JDP Motorsports
Old 05-27-2010, 02:00 PM   #141
Primus
2G1FF1EV0A9113319
Primus's Avatar
Drives: 2010 1LT/RS 6MT
Wow, I would have bought that if I knew it was going to be that cheap. bastards.
2010 Camaro 1LT/RS M6 Black
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
3800: 5/28/2009 VIN: 2G1FF1EV0A9113319
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Delivered: 6/10/2009
Primus is offline   Reply With Quote
Old 06-03-2010, 01:45 PM   #142
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Originally Posted by SS 376 View Post
The Dale Jr. spoiler is now available at chevypartsplus and gmpartsdirect. It's $460 at chevyparts and $418 at gmpartsdirect.
I don't see it on gmpartsdirect anymore and chevyparts site is down. Is it no longer available?
nak3dsnake is offline   Reply With Quote
Old 06-03-2010, 01:52 PM   #143
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
Originally Posted by dickholloway View Post
on the NLP, did you find a lot of filling and sanding had to be done to the fiberglass before painting like the install instructions say?
LOL not yet, but hopefully I'll be able to order my 2SS soon, so I can have something to put one onto
Old 06-04-2010, 01:06 PM   #144
SS 376
SS 376's Avatar
Drives: IBM 1SS
Here you go. These should be the right links...
http://www.gmpartsdirect.com/results...umber=92234283
http://chevypartsplus.com/product_in...04c8876c562360
And here's Hurst:
SS 376 is offline   Reply With Quote
Old 06-04-2010, 01:07 PM   #145
nak3dsnake
nak3dsnake's Avatar
Thanks
Old 06-26-2010, 01:53 PM   #146
spawny
spawny's Avatar
Drives: Black 2SS/RS L99
I picked up the IVS Havoc dovetail at the GM nationals in Carlisle this morning for $300... My question is this.. should I have the dealer paint it for me? Or cheaper elsewhere? The dealer is supposed to be adding white rally stripes for me anyhow, I just haven't been able to drop it off with them. For that matter, I'm no longer sure I even want the rally stripes, now that my rims are powder coated black.
hmmm, pictures not working.. here's a link
http://s8.photobucket.com/albums/a32...n.jpg&newest=1
spawny is offline   Reply With Quote
Old 06-27-2010, 02:01 PM   #147
SNV
SNV's Avatar
Drives: 2014 RRM 2ls
It might be a little cheaper at a body shop. If your car is going to the dealer anyway I would price it out with them doing it.
SNV is offline   Reply With Quote
Old 07-03-2010, 04:50 AM   #148
Wilburbeest
Think With Your Dipstick!
Wilburbeest's Avatar
Drives: 1997 Camaro Z28
Wow nice pieces but seems awfully expensive for a little strip of fiberglass.
Originally Posted by Primus View Post
I have a dumb question. It's probably the same for all these spoilers, but how do you get the bolts mounted to the spoiler?
I just got my spoiler in (Carbon By Design) but I'm not quite sure how to mount the bolts onto the spoiler. The stock spoiler already has them mounted and I assumed that is how this spoiler would come. I found the bag with the mounting hardware but there were no installation instructions so I'm not quite sure how to get the bolts into the spoiler.
Any help would be greatly appreciated.
Well I would say unbolt the stock spoiler and if you have more holes for the new one than are in the hatch, or if they are in different locations it's time to bring out the drill. You could probably make a template if you wanted to by taking some cardboard (or any number of other materials), sticking it to the spoiler with double sided tape, cutting it to the proper shape, then putting the holes in it and sticking that down on the car before you do any drilling. Of course set the spoiler on top of the template to be sure its right before the drill ever comes near your deck lid. You could also try what I attempted with my dovetail for my 4th gen, which was to stick squares of double sided tape onto the spoiler over the holes, cut out around the holes, then press the spoiler on the car and carefully lift it off, leaving the tape behind. I didn't have any luck with this technique but others have had it work somehow so it might be worth a shot. I ended up finding a way to use the drill guides the spoiler came with but it doesn't sound like you have those. If you're uncomfortable with any of that I'd recommend taking the car to a shop.
EDIT: just realized how long ago that post was made. Oh well maybe somebody else will find it useful.
- Willy
1997 Camaro Z28 (LT1/T56): K&N CAI | Kooks 1 3/4" LTs | 3" Custom Duals | UMI LCAs w/ relocation brackets | UMI adj. panhard bar | UMI adj. torque arm | Koni SA shocks | Strano Springs | Ram Powergrip clutch | Pro 5.0 shifter | skip shift eliminator kit | WS6 Store rotors | Hawk HPS pads
Wilburbeest is offline   Reply With Quote
Old 07-03-2010, 10:21 AM   #149
Primus
2G1FF1EV0A9113319
Primus's Avatar
Turns out the nuts were molded into the carbon fiber. I'm not sure exactly why it came with a second set of nuts. It came with double sided tape attached to the spoiler. Unfortunately the holes in the spoiler didn't match up with the holes from the stock spoiler very well. I had to drill out a few of them in the deck lid before I could get the bolts through the holes and into the spoiler. Then, on one of the holes, when the screw was about half-way into the spoiler the nut molded into the carbon fiber must have broke loose a bit. I know it wasn't cross threaded and I know I had not overtightened it as the bolt was only about half way into the spoiler.
Aside from those issues it went okay and I really like the look of it. I understand that some don't really care for carbon fiber, or this style of the spoiler but I really love it and it gives it that '69 look I was going for, IMO.
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Old 07-05-2010, 12:21 AM   #150
Edge.128
Edge.128's Avatar
Drives: 2010 Camaro LS
I have a LS camaro and don't really want to drill holes into the trunk lid. is that 3M tape strong enough to hold these spoilers on or is drilling the only way to go?
Edge.128 is offline   Reply With Quote
Old 07-05-2010, 02:18 PM   #151
Primus
2G1FF1EV0A9113319
Primus's Avatar
It's possible that it's strong enough to hold it on but I would just drill if I were you. Drilling it out isn't really all that bad. Just use some rust prohibiter after drilling.
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Old 07-07-2010, 01:44 AM   #152
nards444
nards444's Avatar
Drives: 1SS/RS Black
http://www.chevypartsplus.com/produc...b9161a0727b801
anybody put this on and have an actual picture? I know there are concept pictures or renditions but I would like to see a NO BS picture on somebodys car.
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
nards444 is offline   Reply With Quote
Old 07-07-2010, 10:01 AM   #153
Primus
2G1FF1EV0A9113319
Primus's Avatar
If I had seen that before I bought my Carbon By Design one I would have but it wasn't available then :(
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Old 07-07-2010, 05:56 PM   #154
Edge.128
Edge.128's Avatar
ya i'll just drill it but i was just curious what you guys thought... thanks
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 380 11-06-2017 05:38 PM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 10:17 PM
