Emblempros
Forced Induction - V6 V6 Supercharger, turbo, nitrous discussions
Old 10-16-2009, 06:48 PM   #1
chadsim93
Drives: 2010 Camaro 1LT RS
Twin turbo for the 2010 V6 Camaro
Just saw the SCAP’s twin turbo for the V6 Camaro. And there's no prices yet. You guys got any guesses.
chadsim93 is offline   Reply With Quote
Old 10-16-2009, 06:53 PM   #2
tones2SS
tones2SS's Avatar
Drives: 13 Roush S3 05 Dodge Ram Daytona
Thumbs up
I would get in contact with Turbonetics. They are the company making the turbos for the V6. And, they make a killer turbo!!
GOOD LUCK!
Old 10-16-2009, 08:13 PM   #3
Kaze10
Drives: 2006 Dodge Charger R/T
will it be cheaper to go with Twin Turbo or Supercharger on the V6?
Kaze10 is offline   Reply With Quote
Old 10-16-2009, 08:32 PM   #4
Morepwr
woohoo
Morepwr's Avatar
Drives: Silverado, 70cutlass, 57chevy&more
Screw prices, I want dyno results!
I am not useless, I can still be used as a bad example!
Morepwr is offline   Reply With Quote
Old 10-16-2009, 08:40 PM   #5
chadsim93
Yeah i was wondering the same thing.
Old 10-16-2009, 09:20 PM   #6
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
I would think a supercharger would be cheaper. With the turbo setup you would have the two turbos and the special exhaust manifolds feeding them. With a supercharger it would probably be a setup like vortechs.
9/26/09 Took delivery!
Old 10-17-2009, 07:05 AM   #7
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
In general turbo kits are usually more expensive than supercharger kits. Twin turbos even more....
Other thing to remember... things that show up at SEMA don't necessarily make it to market...
scrming is offline   Reply With Quote
Old 10-19-2009, 12:34 AM   #8
Jlpinc4y
Drives: 2010 Camaro 2LT RS
Might be a stupid question, but what is the difference between a supercharger kit and a turbo kit?
Jlpinc4y is offline   Reply With Quote
Old 10-19-2009, 12:45 AM   #9
fredbo
Drives: black 2010 LS
im thinkin a twin turbo should put it @ around 500 rwhp
fredbo is offline   Reply With Quote
Old 12-07-2009, 03:05 PM   #10
Legend17
Army Bound
Legend17's Avatar
Drives: 97 Camaro RS
why twin turbo these engines? one turbo is more than capable of powering it. am i missing something?
Legend17 is offline   Reply With Quote
Old 12-07-2009, 03:35 PM   #11
general23cmp
Drives: 2010 RS SS
Wow! How much boost you planning on running to get that?
general23cmp is offline   Reply With Quote
Old 12-07-2009, 04:10 PM   #12
mrray13
mrray13's Avatar
Drives: 2010 1LT RS Rally Yellow
Sheer basics here...
supercharger is belt driven. Takes horsepower to make horsepower, however it's instant! Foot on gas, back in seat!
turbocharger is exhaust driven. Free horsepower as it takes waste gases to spool a turbine and compress air the way a supercharger does. Depending on turbo, one might get lag, as the turbo can only spool when you are on the gas, and it takes a moment. Between new vane designs and ball bearings, amongst other things, turbo lag is all but a thing of the past.
Supercharges can be cheaper due to the fact that depending upon style , centrifigual or roots,and boost, all one has to do is change intake plumbing and belt. Turbo's require new exhaust manifolds and intake plumbing, in the bare minimum.
PacMan
mrray13 is offline   Reply With Quote
Old 12-07-2009, 04:11 PM   #13
Mosher
Mosher's Avatar
Drives: 1LT Cruze Summit White
I was thinking the same thing. Seems weird with Twin turbos, but most of the time when this happens from the factory it's discarded in favor of a single turbo setup. While the 3.6L is not a real big engine, I would think it would push a decent size turbo and probably make enough streetable power for most anyone
Mosher is offline   Reply With Quote
Old 12-07-2009, 05:36 PM   #14
Exotic Performance Plus
Exotic Performance Plus's Avatar
Drives: 1999 Camaro Z28
Two smaller turbos can sometimes spool faster than one larger turbo. I wonder what they are doing to tune the car. Bob
Exotic Performance Plus is offline   Reply With Quote
Old 12-08-2009, 10:19 AM   #15
matt55
matt55's Avatar
Drives: 2010 SS AMB , mini revo
V6's dyno at 250ish WHP (304 hp)
To get 500 WHP(608 hp) you should need at least 15psi
Thats asking alot of that motor with such a high C/R on pump gas .
Vararam , OBX LTs.
matt55 is offline   Reply With Quote
Old 12-08-2009, 11:30 AM   #16
Mike@DS
Drives: 99 Z28
Lets not forget that pump gas is being delivered via direct injection....whole new ballgame.
Mike@DS is offline   Reply With Quote
Old 12-08-2009, 12:45 PM   #17
Z_Rocks
Drives: a Jet :-)
Mike, is it true that DI cars are more difficult to tune? From what I've read, the next LS engine for Corvettes and Camaros will be DI with more power and more efficient, and perhaps smaller CC. I wonder how that will affect the tuners?
Z_Rocks is offline   Reply With Quote
Old 12-08-2009, 11:53 PM   #18
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
turbo's aren't free HP from exhaust. It still "robs" HP, just not nearly the amount a SC does. But turbo's usually bring on a whole set of problems as well such as the heat they generate. And they can be more finicky and can require more maintenence.
