Old 10-23-2009, 07:40 AM   #1
JerseyMonte
JerseyMonte's Avatar
Drives: 1972 Z28
Clutch too sensitive
I have had my ss man for about 6 weeks now,
and still can't get used to the clutch.
It feels like it is engaged or disengaged with no in between
I've been driving manual transmissions since
before auto came out , i've owned about 6 manual
cars.
Problem is clutch is so sensitive that it requires
very slow engagement or it will stall out the engine.
Also shifting requires a different procedure to coordinate
throttle, clutching,and shifting from gear to gear.
It's embarasing to stall at a light with someone behind you.
It doesn't happen every time though, I even keep my left
heel on the floor to steady the engagement.
JerseyMonte is offline   Reply With Quote
Old 10-23-2009, 08:16 AM   #2
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
Intially I had a few problems as well, I stalled a few times, wasn't sure of the right rpms's bc my old car was different. It will start to break in for you and then you should have no problems, BTW how many miles on the car
mydreamcar is offline   Reply With Quote
Old 10-23-2009, 08:29 AM   #3
Camaro509
Camaro509's Avatar
Drives: 2010 2SS/RS Black
Mine is sensitive, but nothing that can't be compensated and gotten used to after just a few miles and shifts.
Understeer, Oversteer, Wheel Alignment (Camber etc), Torque, Horsepower, Camaro
Fold for team 11108 to help find a cure!
Folding@home Stanford's Research DC Program.
Camaro509 is offline   Reply With Quote
Old 10-23-2009, 08:34 AM   #4
Icefsh
Icefsh's Avatar
Drives: CGM 2LT/RS M6
Noticed the same thing. Not with stalling any more but more with trying to take off fast. Like at the friction point to full engagement, there is such a small amount of travel. It is hard to realy get a fast start without riding the clutch.
Also when shifting from 1st to 2nd you realy have to be careful on how you release clutch and accelerate without jerking. Have done better with practice. You can't just release clutch then throttle. But feather it in. All the other manuals I have owned have never been this sensitive. I agree with your observation.
Maybe it's like Allen Iverson said "We talkin about practice."
Icefsh is offline   Reply With Quote
Old 10-23-2009, 08:46 AM   #5
Kms
2010 2SS/RS IOM/IO INT
Drives: 2010 Camaro 2SS/RS- IOM, IO INT
Hmmm- I just started driving a stick again after many years but no problems. I only stalled the car one time at a stop light. Getting better at shifting too. Not as jerky- just takes time. I would agree it is a little touchy but no complaints here. Love the power of a stick and the smooth ride.
Only issue I notice is it makes you shift from 1st to 4th quite a bit unless your really on it in 1st.
Kms is offline   Reply With Quote
Old 10-23-2009, 12:08 PM   #6
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
That is the CAGS (computer aided gear selection AKA skip shift) kicking in. You can remove it with a skip shift eliminator or a tune.
Old 10-23-2009, 12:18 PM   #7
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
I just have the seat set to where my leg only pushed the clutch to the point where it will disengaged with my leg all the way out and it makes it alot less stressfull when letting the clutch out
WICKEDSS is offline   Reply With Quote
Old 10-23-2009, 12:58 PM   #8
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
My last manual was a 1999 Saturn SL1. The first few miles in the SS were a challenge for sure. You just need to experiment with different ways of engaging the clutch and using the accelerator. It should be an easy transition to the Camaro 6 speed. Good luck.
Old 10-23-2009, 05:06 PM   #9
JerseyMonte
Drives: 1972 Z28
Glad to hear
I'm glad to hear I'm not the only one,
I thought it was just me. Same as with the
the jerking when shifting from gear ro gear.
I have just turned 1 K drove it today,and tried different
ways, I think the biggest problem is having the radio too
loud and not being able to hear the revs come up
without looking at the tach, and keeping my left heel
on the floor to better support engagement
Thanks for the reply
Old 10-23-2009, 06:08 PM   #10
bono83
bono83's Avatar
Drives: 1969 Chevelle, 2010 1LT
I must admit I'm having a little difficulty with the sensitivity as well, but I'm getting better. I too have owned and driven plenty of manual transmissions. Even though it's a little touchy, I really, really love this car....the best I've ever owned!
Order: 5/23/09 - Deposit given with order at dealer.
1100: 6/26/09 - Order placed by dealer - no allocation
2000: 8/15/09 - Accepted by GM.
2500: 8/18/09 - Preferenced.
3000: 8/18/09 - Accepted by Production Control.
3100: 9/9/09 - Available to Sequence.
3300: 9/9/09 - Scheduled for Production.
3400: 9/19/09 - Broadcast.
3800: 9/29/09 - Produced.
4000: 9/29/09 - Available to Ship.
4150: 9/29/09 - Original Invoice.
4200: 10/6/09 - Shipped.
5000: 10/13/09 - Delivered to Dealer.
6000: 10/13/09 - Delivered to Customer.
bono83 is offline   Reply With Quote
Old 10-23-2009, 06:33 PM   #11
JerseyMonte
Drives: 1972 Z28
I have to admit
I have owned many new cars, mostly performance
and have not had one I enjoy more than this one,
I may be an old fart [67] but I still feel the same as
I did when I got my first new one a 60 Impala 348
triple carb 4 speed.
The clutch is only a minor. I wouldn't say problem
or inconvinience but I will get it down the more miles
I put on it
Old 10-23-2009, 07:01 PM   #12
LightningSS
Drives: WAS '10 SS IBM, NOW '14 BRM ZL1
Take the return spring out and then it's smooth in and out....constant pressure...
LightningSS is offline   Reply With Quote
Old 10-23-2009, 07:27 PM   #13
cliffy
Chevy Power Forever
cliffy's Avatar
Drives: 1969 Dusk Blue Z/28, 2015 Red Z/28
Anybody that says this clutch engagement in the Camaro is normal is making excuses, because it just plain ain't for shit. You should not have to "get used to" squat. Drive a Porsche, or even a Subaru WRX, or even my 70 Chevelle with Rockcrusher to find out how it should be. Clutch should be intuitive and a natural coordination of a stroke of your left leg and your right foot, You should not have to train your leg to do jack (compensate for anything) especially engagement points.
Anyone that comes up with a fix or adjustment I'll beat a path to their door
Cliffy
cliffy is offline   Reply With Quote
Old 10-25-2009, 10:01 PM   #14
Scooterlee
Scooterlee's Avatar
Drives: 2LT/RS M6 RY
Glad to hear I'm not the only one. I stall the car quite a few times since I got it a month ago.
Getting better now but for a moment I thought I had no tallent driving a M6.
btw... will stalling hurt the transmission? or it just hurts your pride
Scooterlee is offline   Reply With Quote
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Question for seasoned stick shift drivers tommygun6644 Dragstrip and Launch Techniques Discussion 69 10-11-2010 11:42 PM
Coming Soon! RAM Twin Disc Clutch and Flywheel! Taking Pre-Order List @BMC Peformance Kris@BMCPerformance V8 Bolt-Ons & Tunes 7 02-18-2010 08:00 PM
Vengeance Racing Introduces RPS Organic Street Twin Clutch for 2010 Camaro!!! Ron@Vengeance V8 Bolt-Ons & Tunes 2 08-05-2009 02:03 PM
Burned my clutch a bit with Launch Control.... Caution you guys... Embalmer 5th Gen Camaro SS LS LT General Discussions 49 04-23-2009 09:49 PM
