BeckyD@RodgersChevrolet
Old 10-25-2009, 11:52 AM   #1
Cruz-lo
Drives: 2010 2ss RS
Question ACTUAL GM alignment specifications?
Does any one really know what they are?
Since the GM service manual is not out I have no idea.
saw one post on here with specs. But they are all very different and mention
"FE2" "WRS" and "RPO"
No idea how that relates to a 2ssRS.
I checked mine stock I have.
Front -1.3 camber each side 0 toe.
Rear -1 and -1.2 camber and +.120 toe "in"
Please help!
Thanks.
Cruz-lo is offline   Reply With Quote
Old 10-25-2009, 01:07 PM   #2
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Here you go:
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 10-25-2009, 07:14 PM   #3
Cruz-lo
Drives: 2010 2ss RS
Yes Thank you.
This is what I found in my search. But there are two front settings and three rear settings. What do the definitions in my first post mean so I can use the table correctly?
What do the followng mean then.
FE2
FE3
RPO
WRS
WBS
Thanks.
Old 10-25-2009, 08:18 PM   #4
Info@PeddersUSA.com
Originally Posted by Cruz-lo View Post
Yes Thank you.
FE2
FE3
RPO
WRS
WBS
Thanks.
With stock suspension, I would go with FE3 suspension for all vehicles. To be honest, there is little difference.
Now with a Pedderized Camaro, that is a different ballgame., We can go a lot more radical and still have good tire wear.
thanks
mike
dms
Old 10-25-2009, 10:00 PM   #5
RCLapCar
RCLapCar's Avatar
Drives: 2016 2SS A8 HB/JB
Yes Thank you.
FE2
FE3
RPO
WRS
WBS
Thanks.
If those are the GM codes it should be
FE2 - V6 suspension
FE3 - V8 suspension
WRS - Rally Sport Package (20" wheels instead of 19" on LT's)
WBS - LT without RS package ?
It seems there are different specs for LT's with and without the RS package.
Current: 2016 2SS Hyper Blue/Jet Black
Former: 2010 2LT/RS IOM/IO - Solo Catback w/ J-Pipes
RCLapCar is offline   Reply With Quote
Old 10-26-2009, 01:46 AM   #6
Info@PeddersUSA.com
FE2 - V6 suspension
FE3 - V8 suspension
these are the exact specs from the GM web site.
mike
dms
Old 10-26-2009, 08:45 PM   #7
Cruz-lo
Drives: 2010 2ss RS
Thank you everyone.
Exactly what I was looking for.
My first thought is that toe in of .2 for the rear is too much? But the specifications are what they are.
Being a Rear wheel drive I would have thought more to 0 for toe. But this is my first rear wheel drive independent rear suspension car also.
Now I just need my Pedders coil overs ordered September 16!
Thanks again!
Old 10-28-2009, 02:01 AM   #8
Info@PeddersUSA.com
Thank you everyone.
Thanks again!
With your Pedders coil overs do this:
Front
Camber -1.0 each wheel
Toe at .05-.07 toe out each wheel
Rear
Camber -.5
toe at .0
this will make you smile!
mike
dms
Old 10-28-2009, 05:01 PM   #9
Cruz-lo
Drives: 2010 2ss RS
Great!
Thank you. In fact that is what you mentioned to me when I ordered the coil overs from you!
Now I just need the coil overs!!! But I know you quoted 6-8 weeks.
Old 10-29-2009, 06:47 PM   #10
55Designs
Drives: 2010
Mike DMS what kind of drop level do you recomend those alignment specs and is that with and without sway bars?
55Designs is offline   Reply With Quote
Old 10-29-2009, 11:45 PM   #11
Info@PeddersUSA.com
Those specs are good from 1/2 drop to a 2 inch drop. We can go seriously different when we add the bushes, etc.
Sway bars really do not affect alignment settings.
Now one other thing to do is to have the Camaro 1/2 inch lower in the back than the front. This will help the serious decels and hard braking.
mike
dms
Old 10-30-2009, 08:36 AM   #12
tlc9193
The Original
tlc9193's Avatar
Drives: 2010 Camaro 2SS
Send a message via Skype™ to tlc9193
What kind of alignment settings would you recommend with just changing the springs out with H & R Springs?
tlc9193 is offline   Reply With Quote
Old 10-31-2009, 03:39 AM   #13
Info@PeddersUSA.com
You should contact H&R for this
mike
dms
LLT engine specifications Tran Wiki 2 03-29-2010 11:06 AM
Looking for a Camaro to get a Pedders Alignment PartsGedder USA - Texas 5 10-20-2009 10:12 AM
Alignment Specs?? Camaro21 Suspension / Brakes / Chassis 4 10-01-2009 03:53 PM
ls3 ss now 430hp!!!? gss9909 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 57 11-18-2008 02:56 PM
Anyone seen photo of actual rally stripes? littlecammi Camaro Photos | Spyshots | Video | Media Gallery 0 10-26-2008 12:17 AM
