Classic Industries
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 06-23-2008, 04:13 PM   #1
carsismeZ06
Corvette and Camaro lover
carsismeZ06's Avatar
Drives: 2010 Camaro...some day...
Camaro Top Speed
I was thinking today, and while looking around at the different engine choices, a thought popped up into my head. What will the Camaro's top speed and 0-60 time be like? In the LS2 powered Corvette, you can get 186 mph, and a 0-60 time of 4.2 seconds. (maybe quicker if you really nail it) with the added weight of a Camaro, I'm thinking that you can get up and over 180 mph (180-185) and a 0-60 time of 4.5. Not bad if you ask me. That is also a tad bit better than the HEMI 6.2 liter V8, which powers the Challenger up to 174 mph, and a 0-60 time of 4.5. Just throwing this out there, tell me what you think.
carsismeZ06 is offline   Reply With Quote
Old 06-23-2008, 04:31 PM   #2
Mythic
Mythic's Avatar
Drives: '03 Monte Carlo SS
Its not just weight, its aerodynamics. The Vette simpply moves through the air better than the Camaro will.
However, if we have made any impression on GM we will get a 430hp 6.2L V8 to play with. If we are really good and eat all our vegetables we might get a 550hp s/c V8. If so Im sure that is neighborhood the Camaro will be trolling through.
Mythic is offline   Reply With Quote
Old 06-23-2008, 04:46 PM   #3
Camo_Soldier
Future 2009 Z/28 Owner
Drives: 1993 Mustang Cobra
Alot of companys like dodge and ford have figured out how to get the same type of aerodynamics with a box style body as the rounder body cars, the handling is different.
Camo_Soldier is offline   Reply With Quote
Old 06-23-2008, 05:03 PM   #4
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
At those speeds, aerodynamic drag is pretty much the only factor for top speed. Even the tiniest difference in aerodynamics will make a big difference in top speed at that level.
I'd guess that the Camaro's top speed will be electronically limited before 186. They won't ship it able to exceed the speed rating of whatever tires come on it, though maybe uplevel Camaros will come with high-rated tires.
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 06-23-2008, 06:11 PM   #5
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
predicting 4.3-4.5 0-60 top speed of 160 (electronicly limited) and 1/4 time in the mid to low 12's on street tires and possibly high 11's on slicks. that's for the LS3. Now if we get a 550 hp version I'm going to say 4.0-4.3 0-60 and a mid 11 sec 1/4 run. as for the electronicly limited top speed I'd say it'd be the same if not a little lighter. All those times are at sea level and with a manual. now I predict motortrend to be a few tenths off on everything I've stated because they don't beat the cars like they should be to perform the best they can.
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 06-23-2008, 06:14 PM   #6
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2012 Camaro ZL1
Some expect the V6 to be a 160mph car, and the base V8 to be capable of 175+.
I agree with those people. Whether they're speed limited is a different story.
"Keep the faith." - - Read Before You Post.
Old 06-23-2008, 06:51 PM   #7
carsismeZ06
I agree, 160 for V6, bae V8 = 175+
Old 06-23-2008, 06:54 PM   #8
smokn'
smokn''s Avatar
Drives: 2006 GTO
4.4 & 185
"Preach the gospel at all times--If necessary use words" - Francis of Assisi
"To the honda owners: could of had a V8!"
smokn' is offline   Reply With Quote
Old 06-23-2008, 08:06 PM   #9
ihc95
ihc95's Avatar
Drives: 2007 Lexus RX350
Tires should not be an issue. As we saw in the spyshots, the base V8 will likely have fat Pirelli PZero tires, the same used on 215mph Lambos. Oh and realisticly, the V6's top speed will probably be around 150mph. Though the base V8 should get to 175+mph
ihc95 is offline   Reply With Quote
Old 06-23-2008, 08:28 PM   #10
theholycow
theholycow's Avatar
Well, that ought to be enough to get me to work on time.
Old 06-24-2008, 12:50 AM   #11
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: THRSS #2 / CGM#1
I'd bet anything that the V6 has a speed limiter on it like the V8. I personally don't think they'll let it go over 120.
