Old 02-13-2010, 04:30 PM   #57
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
I should have some time to work on the car this week (I hope!). My painted Heritage grille from Gary's Customs should be here this week, as well as the remaining Pedders parts from Rob at Wretched Motorsports. I bought the differential bushing removal tool from Cincy Speed, that should be here this week too. Now I can install the Pfadt diff bushings and the job should be a lot easier! I'll post up this week as work progresses...
Currently in the fleet... 2010 ZR1 Corvette, 2014 Cadillac CTS-V, 2010 Camaro SS single turbo, 2006 Chevrolet 2500HD Duramax, 1967 Camaro SS350, 1969 Camaro SS427.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
FrankT is offline   Reply With Quote
Old 02-13-2010, 05:25 PM   #58
Silver Ice
Silver Ice's Avatar
Drives: 2010 Camaro 2ss-rs
Sweet
Silver Ice is offline   Reply With Quote
Old 02-14-2010, 01:22 AM   #59
Ivan @ Southwest Speed
Originally Posted by FrankT View Post
Lingenfelter pedals installed. Now I need to practice my heel/toe braking...
Nice covers!
Looking good man!
-Ivan
Old 02-23-2010, 04:50 PM   #60
FrankT
FrankT's Avatar
Currently working on Pedders radius rod bushings...
Old 02-23-2010, 04:55 PM   #61
FrankT
FrankT's Avatar
After removing the radius rods, it's time to get the bushings out. I pressed the center portion of the stock bushing out first. It's fluid filled, so it's pretty messy. Once it pops free of the shell, the fluid leaks out (maybe 2 or 3 ounces worth).
Old 02-23-2010, 05:00 PM   #62
FrankT
FrankT's Avatar
After that, I used my sawsall and cut almost all the way through the stock shell in two places. Then, using a hammer and chisel I peeled the slice out of the shell. The remaining part of the shell comes right out.
Old 02-23-2010, 05:04 PM   #63
FrankT
FrankT's Avatar
The new Pedders bushing can then be pressed in. To make thing a little easier, I put the bushings in the freezer for about an hour, and heated the radius rod eye with a propane torch for 4 or 5 minutes. After all that, it was still a pretty tight fit!
Old 03-22-2010, 06:05 PM   #64
FrankT
FrankT's Avatar
Things are coming along nicely so far this week. I'm feeling the deadline of the Camaro5 fest coming!! Pfadt rear subframe bushings are in the cradle, front brakes are done with Racing Brake rotors and pads. KW Varient 3 coilovers are in too. Heritage grille is in.
More to come with pics this week...
Frank
Old 03-22-2010, 06:42 PM   #65
ron10
Drives: 2010 2SS IOM L99
very nice
Old 03-27-2010, 10:33 AM   #66
FrankT
FrankT's Avatar
Rear suspension cradle is back in with Pfadt diff bushings installed, BMR toe rods in, powder coated calipers on, and Spohn lower control arms being installed. Brakes are bled, and I should finish up the rear suspension this weekend. With luck, I should be driving it next week!
Old 03-27-2010, 07:23 PM   #67
gtdauto
Drives: 2010 ss/rs camaro
7.6 twin disc fidanza on my 10 ss/rs?
Now comes the want for more power (it seems to always happen)... This time, I wanted to do something a little different. So, I decided to so single turbo this time. I had already changed the mufflers to SLP's Loudmouth II. Loved the sound, but don't think it made a lot more HP. Maybe 4 or 5, definately not enough to feel the difference. I had a place in FL do the turbo for me. A few issues with the work they did, but nothing I couldn't remedy myself. Car is running fine now. Upgraded the clutch to Fidanza 7.6 with aluminum flywheel. Best HP clutch I have had yet. Very driveable. Added the Hurst aftermarket short throw shifter. I love this shifter! Went with the black engraved ball, and the old school chrome stick.
when i pull out from a dead stop and that the clutch come out i here and feel a noise then it goes away after i start moving is this normal for these clutchs do you know?
gtdauto is offline   Reply With Quote
Old 03-28-2010, 10:34 AM   #68
FrankT
FrankT's Avatar
The 7.6 chatters a bit on engagement. I seem to need to give it a little more gas and slip it a little more starting off than the stocker. So I guess you could say it's a little noisier than the stock clutch was. If I had it to do over, I might try the ZR1 clutch Lingenfelter sells. But, it wasn't out yet when I put the Fidanza in.
Old 03-28-2010, 03:51 PM   #69
FrankT
FrankT's Avatar
Rear suspension is done!!!
KW Variant3 shocks, Spohn lower control arms, Pfadt swaybars and subframe bushings, Lingenfelter sway bar links, Pedders alignment bolts and upper control arm bushings, BMR trailing arms and toe rods.
Old 03-29-2010, 10:10 AM   #70
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
very nice frank!!!
Nationwide Turf
"artificial turf factory"
lawdogg149 is offline   Reply With Quote
Saw aqua blue today.. Help! cstproductions 5th Gen Camaro SS LS LT General Discussions 61 07-02-2010 10:19 PM
Pic request: Imperial Blue Metallic / Aqua Blue Metallic JameSS Camaro Photos | Spyshots | Video | Media Gallery 38 11-08-2009 03:20 PM
Anyone know where an Aqua Blue one in CT is? TooCool5 USA - NY / NJ / PA 12 06-25-2009 08:59 AM
Aqua blue & IBM are not for SS? bdstealth 5th Gen Camaro SS LS LT General Discussions 12 04-10-2009 10:37 PM
Aqua Blue vs. Jetstream Blue KevinK 5th Gen Camaro SS LS LT General Discussions 54 08-28-2008 08:36 AM
