Tom Henry Racing
Camaro V6 LLT Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 10-21-2009, 10:27 AM   #1
Airaid Filters
Airaid Filters's Avatar
Drives: 2010 Camaro
Air Intake Information for GM's 3.6L V6
The new Camaro direct injection system is advanced. The PCM is capable of identifying sensor readings that are outside of acceptable parameters and will compensate. The ability to compensate for sensor readings will allow the PCM to function with what is assumed to be degrading components. Sensor readings such as Mass Air Sensor frequency are expected to be within a particular range when sampled along with other engine sensors readings to include engine RPM, throttle position, etc. A component or group of components that cause sensor reading to be outside of acceptable range will lead to compensation settings from the PCM. The malfunction indicator lamp can illuminate if sensor readings (or combination of readings) are beyond these acceptable limits.
The PCMs ability to compensate results in restored functionality (or loss of temporary performance gains). Vehicle modifications can result in temporary “improvements” that are later adjusted back to original performance if those modifications result in sensor readings that are outside of the expected parameters. For example, installing an intake system with less restriction (more air flow) and mass air sensor mounting location that does not allow for proper sampling of the additional air flow. This will force the PCM to make necessary adjustments until it receives acceptable readings or combination of sensor readings. These “adjustments” result in original performance levels or an illuminated MIL if requirements are met.
An intake system that is properly designed to provide less restriction (more air flow) while allowing the mass air sensor to sample the incoming air flow accurately (as it did in the original intake) should not result in the PCM re-learning or compensating. The additional air flow resulting from less restriction should be measured from the mass air sensor accurately as the correct frequency reading per volume of air. Additional air flow should continue to be sampled accurately from the mass air sensor until the additional amount of air flow exceeds the functional limits of the mass air sensor or the allowable parameters of the PCM.
An unmodified Camaro will perform better at sea level than it will at 7000 feet elevation. This is due to the more dense air that is available at sea level. The mass air sensor will accurately read the difference in air density and the PCM will process accordingly (not relearn the performance back out) because the other PCM readings and functionality are within allowable limits. A properly modified Camaro will respond the same with additional air flow being measured accurately while maintaining sensor readings that are accurate and within allowable spec of the PCM.
The challenge for aftermarket manufacturers is to develop performance systems that provide added air flow while retaining sensor functionality within their design limits. Our staff of engineers and ASE certified techs utilize our in-house chassis dyno, flow bench, mass air sensor flow bench, rapid prototype equipment and much more to insure our products function and fit as intended. Our success has resulted in the consultation of performance intake systems to OEM manufacturers.
AIRAID Filter Company | www.AIRAID.com
airaidinfo@AIRAID.com | Toll Free # 800-498-6951
Find a local or Online AIRAID Dealer : http://www.airaid.com/DealerLocator.aspx
Airaid Filters is offline   Reply With Quote
Old 10-21-2009, 10:36 AM   #2
Xanthos
Almost-Original Postwhore
Xanthos's Avatar
Drives: Stick
Thanks for clearing this up!
- X
Xanthos is offline   Reply With Quote
Old 10-21-2009, 11:04 AM   #3
esperman
You Can Call Me Jay
esperman's Avatar
Drives: 2010 1LT RJT Manual w/CAI & Solo
exactly what I suspected all along.
Thats why I went and bought the Airaid.
AND I LOVE the sound & extra torque.
esperman is offline   Reply With Quote
Old 10-21-2009, 11:33 AM   #4
kga10734
Don't Feed the Troll
kga10734's Avatar
Drives: 2010 Camaro 2LT/RS & 1999 Corvette
Question about the MAF?
Which way is the proper way to install the MAF in the Airaid system? Does it really matter? After reading the above info by David, it just might make a difference.
I installed the MAF the way it showed in the directions, which is opposite of the way the factory had it.
kga10734 is offline   Reply With Quote
Old 10-21-2009, 12:01 PM   #5
esperman
You Can Call Me Jay
esperman's Avatar
Good question. I didn't pay much attention to that part of the instructions. I just seated it the way it felt the best fit.
No CEL and it's performing very well....so I'm not worried.
Old 10-21-2009, 12:05 PM   #6
faninc
Drives: 2010 Camaro RS in SIM
Airaid, well done and hopefully this dispells some of the fiction that it cannot be accomplished with the V6 PCM! Cannot wait to install mine when it arrives.
best
J
faninc is offline   Reply With Quote
Old 10-21-2009, 12:16 PM   #7
Airaid Filters
Drives: 2010 Camaro
Hello kga10734,
The MAF sensor will only mount in the tube 1 way. If you put it in backwards, the holes do not line up.
any other questions, please let me know.
Thanks,
David
Old 10-21-2009, 02:06 PM   #8
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
thanks for the info David!
