 PM   #23
merlin803
merlin803's Avatar
Drives: 2016 Summit White Camaro 2SS
i have also offered up my car for them if they want to test it out on a V6 (which they indicated they may do within a couple of weeks)
merlin803 is offline   Reply With Quote
Old 10-14-2009, 05:55 PM   #24
thesnoopster
thesnoopster's Avatar
Drives: '10 SIM SS/A6 - '12 SIM Equinox LT
Nice looking CAI.....I like the see through top with the plexi.
2010 SIM Camaro 1SS/A6
Mods: "93 Octane and a baby seat..." TunedByFrost/EFI Performance,LLC @ PAS "You gotta love me ... or leave me alone"
Old 10-14-2009, 05:56 PM   #25
Longhorn SS
Longhorn SS's Avatar
Drives: 2010 IOM Camaro SSRS L99
Strange that they'd go to the effort (for performance sake) to insulate the box, then run a metal tube through the hot engine bay. Seems a conflict of interest between looks of metal and performance of plastic/insulation.
I am an engineer and generally thorough, but in this case I'm guilty of going straight for the pictures.
2010 Camaro 2SS/RS - Roto-Fab CAI, ARH 1-3/4" LTs w/cats, LMR tune, KW V3 coilovers, Pfadt F&R sway bars, end links, rear trailing arms, tie rods, solid subframe bushings, HPS brake pads
Longhorn SS is offline   Reply With Quote
Old 10-14-2009, 06:11 PM   #26
Dway
Drives: 2008 GMC Sierra 2500
Longhorn SS,
The CAI system goes above and beyond on the perfomance side of Intake systems - it builds its system around the coldest air possible going into your engine = creating more HP thus better performance! The custom air tight box keeps the hot air out allowing only the ambient air to flow into the system. The CAI intake tube is not the "normal" tube because they take the metal tube and ceramic coated to keep the air at ambient temperature. Thus this is why I found CAI to be the benchmark of intake systems vs everyone else. I love my system on my 08 Duramax and will get one when I order my camaro!
Steve
Dway is offline   Reply With Quote
Old 10-14-2009, 06:13 PM   #27
Eric-MPD1.com
Drives: Cool parts for cool cars
I would think a ceramic coated aluminum tube would do a great job of staying cooler than plastic.
And yes it is designed to work with our cowl induction and L88 style hoods. The MPD version will be offered with the correct hood to airbox seal.
Eric-MPD1.com is offline   Reply With Quote
Old 10-14-2009, 06:43 PM   #28
ShadowSky
ShadowSky's Avatar
Drives: 97 Z28,92 25th RS, 91 LX,82 GT
I don't have any. Talk to James! I do know that the other intakes they've made for their other non-camaro customers have got some great gains. I would expect this to be in line with pretty much all the others out there.. probably 12-20hp w/o a tune, maybe a little more w/ tune. It's pretty dang awesome looking to boot! :-)
Thanks For helping us out Adam.
We're happy that you like it.
Sky
Boost Or Die!!!
82 gt
92 25 anny RS
among others
ShadowSky is offline   Reply With Quote
cai, cai shootout, cold air intake, custom, michigan
Fastlane Pipeline Cold Air Intake Fastlane V8 Bolt-Ons & Tunes 24 01-12-2010 10:35 AM
BAD BOY POWER -Programer Plus Cold Air – Do it yourself $699 BADBLACKSS V8 Bolt-Ons & Tunes 4 09-29-2009 01:23 PM
LMR Cold Air Intake & Phastek Performance - now available to order Online Sean@Phastek Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 09-17-2009 03:05 PM
Cold Air Intake and Grille AirmanSal Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 5 09-16-2009 11:14 AM
Cold Air Intake xsofa 4th Generation Camaros 2 08-13-2009 06:40 AM
