SDTW Custom Wheels & Tires
Old 10-27-2009, 03:35 PM   #1
CamK18
CamK18's Avatar
Drives: 2010 1LT Vic Red
Downshifting into second...new Camaro owner/standard driver
Hey guys,
I have had my LT for about 3 weeks and i have picked up standard pretty well, I just have one problem and a question for you guys.
When in third, and downshifting into second, its extremely jerky sometimes so I have started doing a single clutch downshift and that has helped alot...but its still relatively jerky.
Is this because im possibly going to fast? It usually happens when I am slowing down, approaching a light and shifting into second at about 40 hm/h (while doing the rev-match). Is this too fast and possibly causing the jerkyness?
CamK18 is offline   Reply With Quote
Old 10-27-2009, 04:08 PM   #2
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
What are you doing if you're NOT doing a single clutch downshift? Double clutching?
I like to blip (quick press) on the throttle as I'm downshifting. It attempts to match the engine with the higher RPMs you will have once you downshift. Sounds like you might already be doing that though...
Very easy to do on my motorcycle, but takes some practice on the car.
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 10-27-2009, 04:11 PM   #3
CamK18
CamK18's Avatar
Yeah thats what I have been doing, blipping the gas before the downshift..works like a charm, no jerk at all in any other gear besides second. I dont usually downshift into first so i cant say for that gear but all the others seem fine.
Old 10-27-2009, 07:50 PM   #4
nemosgt
Drives: 2006 Ford Mustang GT
Send a message via ICQ to nemosgt
Hi CamK18
"When in third, and downshifting into second, its extremely jerky sometimes so I have started doing a single clutch downshift and that has helped alot...but its still relatively jerky."
Yeah, single-clutch downshift is the way to go. Double-clutching not required. You should not be using the transmission for slowing anyway. Downshift when you need the lower gear in order to accelerate. Use the brakes for slowing. Brake pads are cheaper than transmission repairs.
Remember, the lower gears (1st and 2nd) are comparatively steep, so try waiting till you have slowed more than for the higher gears before shifting.
Make sure you have rev-matched before releasing the clutch.
Practise makes perfect.
Cheers.
nemosgt is offline   Reply With Quote
Old 10-27-2009, 07:54 PM   #5
JHart
I haz camaro again :)
JHart's Avatar
Drives: 2010 Chevrolet Camaro 1SS
i usually hold my shifter next to the gear when i drop down, push the clutch in until it falls into the lower gear, and slowly let off the clutch. just takes practice man, hell i'm 17 and i've got this thing about down pat. took me about a month.
2010 Camaro 1SS(back in a camaro again, yessssss!)
2010 silverado z71 ccsb(sold, old dd)
2010 camaro1ss(sold, missed, will have another someday)
JHart is offline   Reply With Quote
Old 10-28-2009, 10:54 AM   #6
crazz28
crazz28's Avatar
Drives: '10 Camaro SS/RS, '10 GMC Sierra
When you are going to that low of gear you don't have much momentum and if you aren't perfectly matched in revs, these "lightweight" cars with high hp/tq engines will do thier own thing and jerk you around until it's found the right speed.
I don't even bother trying to downshift into second unless i'm barely rolling from third..........unless I'm coming up to a tunnel or something!!
CGM/BLACK INTERIOR 2SS/RS LS3 M6
TTi/GMS Twin Turbo, Borla S-Type mufflers, Hurst Shifter
crazz28 is offline   Reply With Quote
Old 10-28-2009, 02:35 PM   #7
CamK18
CamK18's Avatar
I did what you guys all said and im starting to get better..thanks guys!
Old 10-28-2009, 03:15 PM   #8
lcmc
Drives: 1987 IROC Z convertible
What's with double clutching. Haven't had to do that since the Model T was out!
lcmc is offline   Reply With Quote
Old 10-28-2009, 09:43 PM   #9
JHart
JHart's Avatar
idk what the hell double clutching is. i try to rev match my gears when downshifting, if that's double clutchin,i guess i do it alot then. lol.
