Old 11-03-2009, 10:07 PM   #771
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
ZR2+Z28=ZR8
if you solved for R....?
ZR2+Z28
R2+28
R+14
R=-14
So (Z(-14)2)+((-14)28)
(Z(-28))+(-392)
Z+(14)
Z=-14
So ((-14)(-14)2)+((-14)(28))
-28+(-392)
-420
Assuming my math is ok the birth of a ZR2 and a Z28 would be a -420
God I'm bored....
9/26/09 Took delivery!
Old 11-03-2009, 11:01 PM   #772
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Chevrolet Leno Camaro SEMA Concept car (with Pedders suspension) unveiled by Jay Leno
If you have followed our threads, you will know that we are a preferred vendor for GM, and have had the honor of working extensively with GM on the 2010 Camaro and other projects in the past and are working on future ones as well. This is a great honor for Pedders! The engineers we are working with are seriously first class and is a honor to work with them!! The install of this twin turbo is beyond good!. It is flawless and perfect. The guys at Milford are SERIOUSLY beyond perfect!!
GM made a very special Camaro for SEMA for Jay Leno. Guess what suspension system is on the the Queen of the Show? PEDDERS!!!!!! In fact, EVERY GM Camaro that GM made is riding on Pedders!!
Here is the data that was released tonight that we were present at the press introduction:
Powered by a twin-turbocharged version of the 3.6L direct injected V-6 that is standard in Camaro LS and LT models, Leno’s Camaro blends high performance with surprising efficiency in a racing-ready package. A pair of Turbonetics T-3 turbochargers blows through a custom air-to-air intercooler, force-feeding the engine about seven pounds of boost and lifting its horsepower level to about 425. That’s about 40 percent greater than stock and in normal driving (when the turbochargers aren’t making boost), there’s virtually no penalty in fuel economy over the non-turbocharged 3.6L engine.
“Jay’s Camaro offers style, performance and efficiency in a big way,” said Dewar. “It delivers the power of a Camaro SS on demand, but with the fuel economy of a V-6.”
Supporting upgrades for the turbo system include a larger-capacity Be-Kool radiator and a custom exhaust system, as well as a Centerforce-supplied clutch and pressure plate for the six-speed manual transmission. The tubing for the turbo system is powder-coated blue. The powertrain was designed to deliver consistent, controllable power for both the street and race track. In fact, road racing was a primary mission for the car during its development.
Additional vehicle also support its racing intent:
• Brembo six-piston brake package
• Pedders coil-over lowering kit
• New front fascia with custom fog lamps and integral brake cooling vents
• Air extractor-style hood
The exterior styling of Leno’s car is the most radical of all the Camaro concepts at SEMA. The front fascia and hood are one-off creations as are the unique upper and lower grilles and the ground effects package (including a rear diffuser). The heritage-inspired vent styling in front of the rear wheels has been replaced with functional brake cooling ducts.
THIS IS THE Z/28.
2cnd chance is offline   Reply With Quote
Old 11-03-2009, 11:58 PM   #773
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
425 hp isn't enough for the 3.6 L DI v6 with TT. seems too low.
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 11-03-2009, 11:59 PM   #774
boxmonkeyracing
juggernaut
Originally Posted by 2cnd chance View Post
THIS IS THE Z/28.
and you are wrong.
Old 11-04-2009, 12:06 AM   #775
Mr Twisty
Mr Twisty's Avatar
Chevrolet Leno Camaro SEMA Concept car (with Pedders suspension) unveiled by Jay Leno .....................
THIS IS THE Z/28.
-- Benjamin Franklin
Old 11-04-2009, 04:23 AM   #776
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
Aftermarket probably low. Keep in mind new ford 3.5L is 365 HP. So this is up 60 HP. Plus rule of thumb is 10 HP per pound of boost so 12 pounds of boost would put the Camaro at 424.
