Old 10-23-2009, 09:31 PM   #1
DC-SS
Drives: Imperial Blue 2010 Camaro 2SS
Anyone have 1-2 shift issues?
Sometimes shifting from 1st to 2nd the stick will be totally locked out of second. It wont go in no matter what except to let it naturally float to neutral and then put it in second. Not hard on the throttle either... Not in comp mode... It only happens about 1 in 20 shifts but that sure is enough for me to get a little bonkers, lol.
DC-SS is offline   Reply With Quote
Old 10-23-2009, 09:34 PM   #2
Kelso
Drives: 99 camaro
Its the "skip shift" feature. A little lite should come up by the speedometer...it basicallly wants u to shift to 4th gear instead of 2nd...can be fixed with tune or eliminator
Soon to own: 1SS CGM M6
Kelso is offline   Reply With Quote
Old 10-23-2009, 09:36 PM   #3
bbardo
bbardo's Avatar
Drives: "Modi" son of "Thor"
Its called skip-shift
Look it up on the forum or in your manual
Then purchase a skip shift eliminator they are in the forums as well
2SS/rs named "Modi"
Adopted & signed by Scott 8/15/09
Officially "Son #2 of Thor"
bbardo is offline   Reply With Quote
Old 10-23-2009, 09:44 PM   #4
Lydon
Lydon's Avatar
Drives: 2010 2SS Camaro
It's designed to 'save gas' and you'll get used to it. Doesn't do it all the time, but can freak you out when it does. Don't fight it or you'll eff up the tranny. It def lets you know it's going to do it in the DIC between speedometer and RPM dials.
Karen
Lydon is offline   Reply With Quote
Old 10-23-2009, 11:38 PM   #5
103FrazzL
103FrazzL's Avatar
Drives: 2010 Camaro 2SS RS M6
If the throttle is at 21% or less and the vehicle is fully warmed up it WILL do it so if u give it a litttle extra throttle out of first it will not do it or if the vehicle is not warm it will also not do it.
2010 Camaro 2 SS RS CGM
ADM Street Cold air intake, SLP Loud Mouth II, ARH 1 7/8 Long Tube Headers w/high flow cats, Hurst Short Throw shifter, Skip shift eliminator, LED licence plate Lights
103FrazzL is offline   Reply With Quote
Old 10-24-2009, 03:13 PM   #6
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
accelerate a little harder or shift a bit later and it won't activate, this is a free solution (since all will end up costing you a little in gas). Or eliminate it completely with a store bought resistor (couple bucks, but mistakes are relatively easy to make), a commercial kit (few more bucks, harder to screw up), or a professional tune (more expensive but you can blame them if things go wrong).
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-25-2009, 08:11 PM   #7
DC-SS
Thank you all! I actually saw the 1-4 display on the DIC today when it did it. This was the first time I noticed it. I thought for sure my tranny was in need of some break-in... I ordered the SLP skip shift eliminator with my exhaust and Eibach springs. I got the exhaust on last night and I spent all day today driving it around and trying the "load" break-in... The new exhaust sounds amazing but I ended up having to pull the center brace out completely. I just can't get the 3" pipes over it without it rattling at least a tiny bit...
Old 10-25-2009, 08:18 PM   #8
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
I had the same problem with my ARH 3" pipes rattling on the tunnel brace, got me a replacement from MBRP that comes with thier exhaust kit. It clears the pipes with ease.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 10-26-2009, 09:10 AM   #9
DC-SS
I looked up their web site and I like the way that looks. I called my local MBRP dealer to see if they can get the part or not...
Thanks!
Old 10-26-2009, 10:15 AM   #10
linkwpc
The punching cat
linkwpc's Avatar
Drives: '10 Camaro SS Black W/Hugger&W/IOI
Just order a skip shift eliminator from SLP. I love mine and it does not come on anymore!
My car build (COTW 7/23/12) - - - - - - > CLICK HERE! : http://www.camaro5.com/forums/showthread.php?t=80725
linkwpc is offline   Reply With Quote
Old 10-26-2009, 10:20 AM   #11
Mr Smith
Born again Hot Rodder
Mr Smith's Avatar
Drives: Black 1SS/RS LS3 M6
Really...Cause before I figured out what it was doing id let it go to neutral and then jam it into 2nd...
Mr Smith is offline   Reply With Quote
Old 10-26-2009, 10:50 AM   #12
V1c1ous
V1c1ous's Avatar
Drives: 96 Z28 SS, 2010 SS RS
With the eliminator, your display will still come on but you can shift to 2nd. It drove me crazy.
"Start brain before placing mouth in gear".
V1c1ous is offline   Reply With Quote
Old 10-26-2009, 08:02 PM   #13
DC-SS
I would let it go to neutral let go, then grab and it would go into second no problem but I was definately thinking it needed to be broken in a bit... So I intentionally took routes with lots of stops and turns so I had more chances to use 1-2 shifts... I got the SLP skip shift eliminator and it works like a champ! No more forced shifts...
Old 10-28-2009, 12:19 AM   #14
camarogolfguy
Camarogolfguy
camarogolfguy's Avatar
Drives: 2012 ssrs
What does the sse cost, where do you get them and does installing one mess with the warranty on the car or powertrain?
camarogolfguy is offline   Reply With Quote
Camaro Skip Shift Eliminator.... southerncarparts V8 Bolt-Ons & Tunes 12 02-22-2018 09:34 AM
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 11:34 AM
How's your Gas Mileage? Shift Notice Issues? massng 5th Gen Camaro SS LS LT General Discussions 1 08-29-2009 12:13 PM
Issues With My Camaro - We Need a Forum Here Embalmer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 14 06-15-2009 02:04 PM
