Old 10-15-2009, 09:35 AM   #1
fsuredneck
fsuredneck's Avatar
Drives: 2007 Ford Mustang
Roof Ditch Molding
How expensive/hard would it be to have the roof ditch molding painted professionally (to look factory), if can even be done? Thanks.
fsuredneck is offline   Reply With Quote
Old 10-15-2009, 09:41 AM   #2
ottobody
Drives: 2010 trans am/camaro
not sure whatyou meanby painted to factory?
ottobody is offline   Reply With Quote
Old 10-15-2009, 09:43 AM   #3
jrpxxii
jrpxxii's Avatar
I'm sure he means to match the paint as the factory RS cars do with the moldings. I would imagine that this would be very simple do for a qualified painter.
Old 10-15-2009, 09:46 AM   #4
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
The thing to remember though that is rubber/something like it. It will expand and contract and keeping the paint sticking will not be easy. You may have cracking down the years. Someone needs to make them molded in the cars colors and not just painted.
Scott@Bjorn3D is offline   Reply With Quote
Old 10-15-2009, 11:51 AM   #5
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: 2010 2LT RS 2G1FC1EV4A9103434
I am checking with gmpartsdirect.com if there is a part # for the roof ditch molding in factory colors - I'll post what they say...
Update - here's what http://www.gmpartsdirect.com customer service said:
"GM Part #92225861 Roof panel joint finish molding; 2 per vehicle. Item callout number 17 in the accompanying illustration. This is for cars with the Rally Sport (RPO WRS) option. GM Part #92217614 is for cars without the RS Package. Neither mention anything about colors. These are the only roof panel joint moldings used on the 2010 Camaro"
Both Part #s are List Price is $34.69 each / Discount price is $21.29 each.
As the they look-up by VIN #, and I have an RS, and I assume as the VIN doesn't have the color as part of that code then this is probably the black roof ditch molding pre-painted even though its for an RS as there was no color mentioned per customer service If so then you're back to having it painted at a body shop. Given how inexpensive the part is perhaps its best to order 2 to take to a shop then swamp out the originals... just a thought.
http://www.hubgarage.com/mygarage/tjd24 http://ny5thgen.com/TJD_RS.htm
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 & booked for #5
tjd24 is offline   Reply With Quote
Old 10-15-2009, 05:02 PM   #6
jrpxxii
jrpxxii's Avatar
You can order the actual molding from GM in the color you want. The only thing you need is a VIN from a car of your same color with the RS package.
Old 10-15-2009, 10:38 PM   #7
tjd24
tjd24's Avatar
gmpartdirect indicated there was no color choice on the part #s they gave me in my post below yours. The VIN has no color designator unless the VIN provides a link to the car's color somehow.
I'd contact Dave in Parts at CamaroScotty's Newman Chevy to see what he says - dhiller@north2newman.com
Old 10-15-2009, 10:43 PM   #8
jrpxxii
jrpxxii's Avatar
All you have to do is go to the link on this site where you track registered VIN numbers and find one that is the color of your car that has the RS option and take that VIN to your local dealer and order the moldings and they will come in the color of the registered VIN. What color are you needing and I will get you the part number with your specific color.
Old 10-16-2009, 01:33 AM   #9
SummoneR
Paul
SummoneR's Avatar
Correct, though color is not a part of the VIN itself, the VIN is registered with everything the car has including color, so they pull the color from that as jrpxxii states.
Old 02-24-2013, 04:21 PM   #10
louis*sweetlou
Drives: 2013 1lt rally yellow
roof ditch moulding
Has anyone been able to order a painted one.
louis*sweetlou is offline   Reply With Quote
Old 02-24-2013, 11:52 PM   #11
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
They are black only. They are painted with the car.
Perm-a-grin in place.....
JimE is offline   Reply With Quote
Roof Ditch molding starting to bend up Crowley Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 07-17-2009 04:50 PM
paint ditch molding? imoldfella Cosmetics and Lighting Modification Discussions 0 06-30-2009 01:14 AM
Roof Ditch Cracks on RS Package? CarbonFiberSS-RS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 17 06-27-2009 10:58 PM
Roof Ditch Molding ColoradoCamaro 5th Gen Camaro SS LS LT General Discussions 5 03-28-2009 12:27 PM
Black Ditch Molding? francone13 5th Gen Camaro SS LS LT General Discussions 15 01-04-2009 03:59 PM
