JUICEDMOTORSPORTS
Old 10-17-2009, 11:42 AM   #1
Bigred1981
Drives: 2LT Red Jewel Coat 6sp
Loud noise/grinding from rear end
Recently got a Camaro V6 RS the car has only 100 miles on it driving thru town and I'm hearing a loud grinding noise from the rear end in 1st gear. Any thoughts--the tires are fine and it doesn't happen every time
Bigred1981 is offline   Reply With Quote
Old 10-17-2009, 12:07 PM   #2
hamidar05
Drives: 10 Camaro/69 Bronco/08 Mazda3
Parking brake off?
Check brake rotors, look for any leaks, look at your dog bones. Feel your rear end parts and see if any are hotter than others (friction).
Brakes, bearings or gears...
Take it back to where you got it ASAP and have them look at it...
Selection Worksheet - 04/27/09
3300 - 08/03/09
6000 - 08/25/09
VIN# 34612
Bitchin Camaro - Dead Milkmen - http://www.newgrounds.com/portal/view/8092
Thank You Oshawa - Domo arigato Mr. Roboto
~1600 mi so far - 07/18/10
hamidar05 is offline   Reply With Quote
Old 01-17-2010, 01:34 AM   #3
sixty9fordkiller
bowtie junkie
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
if its nothing that was mentioned in the previous post, i think there is a TSB about an exhaust heat shield rubbing on the driveshaft or something. you might wanna check that out
sixty9fordkiller is offline   Reply With Quote
Old 01-24-2010, 10:49 PM   #4
daveprimo
daveprimo's Avatar
Drives: 2010 Camaro 2LT
your probably tagged for for tires. Same shit happened to me and someone else as well. Got in car and front left was making the worst grinding noise so I parked the car and was taking it in to the shop the next day to see whats up and bam... car was on blocks and wheels gone. They wedge rocks between the rotor and plate behind it I would assume so its parked for their taking.. careful bro
daveprimo is offline   Reply With Quote
We need help with Electronics wiring diagrams 2SSRS@Gen5diy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 12-13-2009 06:58 PM
Bang from my rear end Black5thgen V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 10-04-2009 11:21 PM
Rear end gear 3.73 - where to buy? rpepka V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 67 09-17-2009 06:23 PM
Rear end whine while under load shiftz33 5th Gen Camaro SS LS LT General Discussions 4 08-12-2009 05:15 PM
