Rick@Livernois
Old 10-25-2009, 12:42 PM   #1
myold88
myold88's Avatar
OnStar Diagnostics Report- TIRES.
Today I received an OnStar computerized diagnostic report via Emailed with green, yellow, red boxes along with a short note on each mechanical catagory. All is Ok but it says all 4 tires are at 30 PSi instead of 36 PSI.
I'm wondering if this could be a computer glitch or due to the colder weather now hitting New England. It's in the 30's here now in the early A.M.'s.
I guess I'll have to go check my tire pressure but @ 1700 miles it seems odd all 4 tires would be down exactly 6 pounds on my 2SS.
Old 10-25-2009, 12:50 PM   #2
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
It's the cold weather. I'm in Utah and its getting around 36 degrees here over night and I'm getting reports that my tires are around 30-31psi as well.
Old 10-25-2009, 12:57 PM   #3
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2014 1LE...Drove: 2012 ZL1
The DIC should tell you the tire pressures, too...right?
Mr. Wyndham is online now   Reply With Quote
Old 10-25-2009, 12:58 PM   #4
lcmc
Drives: 1987 IROC Z convertible
I put 35psi in mine but my car only shows 31. Is there a way to calibrate the sensors?
lcmc is offline   Reply With Quote
Old 10-25-2009, 01:26 PM   #5
68/2010
Emerald Coast Camaros
68/2010's Avatar
Drives: 2010 2SS Rally Yellow
I think it's messed up myself. I had all mine done at 36 and the computer said 40, 41 and 38,39. On star is never the same. Sp, I don't know what to believe.
Old 10-25-2009, 03:44 PM   #6
beegroovie
Drives: 2016 Mosaic Black 2SS
FWIW, all 3 montly OnStar diagnostics that I've gotten since I took deliver all say the tires are low (31psi). The DIC and the tire gauge say they're fine. This happened in warm weather also, so I don't think it has to do with the outside temperature.
beegroovie is offline   Reply With Quote
Old 10-25-2009, 03:54 PM   #7
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Same here my report says they are low but when I check tire gauge there fine,
Old 10-25-2009, 03:56 PM   #8
anthonybyram
anthonybyram's Avatar
Drives: 1972 Z28, torch red,454
Get a good tire pressure gauge, use it,and trust your instincts. Kinda of old fashioned but has proven successful for alot years!
anthonybyram is offline   Reply With Quote
Old 10-25-2009, 06:12 PM   #9
IROCanSS
Drives: 89 IROC 350
It does.
You can. Its in the DIC, it says reset. The horn will beep a few times when you hit it. Very strange.
Mine does it all the time. Don't worry about it and don't over inflate them. if it is cold out and the car has not been driven, the air compresses and the pressure is low. As you drive, the tires heat up, the air expands and the warning goes away. if you get the warning and fill them up in the cold, the tires will warm up, the air will expand and you will be over inflated. Best advise... on a decent day in the 60s, drive the car around a while doing osme turning to heat the fronts up too and go fill them where you want them using a pressure guage and then ignore onstar. If the warning comes on in the DIC, take a quick check to make sure you are only a few pounds off and go on your way. It is a good idea to check incase you actually do have a leak. If it reads 20psi.. you have a problem. Expansion/contraction only changes them a few pounds and if you run low 30s you will get the warning alot.
Second way to eliminate it is go and have them filled with nitrogen. Expansion/contraction is much less.
Old 10-25-2009, 06:33 PM   #10
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
Don't listen to Onstar or the tire gauge in the car.. It is rarely accurate. Buy yourself a digital tire pressure gauge and once a week check them. I also bought an inflater and every week it is down from 36 to 35/34 when cold. That is in 75 F weather in the morning. The moment you start driving around, the tire pressure goes up and down depending on how you drive. Always check the pressure when it is cold and in the morning to be consistent.
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 10-25-2009, 07:48 PM   #11
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
If you have pressures set at 36 cold and it is 70 degrees out, the pressures will drop 5-6 psi at 30 degrees.
Always fill tires when it will be coldest out..both ambient and tire temp.
A digital gauge should be used regardless what the DIC states.
Same holds true from winter to spring...You have 36 PSI and a 70 degree day hits. Your cold pressures will be 42 psi.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 10-25-2009, 07:51 PM   #12
Mr. Wyndham
I'd like to disagree with this...My experiences with the system have always been within 1 psi of the actual pressure.
Old 10-25-2009, 07:58 PM   #13
97one
97one's Avatar
Drives: 2016 & 1967 Camaro, 2015 Impala, +1
It varies with the outside temp.
And rises after you drive & they heat up.
97one is offline   Reply With Quote
Old 11-04-2009, 11:02 AM   #14
calflan
calflan's Avatar
Drives: 1LT; IBM; 6 Spd Manual
Reset your tire pressure sensing at the switch on the steering wheel. I had a tire indicate low pressure - warning from car sesning system illuminated. I reset the pressures and all was fine. Pressures were a tad higher than before reset. Like any monitor system I suppose it can get corrupted or misinform. Just reset and see what you get.
1LT; Airaid CAI; Flowmaster American Thunder Axelback; Int Floor Lts; RS Spoiler; Radio Controls; Sequential tail lights; Oil Catch Can; VMAX Throttle Body; MACE plenum spacer; Mace manifold insulator[/I]
calflan is offline   Reply With Quote
Onstar....a spy???? please comment dieseldave24v General Automotive + Other Cars Discussion 138 02-23-2012 01:12 PM
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 10:51 AM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Got my first Onstar Diags report. Scott@Bjorn3D 5th Gen Camaro SS LS LT General Discussions 47 05-13-2009 02:35 PM
18, 19, & 20" replacement tires ... dougmac Wheels and Tires Talk Sponsored by The Tire Rack 3 03-29-2009 05:27 PM