THE EVIL TW1N is offline   Reply With Quote
Old 12-09-2009, 12:00 PM   #19
MIAPLAYA
Drives: cHEVY
On what turbo? Bost pressure is subjective. 15 PSI on a 88 mm compressor is not the same as 15 PSI on a TD04. for example the SS makes what 350 to the wheels give or take? At 9 PSI turbonetics is making ~650 HP with a 61mm compressor. My 350Z made 234 WHP stock. At 8 PSI on a 60-1 compressor I made 379 WHP on pump gas. I wouldn't be so quick to say you need 15 PSI and call it that. It will depend on the system design and the compressor used in the system.
MIAPLAYA is offline   Reply With Quote
Old 12-09-2009, 02:14 PM   #20
MIAPLAYA
Drives: cHEVY
Can you expand on this a bit more? Turbochargers actually are close to 100% efficient as they utilize exhaust gas spent during the combusting cycle and convert that waste energy which would otherwise by expelled from the tail pipe into additional power by driving a compressor wheel on the cold side. This in definition alone means a turbocharger does not have parasitic loss. The energy used to drive a supercharger is the same energy used to turn the crankshaft meaning the supercharger is a parastic power draw using some of the existing power to spin the screws. The exhaust gas exiting the manifolds and leaving the tail pipe is not used for ANYTHING therefore it being used to turn the turbine wheel and compressor wheel results in wasted energy being converted to more horsepower or zero parasitic loss. Also modern turbochargers are quiet reliable and do not necessarily require "more maintenance". Any car with forced induction should have oil changes done very often (3,000 miles is my preference) and routine inspection of the equipment used regardless of supercharger or turbocharger. There is nothing special neeeded for turbos here. In regards to heat modern turbos are typically watercooled and do not add significant heat especially when ceramic coating is used.
Old 12-09-2009, 02:57 PM   #21
Z_Rocks
Drives: a Jet :-)
I think what he means by loss of energy, is the back pressure related to having the turbo charger and preventing the exhaust to free flow through the pipes. I agree with this to some minute extend. However, having proper Turbo size and ball bearing, can eliminate this back pressure to a large extend. Secondly, the further away the turbo is from the exhaust manifold, the less of back pressure problem you would encounter. When adding Turbo, the best thing is to replace the stock CATs with High Flow Cats and replace "Chambered" mufflers with straight through mufflers, and you barely loose any power due to back pressure. In Turbo system, you want to have the least amount of blockage after the hot side, to get the gas pass through the turbo as fast as possible. My two cents!
Old 12-09-2009, 03:23 PM   #22
MIAPLAYA
Drives: cHEVY
You have a point here and are absolutely correct. A properlly sized turbocharger shoudl result in little to no added backpressure especially if you have a high flowing turbine wheel and relatively open exhaust before and after the turbine section. That's why I mentioned in my post that turbos are almost 100% efficient. The only reduction from 100% is the amount removed for any backpressure presented to the engine. With a properlly set up turbocharger system and the correct size wheel and housing this should be no issue. One could argue that with a perfectly match combination of turbine wheel, housing, and ehxaust system you could present a near zero increase in backpressure. Compare this with a supercharger where you are guranteed to have parasitic loss though. No matter how free flowing the ehxaust system is you will have parasitic loss from a supercharger.
Old 12-09-2009, 07:07 PM   #23
matt55
matt55's Avatar
A properly sized one .......
Big turbo VS small turbo , yes bigger is more efficient so you get a cooler charge, less back presure and can tune accordingly , but who is going to strap an 88mm on a stock 3.6 ?
Turbonetics made 650 Whp ? or 650 flywheel HP , Ive not seen it in the thread .
Lets play a game , lets say to X 2 WHP you need X 2 the atmosphere , 14.7psi
I would say to go from 234 to 379 you need about 9 psi
234 whp(your stock) X 1.62 = 379whp (with turbo 8 psi , tune , exhaust?)
14.7psi (1bar , an atmosphere at sea level) X 1.62 = 9.1psi ("-" 14.7psi for the atosphere)
Pretty close huh ? and if your stock #'s had a tune and was 240whp and 8psi it would come up with 377 whp . a 54% gain or 54% X 14.7psi = 8psi
So I still say to get +500WHP on a stock Camaro 3.6 DI you need at least 15psi or close to it , +/- , you milage mat vary , no $ back guarantee , dang its close enough for the internet
Vararam , OBX LTs.
Old 12-09-2009, 07:34 PM   #24
Toastylicious
My car goes Vrooom.. You?
Toastylicious's Avatar
Drives: 2010 Rally Yellow Camaro LS
This might be a dumb question but which 1 would be safer for the engine a turbo set up or a supercharger.
Toastylicious is offline   Reply With Quote
Old 12-09-2009, 07:54 PM   #25
GEIST LS9
An Evil Automotive Genius
Drives: 2003 Mercury Sable GS
TWO WORDS:TURBO LAG,
as with a single turbo it'll take a while for the air to spool the turbo which causes a lag or space of time between you putting your foot to the carpet and the power comming to bear.
a twin turbo setup can allievate this by usually having two small trubos which take less time to spool and one turbo can spool the other therefore creating a more instantanious power response
you can use a compound boost setup which involves usually 1-2 turbos feeding into a supercharger like Hellion does with the GT500 AND SVT Cobra kits.this has several advantages like adding more low end torque
GEIST LS9 is offline   Reply With Quote
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 79 03-04-2013 09:25 AM
Does the v6 have enough power? cstproductions Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 305 08-29-2012 09:27 PM
New Zex 2010 Camaro V6 Nitrous Kit - intro and free shipping @ PFYC.com Redshift Forced Induction 0 07-16-2009 08:31 AM
2010 Camaro, Decisions Decisions… (Winding Road Review) Xmicro_SS 5th Gen Camaro SS LS LT General Discussions 19 05-09-2009 11:40 AM