The build of THRSS #2
Old 06-24-2008, 01:40 AM   #12
boxmonkeyracing
juggernaut
I agree a speed limiter will be used but I'd say it's closer to 150-160.
Old 06-24-2008, 08:08 AM   #13
theholycow
theholycow's Avatar
They've got to give it more than 120. Even this dinky little thing is good for 130:
Old 06-24-2008, 09:50 AM   #14
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
as per mr FbodFather: class leading performance.
Quote: In 2014 the camaro will have ... a twin turbo v6 ... around 350 to 360HP
No. Let me repeat that. No. FbodFather
Camaro5 Fest III Information
Camaro5 Fest III pre-registration
DGthe3 is online now   Reply With Quote
Old 06-24-2008, 09:52 AM   #15
BumbleBee
Yes, I am a girl
BumbleBee's Avatar
Drives: 2006 Pontiac Vibe
+1
My base Vibe can do 115, but the GT I believe can get up around 130.
You can check on the rep...
...second to none
BumbleBee is offline   Reply With Quote
Old 06-24-2008, 10:56 AM   #16
carsismeZ06
Originally Posted by smokn' View Post
4.4 & 185
I want nothing short of that.
Old 06-24-2008, 09:53 PM   #17
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
My guess is the V6 will go 0-60 in about 5.3-5.5, base V8 (assume LS3) 4.5-4.8, and hi-po V8 (LSA) 4.0-4.3. I would also guess the V6 will be limited to 140-150, base V8 to 160, and top dog to be unrestricted and hit 175, similar to the Challenger SRT8.
stovt001 is offline   Reply With Quote
Old 06-24-2008, 10:20 PM   #18
Mr. Wyndham
Shouldn't you shift Camaro forwards a little? I mean by comparing the base V8's top speed to that of the SRT Challenger. Those will share the most similar power outputs...which puts the "Top Dog" Camaro in the upper 180s as far as speed is concerned.
Old 06-25-2008, 09:09 AM   #19
Dan
Dan's Avatar
Drives: 2004 GTO
I would think the v6 will have H rated tires to keep costs down so it will be limited to around 125.
Dan is offline   Reply With Quote
Old 06-25-2008, 10:14 AM   #20
shadowed_Stranger
WAITING!
Drives: 97 V6 5spd
2 second 0-60 and 750mph top speed in jet fighter/camaro hybrid mode.
Originally Posted by Nine Ball View Post
Telling Camaro owners to do the speed limit is a lot like telling a room full of straight men to kiss boys.
Originally Posted by C P View Post
I'll go ahead and say it... how could GM let this happen? They have 5 years to develop the new Camaro and no force field to protect from uninsured drivers???? I'm buying a Honda.
shadowed_Stranger is offline   Reply With Quote
Old 06-25-2008, 10:48 AM   #21
theholycow
theholycow's Avatar
Old 06-25-2008, 10:58 AM   #22
AZCamaroFan
couteau dans le dos
AZCamaroFan's Avatar
Drives: yes
I'm sure interested in what the coefficient of drag is on the car.
Old 06-25-2008, 12:17 PM   #23
boxmonkeyracing
juggernaut
where's the other tail? that's an f-15 isn't it? sure doesn't look like a 16 or 18. . .hmmm
Old 06-25-2008, 12:22 PM   #24
carsismeZ06
Yeah, there should be two vertical wings. In fact the only plane in use by the air force today that has a single verticle wing is the F-16.
Old 06-25-2008, 01:41 PM   #25
theholycow
theholycow's Avatar
It was an F-15, but I couldn't fit the other tail on in a reasonable way.
I am the photoshop master, no?
Camaro Product Manager - interview Moose 5th Gen Camaro SS LS LT General Discussions 11 04-04-2012 06:10 PM
Pedders is Ready for Camaro!!! Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 10 04-15-2009 11:26 PM
Q&A with fbodfather (Scott Settlemire) regarding upcoming Camaro JustinZS 5th Gen Camaro SS LS LT General Discussions 22 05-20-2008 07:48 PM
10 coolest cars on film Camaro in top ten KILLER74Z28 Camaro Photos | Spyshots | Video | Media Gallery 26 05-15-2008 10:52 AM