Old 10-21-2009, 02:19 PM   #9
TIE FIGHTR
Cousin of Foo
TIE FIGHTR's Avatar
Drives: 2010 2LT RS BLACK/BEIGE
So your saying a Houston Camaro performs better than a Denver Camaro?
'I wish I was the full moon shining off a Camaro's hood' ~ Pearl Jam Wishlist
TIE FIGHTR is offline   Reply With Quote
Old 10-21-2009, 02:35 PM   #10
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
Temp factors also, denver is colder than houston
trudawg660 is offline   Reply With Quote
Old 10-21-2009, 03:49 PM   #11
calflan
calflan's Avatar
Drives: 1LT; IBM; 6 Spd Manual
Dave, so pulling fuses 5 and 20 (reset of power to the ECM) are NOT required it would seem. If there is not an engine light illuminated, the system recognized proper sensing requirments and performance gains are immediately available, would'nt that seem the case ?
This supports Scrming's quiry about mounting the temp sensor outside of the flow tube. If the sensor notes a colder - more dense - ambient temp, the ECU / car performs better.
'Within an allowable spec' does not mean a predetermined power level does it ? In other words, the ECU has a set target torque / power rating and therefore based on sensor inputs, compensations or adjustments will be made to maintain a set performance level ?
I agree completely that Airaid's system provides increased air flow, function and fit very well - first hand testimonial, have had the system installed approx. 2 weeks now. Additionally, based on Airaids testing, the system also satisfies required parameters for the ECU sensors, since the ENGINE light does not remain on after installation. But again, is the ECU returning performance to a set level, to maintain a burn level the ECU 'wants' ? May be more a Chevy question than Airaid I suppose.
Dave, thank you for posting. Your attention to customer detail and inquiries only make me more satisfied that I purchased an Airaid system.
1LT; Airaid CAI; Flowmaster American Thunder Axelback; Int Floor Lts; RS Spoiler; Radio Controls; Sequential tail lights; Oil Catch Can; VMAX Throttle Body; MACE plenum spacer; Mace manifold insulator[/I]
calflan is offline   Reply With Quote
Old 10-21-2009, 04:55 PM   #12
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Good info!
From the Jannetty CAI shootout (http://www.camaro5.com/forums/showthread.php?t=48202)
Here are the results:
http://spreadsheets.google.com/pub?k...=1&output=html
In regards to fuel trims... Stock was -3%. My understanding is that the ECU is saying "Ok, I calculated the amount of fuel I need based on the MAF, temp, etc. and I am running a bit to rich based on the o2 sensor so I had to subtract some fuel (-3%) to bring my Air Fuel Ratio back to where i want it"
After installing the Airaid the fuel trim goes to +7%, (10% swing). Now the the ECU is saying "Ok... I calculated the amount of fuel I need based on the MAF, temp, etc. and now I'm running to lean. I had to add more fuel (+7%) to bring my A/F back where I want it"
Now my understanding is +7% is not a big deal (some say less than +/- 10% to +/- 20%... So this is some of the part of the ECU that corrects things... There are also long term and short term fuel trims... and my understanding is if the fuel trims get to far apart then you can trigger a CEL.. Say the long term is -5% and all of a sudden the short term fuel trim goes to +25% you probably have a problem! LOL
scrming is offline   Reply With Quote
Old 10-21-2009, 10:25 PM   #13
curtis0407
Drives: 2007 MINI Cooper S
Hello everyone... I've been cruising around the sight for about a month now, reading and researching all that is being written about the V6 Camaro in hopes of eventually making a well formed decision when it comes time to lay down some money for one.
That said, I was struck by the following:
Does this mean that an Airaid modified Camaro V6 will perform as well @ 7000 feet as it would at sea level? As you may have guessed - Santa Fe is up at 7000 feet...
curtis0407 is offline   Reply With Quote
Old 10-21-2009, 11:53 PM   #14
HokieERVet
HokieERVet's Avatar
Drives: SIM/2LT/RS/Black/Manual
So will relocating the IAT sensor outside of the MAF sensor, as some are doing to get a colder air read, cause any issues with the PCM calculations making it "reset" and prevent gains?
HokieERVet is offline   Reply With Quote
Old 10-22-2009, 04:20 AM   #15
scrming
scrming's Avatar
Nope... you will still have "thin" air... a CAI doesn't change the air density....
Old 10-22-2009, 04:22 AM   #16
scrming
scrming's Avatar
Does not appear to... My long term fuel trims are +/- 1.6% and it appears that the car is running about 4 or 5 more degrees of timing...
Old 10-22-2009, 08:27 AM   #17
calflan
calflan's Avatar
True, but you'll have more airflow, ultimately providing the same affect as more dense air from the stock system. So I'd bet the Airaid system at 7000 would be comparable (or better) to a Sea level stock system.
Old 10-22-2009, 08:41 AM   #18
scrming
scrming's Avatar
Nope... Not even close... Yes you are moving more air but it still has less oxygen! You are just moving more "thin" air! It has to do with the composition of the air, not the volume...
