HeadlightArmor
Old 10-16-2009, 11:30 PM   #1
Tomato
G-Force Addict
Tomato's Avatar
Drives: 2010 SS/RS A6
Anyone Installed an Old Fashioned Shift Kit in the A6???
A tune would be easy, but common sense says that you risk losing your warranty. That said, an old fashioned shift kit installed inside the transmission may be a good way to go to increase line pressure and get firmer, quicker shifts.
I've never been inside one of these new ones - can it be done? Does anyone sell them?
If something blew inside the trans, it would be easy to take out...
Tomato is offline   Reply With Quote
Old 10-17-2009, 12:03 AM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
there are no aftermarket parts yet for the 6L80e(besides converters),, only clutch/seal kits, shift feel and pressures changed with a tune
Old 10-17-2009, 01:14 AM   #3
Xanthos
Almost-Original Postwhore
Xanthos's Avatar
Drives: Stick
In short, generic shift kits probably won't work.
- X
Xanthos is offline   Reply With Quote
Old 10-17-2009, 10:19 AM   #4
Fast vette
Fast vette's Avatar
Drives: 2SS IOM M6, 71 ElCamino, 00 Sierra
I was told by a GM tech that the new tranny's don't have a valve body anymore, all solenoid controlled, therefore probably easily done through ECU.
Fast vette is offline   Reply With Quote
Old 10-19-2009, 09:06 PM   #5
95_9C1
95_9C1's Avatar
Drives: Pontiac G8 GXP
TransGo info/research into 6L80E
click: http://forums.corvetteforum.com/c6-t...-research.html
95_9C1 is offline   Reply With Quote
Old 10-19-2009, 10:55 PM   #6
Tomato
G-Force Addict
Tomato's Avatar
No valve body? Interesting...I need to get a look inside on of these things.
A tune would indeed be an easy way to go, but I'm one of those that is paranoid about my warranty.
Old 05-12-2010, 10:12 PM   #7
CAP'N B
Cajun Mariner
CAP'N B's Avatar
Drives: 10 Camaro SS/RS RJT 99 Silverado
Send a message via Yahoo to CAP'N B
I don't know about the 6L80 E but I have a shift kit in a 4L60E that was built by Finish Line Transmissions it really shifts hard, the line pressure I never touched in the tune but i did decrease the shift time to .10 of a second, it really snaps you back and will chirp the tires even if not really getting on it hard
'10 Camaro 2SS/RS Red Jewel L99/A6
'15Camaro Z/28 Ashen Gray
CAP'N B is offline   Reply With Quote
Group Buy - Turbo Kit ZZcamaro Forced Induction 32 11-30-2009 01:52 PM
Official $5999 Ultimate Performance Single Turbo kit for sale thread. JTinFL Forced Induction 30 10-21-2009 07:43 PM
DSE 2010 Camaro Suspension Installed, Awesome!! dan@swift Suspension / Chassis / Brakes 21 10-19-2009 09:12 AM
New Billet Aluminum Shift Knobs Barton Industries Interior Parts & Accessories 15 10-09-2009 10:13 PM