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 11-04-2009, 07:17 AM   #777
pwrhungry
Drives: wagon
Thats because of the tranny in the 4 wheel drive vehicles. Expect to see more when they hit 2 wheel drives. Also its not really fair to compare what they did with an aftermarket kit compared to a warrantied car off the line that weighs 4400#s with awd.
pwrhungry is offline   Reply With Quote
Old 11-04-2009, 08:23 AM   #778
Mr Twisty
Mr Twisty's Avatar
The Ford engine is 365 hp if it's in a bicycle or a tank.
How is this an aftermarket kit? Who makes it?
Old 11-04-2009, 08:41 AM   #779
pwrhungry
Drives: wagon
Its going to be more in a rear wheel drive only application. Thats why it matters. Its not the engine stopping them from more hp its the tranny of the awd models the current engine is in.
There is one turbo v6 that just showed at sema. Can you show me where you can buy this through the GM website? I dont consider a it a GM item when no one can buy it.
Old 11-04-2009, 09:00 AM   #780
Mr Twisty
Mr Twisty's Avatar
If 365 is manufacturers published numbers, it's at the crank, so the drivetrain it's turning doesn't matter.
Jay Leno bought it.
Old 11-04-2009, 09:32 AM   #781
RSHugger
Drives: 1969 RS Camaro
Wow... N3 was up early today... I guess a 6AM meeting with the Deutchland Team would do that to you.
Question... back to the House of Z... we have seen a couple of different hood combos... the TF2 BumbleBee hood remenicent of the Baldwin Style hood with the front facing bug catcher, the current hood with a flashback to the ZL2 hood... and now Jay Leno's hood. So for combustion air intake which is the better choice?? The ZL2 is non functional and would take a little work to collect air from the cowl and bring it to the front of the engine (unless you could turn the manifold 180 degrees )... the TF2 hood would force air in but increases drag and probably creates a bunch of dirty air... and then we have the Jay Leno hood. First blush it would appear that we have air going over the top of the openings in the hood and this would create a low pressure point over these openings... would not appear too efficient... but would reduce drag issues? Thoughts? What am I missing? It appears that the air box is sealed to the hood when the hood is closed?? Thoughts?
RSHugger is offline   Reply With Quote
Old 11-04-2009, 09:41 AM   #782
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by ShnOmac View Post
This would look so good parked next to a brand new Z/28.....
HELL YEAH! A jacked-up Silverado with an LSA next to my Z28?
How much lighter is that car, really, than an LS3/L99 car? Those turbos and plumbing are going to cost additional weight. The powertrain and chassis will have to be beefed up. And to "only" get about the same power as an LS3? Not even worth it, IMHO. If this is Z28, I'm getting an SS.
"I see your Schwartz is as big as mine."
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 11-04-2009, 09:52 AM   #783
RSHugger
They have an LSA in that truck?? Must have missed that one. Sweet
Old 11-04-2009, 10:17 AM   #784
Mr Twisty
Mr Twisty's Avatar
I think I heard someone say the same thing back in 69
"number z", 2014 700hp z/28, 3/27/2013, 75k, super de duper z thread, thread for the zed, what'z up?, where's our z/28, why no big z?, z/28 spring 2014
Camaro vs House? P. Ham 5th Gen Camaro SS LS LT General Discussions 82 05-20-2011 05:03 PM
House approves $2B more for 'cash for clunkers shank0668 General Automotive + Other Cars Discussion 3 07-31-2009 04:36 PM
3rd Annual Corvette Open House at MacMulkin Chevrolet-WELCOMES the ALL NEW CAMARO!! MacMulkin USA - New England 2 04-11-2009 09:16 AM
White House Approves $17.4 Billion Auto Loans to GM & Chrysler josh1147 General Automotive + Other Cars Discussion 97 12-29-2008 02:21 PM
White House says auto loans deal not imminent camaro5 General Automotive + Other Cars Discussion 11 12-15-2008 11:44 AM
