Old 10-23-2009, 09:40 PM   #1
B.Buster
B.Buster's Avatar
Drives: 2010 AquaBlue 2SS/RS
How about a MAF translater
Back in the 90's we used a MAFT to manipulate the PCM.This changes the signal between the MAF and PCM. This could change fuel trims and timing. Probly could be used today so no reflash is needed that dealer can detect. Just a thought.
B.Buster is offline   Reply With Quote
Old 10-25-2009, 08:44 AM   #2
m1tankr
m1tankr's Avatar
Drives: '06 Trailblazer SS
Those went out of fashion as the technology changed. Tunes work better & the software is fairly easy to use. No more burning chips, just reflashing. I think the other issue would be that this generation of computer tech would keep readjusting for changes in the MAF signal & they are much more complicated then the old GN's & such.
m1tankr is offline   Reply With Quote
Jet Performance MAF Sensor - Thoughts?? SSouthernboy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 03-04-2012 11:14 AM
Tips for First Timer MrCool 4th Generation Camaros 123 10-31-2009 08:37 PM
maf tune/no open loop nice flat 12.5 fuel trim mstrfdsstr Tuning / Diagnostics -- engine and transmission 25 10-15-2009 04:48 PM
Part number or calibration curve for stock MAF on V8? SoloSK71 Tuning / Diagnostics -- engine and transmission 0 08-23-2009 07:33 PM
"Resetting" the MAF vs. CAI install ... where's the hp coming from? LS 1st gen Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 07-03-2009 09:42 AM
