HeadlightArmor
Old 10-18-2009, 10:50 AM   #1
hamidar05
Drives: 10 Camaro/69 Bronco/08 Mazda3
1st Oil Change and 15mm!
So I did my first oil change at 955 miles...
I'd say I did not drive the car hard, but an occasional spirited acceleration, but always already moving at a clip.
So I get the car on jacks in the front and I see the oil pans lowest point is probably a bit behind the drain plug.. so you know there is a bit still in there... I proceed.
15mm! The damn drain pug on my 'American' muscle is metric.. ugh... I proceed. Below is the green drain pan... 955 miles, looks like I drove 5000... and there were metal shavings in there. Can't really see in my crappy pics, but the glint was unmistakable. Needless to say, don't go the full 5000 miles before your first oil change.. Mine is getting another one at 3000....
Selection Worksheet - 04/27/09
3300 - 08/03/09
6000 - 08/25/09
VIN# 34612
Bitchin Camaro - Dead Milkmen - http://www.newgrounds.com/portal/view/8092
Thank You Oshawa - Domo arigato Mr. Roboto
~1600 mi so far - 07/18/10
hamidar05 is offline   Reply With Quote
Old 10-18-2009, 07:46 PM   #2
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
I continue to tell people that is a good idea to change it before 1k. Some people say that is what the filter is for...
I did my $42 Pennzoil Platinum and Mobil1 filter change at 890 miles, then again at 2900..then when the DIC tells me I have 15% left.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 10-19-2009, 12:44 AM   #3
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
My plan is to change the oil the first time at 500 miles, then again at 1500, 3000, and every 3000 thereafter.
May be a bit overkill, but I'd rather be safe than sorry.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 10-19-2009, 07:13 AM   #4
Camaro Chic
Camaro Chic's Avatar
Drives: Soon BumbleB:) GCO SS/RS
Send a message via AIM to Camaro Chic
Same thing we are doing. We just changed ours at the 500 hundred mark and there were shavings in the drain bucket even though the oil still looked yellowish new. With filter cut open there were shavings as well. So next stop is 1000, 1500 and then every 3000 no matter what the oil life indicator says.
0000: 08/20/09 (order placed with dealer) Red River Motor Co.
1100: 08/20/09 (preliminary order accepted) #NNNHNG
2000: 08/25/09 (order accepted by GM)
3000: 08/31/09 (order accepted by production control) TPW: 09/21/09
3300: 09/12/09 (order scheduled for production)
3400: 09/16/09 (order broadcast)
3800: 09/24/09 (order produced) VIN # 9310
4000: 09/25/09 (available to ship)
4200: 09/28/09 (shipped)
5000: 10/03/09 (delivered to dealership)
6000: 10/05/09 (delivered to customer)
Rally Yellow(GCO) SS/RS
Camaro Chic is offline   Reply With Quote
oil drain plug magnetic same as camarossrs2150 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 6 06-29-2009 12:27 PM