Old 10-29-2009, 02:01 AM   #10
xSSkier874
xSSkier874's Avatar
Drives: 13 X5M, 99 Miata
Send a message via AIM to xSSkier874
big no no my friend... by doing this your slipping the clutch . This isn't as big of any issue on the stock clutch but if you plan upgrading you may want to change your technique.
Sold -10 2SS/RS, sunroof, and a lot of toys!
Camaro5 Fest IV camarocross super modified champ
Sold- 2011 Corvette Z06 w/ Z07 package
2013 X5M- the Silver Turbo Dump Truck Missile
1999- the male hair stylist track toy
xSSkier874 is offline   Reply With Quote
Old 10-29-2009, 09:41 AM   #11
Susantroy1
To All Veterans
Susantroy1's Avatar
Drives: 2010 2LT RS Inferno Orange
Originally Posted by nemosgt View Post
Hi CamK18
Cheers.
I have always used engine braking on all my bikes and vehicles to assist in slowing down. I've never had a tranny problems and my brakes last well into the 40-70k range. Am I not understanding here?? is nemosgt saying that engine braking is bad on a tranny?? anybody care to clear this up???
Susantroy1 is offline   Reply With Quote
Old 10-29-2009, 11:57 PM   #12
55Designs
Drives: 2010
I feel the same way and experience the same jerkiness.
For one I am not used to this driveline and I have other cars that Rev to 9000RPM and I can downshift at 4-5k RPM safely because the engines RPM will spike higher and not be a huge deal. The Camaro is a not happy doing that.
I tried downshifting on the Camro from 3-4500 RPM and it locks the rear up and skids dangerously. Going from 4th to 3rd, or 3rd to 2nd and were talking speed below 60MPH
Driving this car is an entirely new experience because its so unrefined compared to other cars I have and owned. I do hope things get better.
55Designs is offline   Reply With Quote
Old 10-30-2009, 12:11 AM   #13
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
no no no. i can't stand it when people do that in my truck!! that's a great way to need a replacement clutch sooner. the less time you're working the clutch pedal on hard shifts like that, the better. if you want to downshift, you're much better off rev-matching because you ain't making the clutch disk slip and match engine/transmission speeds. that wears the surface more & builds up heat - 2 things you don't want.
or at least since synchronized gears came out
nope. double clutching is where you push the clutch, shift to neutral, release the clutch so the engine and input shaft match speeds, then push the clutch, select gear, and release the clutch.
this is really only needed in non-synchronized transmissions
it's just a littler harder on the transmission and clutch. the purpose of downshifting is to either be able to accelerate out of the lower gear or assist the brakes when you have a heavier load. if you're just rolling up to a stop sign, there's no need to downshift. just use the brakes - that's what they're made for
consider, these engines ain't designed to rev as high as many smaller engines or even european or japanese engines. yes, it does take some time to get used to, but once you find the sweet spots for each gear, you'll be shifting like a madman!
Old 10-31-2009, 03:34 AM   #14
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
i read this and was thinking say your rounding out a turn on a track or entrance ramp and you start to accelerate out the turn and your in a higher gear and your in the lower rpms where your not quite in the power band yet then you slip your clutch and give it gas to get the rpms up into the power band then feather the clutch out and haul ass ; well i thought that was double clutching . been racing dirt bikes & cars forever it gets your back tires spinning good in a higher gear so you can accelerate longer in one gear instead of having to shift so much, every second counts.
klatterblast is offline   Reply With Quote
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
New Camaro Exterior and Interior Stainless Steel Trim Parts from RPI Designs! RPI Designs Exterior Parts & Accessories 30 02-20-2013 04:23 PM
Some thoughts on "recent" developments on this site.... fbodfather 5th Gen Camaro SS LS LT General Discussions 258 05-08-2009 11:24 PM
Car and Driver drives V6 Camaro! Xanthos 5th Gen Camaro SS LS LT General Discussions 63 08-26-2008 10:21 PM
