HURST
Old 12-27-2016, 04:28 PM   #15
ABADZL1
ZL1 Pilot
ABADZL1's Avatar
Drives: 2013 ZL1
Do not cut the boot off. It's high temp stuff obviously. Mine has been touching the header for well over a year and hasn't melted nor shown any signs of wear.
GP Tuning 2.5 Cam, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners
Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs
ABADZL1 is offline   Reply With Quote
Old 12-27-2016, 04:58 PM   #16
runyonwc
Drives: 2013 ZL1
Thanks for the heads up!!!
runyonwc is offline   Reply With Quote
Old 12-28-2017, 08:44 AM   #17
Triple5even813
Learner of things
Drives: 2013 ZL1 M6 coupe, black
I have heard lots of different things about steering boot & LTH install problem. When I do mine in the next couple of months, If there is an issue with clearance, what I might try is to wrap the boot with a layer of heat shield cloth like welders and plumbers use for welding and soldering, and tie it up with stainless baling wire or something. This will prevent contamination of the u-joint inside the boot, while solving the problem of possible melting.
Hopefully there is no clearance issue and I don't have to worry about it at all.
Triple5even813 is offline   Reply With Quote
Old 12-28-2017, 12:27 PM   #18
zman1969
zman1969's Avatar
Drives: 1969 R/S Z28 302 m20 Endura
Originally Posted by ram360 View Post
You need to make adjustments in the tune since you have no rear 02 sensors, etc. Yes that is normal and to be expected. Some headers have a clearance issue with the boot and you can cut that off. Mine had no issues with it in place. You prob lost 1-2psi of boost with the headers. With tuning you will prob pick up 10-20hp after it's all said and done.
Is that all LT headers will add to a ZL1?
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone
2015 Zl1
zman1969 is online now   Reply With Quote
Old 12-28-2017, 01:02 PM   #19
JB'sZL1
Drives: 2013 ZL1
Well...that's the simple calculus when done in isolation.
LT's are necessary when doing a cam and other mods, and then add, or will facilitate much more power.
JB'sZL1 is offline   Reply With Quote
Old 12-28-2017, 03:41 PM   #20
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Ditto, I cut mine because it was touching and I have Ceramic coated tubes and now realize it wasn't necessary.
ZMEnow is offline   Reply With Quote