Ok... The Jannetty test showed the Airaid added 9RWHP to a stock SS... so let say we give Airaid the benefit of the doubt and say you pick up 11RWHP. Now using a DA calculator looking at 7000 feet, if you run say a 15.00 in the 1/4, the DA calc says that if you run that same car at sea level you are looking at upper 13's. So clearly a full second faster. It takes a LOT more than 11 RWHP to make up a second! Rough number is about 10HP = 1/10th second...
So adding an Airaid my give you gain you .1 or .2 in the 1/4 mile... it certainly won't make up the difference between 7000 feet and sea level...
Old 10-22-2009, 09:18 AM   #19
Xanthos
Xanthos's Avatar
Drives: Stick
I was going to say something along these lines, but you beat me too it and worded it better than I probably would have anyway.
Heh.
- X
Old 10-22-2009, 09:37 AM   #20
fastal
Drives: 2010 2SS/RS, 2000 Z28
Sadly this is very true. I live near Denver and our local track is at 5800'. I haven't gotten my 2010 to a dyno yet but my 2000 Z28 has seen quite a bit of dyno time. Typically the correction factor on the dyno is between 1.2 and 1.25. So while my 2000 Z28 dynos at 405 with correction factor, the actual rear wheel is around 335hp.
I've decided with my 2010 my goal is to modify it to stock sea level performance. Since I'm at a lower altitude then 7000' I figure I need to add an actual 30-40HP. I figure I'll need a CAI, cat-back, and headers. On the headers I'm waiting until spring to see results people get from the various short and long tube. I'm guessing now that I'll have to go with longtubes to meet my goal. The only other thing that might help is tuning.
For a car guy I really hate living at high altitude On the other hand everything else is awesome, especially since I bought my house in a non-emission county so long tubes are easy to justify.
fastal is offline   Reply With Quote
Old 10-22-2009, 09:42 AM   #21
Xanthos
Xanthos's Avatar
Drives: Stick
You might actually be ok with just intake/exhaust/shorties.
However, I'm also waiting to see how the shorties vs. longtubes turns out.
- X
Old 10-22-2009, 09:49 AM   #22
MontyCarlo
MontyCarlo's Avatar
Drives: 2010 2LT/RS auto IBM
There will be some point where a camaro with an Airaid intake will have the same mass airflow as a stock car at sea level, but it's probably in the 1,000-2,000ft range.
Air pressure (and density, assuming temperature's the same) going into the engine depends on outside air pressure minus pressure loss through the intake. The Airaid intake will have a smaller pressure loss, so it'd definitely be able to go to some higher altitude and get the same flow density into the engine as a stock system at sea level, but exactly what altitude? Can't calculate that without some fluid flow modelling. Now, if somebody wants to send me CAD data for both intakes...
FAQs:
1. No, I do not have any strong opinions about the Monte Carlo.
2. Yes, I know what my name looks like.
3. Yes, but the medication helps immensely.
2LT/RS IBM/gray #21,895 ordered April 21st, delivered July 3rd
MontyCarlo is offline   Reply With Quote
Old 10-22-2009, 10:29 AM   #23
Airaid Filters
Drives: 2010 Camaro
Hello calflan,
That is correct; you do not need to pull the 5 and 20 fuses. If installed properly, there should not be a CEL.
WE do no recommend relocating the IAT sensor. All that is going to do is “Trick” the computer, which could end up with timing issues and other problems down the road. The Airaid is a true cold air intake system and pulls true cold air and that is what the IAT temp sensor is reading.
Thanks,
David
Old 10-22-2009, 10:40 AM   #24
Airaid Filters
Drives: 2010 Camaro
Hello HokieERVet,
Its possible relocating the IAT could result in a PCM issue. Relocating the IAT sensor is only going to "Trick" the computer into reading a false reading which could cause timing and other issues down the road.
Airaid does not reccomend relocating the IAT sensor.
Thanks,
David
Old 10-22-2009, 10:50 AM   #25
esperman
You Can Call Me Jay
esperman's Avatar
Hello HokieERVet,
Thanks,
David
Thanks for your input on the forum David.
I'm super happy with my Airaid and see no reason to modify any sensors.
AirAid Cold Air Intake anyone? Flynnaz Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 09:05 PM
Why RAM Air is a myth!!! Long Read (Wall of text) live2well Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 80 11-02-2009 03:34 PM
Calling all Vendors with CAI's - PROVE Your CAI Gains! READ JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 618 10-20-2009 11:39 AM
Intake/ Air Cleaner observations and thoughts... (?V6/V8?) radz28 5th Gen Camaro SS LS LT General Discussions 27 01-23-2009 08:14 PM
Saturn Sky Red Line GMPP cold air intake question 496BIGBLOCK General Automotive + Other Cars Discussion 8 12-29-2008 01:50 AM
