Old 11-04-2009, 04:33 PM   #15
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
It's new, so I could only order it direct from Hurst. Part #1630410. Here's a link to it:
http://www.hurst-shifters.com/s.nl?s...addtocart.y=21
Currently in the fleet... 2014 Cadillac CTS-V, 2010 Camaro SS single turbo, 2006 Chevrolet 2500HD Duramax, 1967 Camaro SS350, 1969 Camaro SS427.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
FrankT is offline   Reply With Quote
Old 11-06-2009, 09:21 AM   #16
FrankT
FrankT's Avatar
Went to the dragstrip last night. Broke the right axle. Any of you guys with high horsepower and sticky tires need to look into upgrading your axles. I'll be installing a set of 1000 HP axles this week. I'm going to become a dealer for these axles if anyone needs any.
Old 11-12-2009, 01:10 PM   #17
FrankT
FrankT's Avatar
Got the car fixed. I broke the outer CV joint on the right axle. I'll post up a pic of this soon. My Driveshaft Shop axles are installed and look great. These have a one year warranty against breakage. They are coming out with a two piece driveshaft for the 2010 Camaros soon. I am a dealer for their products, so if anyone needs anything, PM me for a price.
Old 11-13-2009, 11:03 AM   #18
FrankT
FrankT's Avatar
600plus RWHP + drag radials = broken axle!
Here are some shots of the stock right axle. Ouch! I wish GM had put bigger CV joints in, but I guess they hadn't planned on people putting 600hp through them!
Old 11-14-2009, 01:10 PM   #19
FrankT
FrankT's Avatar
This is what's going on next... powder coated stock calipers, Hawk pads and widened stock wheels. 275.'s on the front, and 305's on the rear.
Old 11-14-2009, 10:50 PM   #20
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Drives: Silver Ice 2010 SS/RS A6
Looks good Frank.........saving now for those axles
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
LSX-80MM is offline   Reply With Quote
Old 11-15-2009, 01:40 PM   #21
the rich dude
Drives: Getting 2010 Camaro
Keep me updated on the powder coating holds up please Thinking of getting it done but only if it stays looking good!
the rich dude is offline   Reply With Quote
Old 11-16-2009, 12:12 PM   #22
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
looking good my friend!!!!
lawdogg149 is offline   Reply With Quote
Old 11-17-2009, 02:50 PM   #23
FrankT
FrankT's Avatar
Tire differences...
Stock is on left (275), widened is on right (305). Still running the Pirelli's...
Old 11-17-2009, 02:53 PM   #24
FrankT
FrankT's Avatar
Underside shots...
A shot of the new axles, and one of the MBRP exhaust.
Old 11-17-2009, 03:14 PM   #25
matt55
matt55's Avatar
Drives: CTS-V
I would like to see your car in person , when are you gonig to take it out again ?
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
matt55 is offline   Reply With Quote
Old 11-20-2009, 05:11 PM   #26
FrankT
FrankT's Avatar
Caliper bolts finally came in today. For those who don't know, GM uses torque to yield (TTY) bolts to mount the calipers to the spindles. These are a one time use item. I know some people reuse them, but with my life riding on those eight bolts, I deemed it wise to replace them. Now I'm waiting on the Brembo cross-drilled rotors to get here. Also, I'm working on a different air cleaner setup that will use 4" tubing and connectors instead of the 3" presently there. The 3" setup was causing a restriction costing about 40 RWHP. See Lawdogg's thread for his dyno proof of this. Once all this is done, it's going on the dyno at RPM in Garner, NC to see what numbers mine turns. Stay tuned!
Old 11-24-2009, 05:27 PM   #27
FrankT
FrankT's Avatar
Air intake is done. It should flow more than the 3" setup that was on there. Only the dyno will tell for sure...
Old 11-24-2009, 11:50 PM   #28
the rich dude
what kind of air filter is that Frank?
Saw aqua blue today.. Help! cstproductions 5th Gen Camaro SS LS LT General Discussions 61 07-02-2010 11:19 PM
Pic request: Imperial Blue Metallic / Aqua Blue Metallic JameSS Camaro Photos | Spyshots | Video | Media Gallery 38 11-08-2009 04:20 PM
Anyone know where an Aqua Blue one in CT is? TooCool5 USA - NY / NJ / PA 12 06-25-2009 09:59 AM
Aqua blue & IBM are not for SS? bdstealth 5th Gen Camaro SS LS LT General Discussions 12 04-10-2009 11:37 PM
Aqua Blue vs. Jetstream Blue KevinK 5th Gen Camaro SS LS LT General Discussions 54 08-28-2008 09:36 AM
