Old 10-27-2009, 09:55 PM   #1
1-SS
Drives: 2010 camaro SS, 2007 gsxr 750
Doug Thorley headers (ticking noise please help)
I just installed the Doug Thorley Shorty headers on the L99 and getting a ticking noise from the passengerís side. You really donít hear it at idle but when you give it gas you can and when the AFM kicks in you really can. I checked for leaks and nothing I even took them off and reinstalled. Is this normal sound.
Thanks for any help.
1-SS is offline   Reply With Quote
Old 10-27-2009, 11:35 PM   #2
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
When I put headers on my truck I had this same thing happen. It turned out to be the header's collector was not lined up correctly with my "y pipe" causing a leak. I realigned it and the sound went away. The best way to check for a leak is to put your hands around the collector and feel for air leaking out. Careful you don't burn yourself!!
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 10-28-2009, 12:52 AM   #3
thebrainhart
thebrainhart's Avatar
Drives: '10 Camaro 2SS/RS CGM LS3 A6
Originally Posted by 1-SS View Post
I just installed the Doug Thorley Shorty headers on the L99 and getting a ticking noise from the passenger’s side. You really don’t hear it at idle but when you give it gas you can and when the AFM kicks in you really can. I checked for leaks and nothing I even took them off and reinstalled. Is this normal sound.
I got that noise a little too. Can hear it best when driving alongside a wall.
I figure its normal-ish. Probably due to the thinner walls, and therefore less sound deadening headers. Makes the cylinder deactivation louder, I guess. I checked for leaks a couple weeks later, and found none.
I havent noticed the noise recently, possibly cause I am used to it, idunno.
- 2010 Camaro 2SS/RS CGM LS3 A6 "Lurch" - FLYNGSS -
Some ProCharger, Alky, CompCams, Brian Tooley, Holley, Livernois, K&N, Ridetech, DSS, Kooks, JDP Motorsports, Pfadt, BMR, Prothane, Weld, M&H, Mickey Thompson, RKSport, Elite, Garys, Defenderworx, Anvil, etc.
thebrainhart is offline   Reply With Quote
Old 10-28-2009, 01:04 AM   #4
chevyss
SS/RS
chevyss's Avatar
Drives: 2010 SS/RS IOM w/blk stripes A6
Installed a set of ARH and exhaust a while back and my car now has this little ticking noise. It can be heard more like when your in the drive through. I agree that it's the thin wall headers. Stock manifolds hide some of the engine noise.
chevyss is offline   Reply With Quote
Old 10-28-2009, 07:33 AM   #5
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
it could be header ping aka high compression. I got a set of Hooker Supercomps on my 69 and it has the header ping.
It scared me at first but after realizing what it was and that the primaries are not that thick I understand.
Get a piece of black rubber hose stick one end to your ear and the other all over the header and listen.
If its a leak you will hear air suction or pulsating if its ping you will hear the same sound through the hose as you hear from your normal position.
welcome to higher compression engines. Headers bring out the sound in a car for sure
Jekyll-N-Hyde is offline   Reply With Quote
Old 10-28-2009, 01:53 PM   #6
1-SS
Iam going to check everything again it sounds like a leak
Old 10-29-2009, 05:38 PM   #7
trenchdog73
trenchdog73's Avatar
Drives: 2010 2ss/rs Cyber grey camaro
yeah sound like a gasket leak
trenchdog73 is offline   Reply With Quote
Old 10-29-2009, 06:28 PM   #8
Speedy One
I have Doug Thorley's on mine and had the same problem. Turned out to be at the collector, gasket wasn't seating correctly. Added another type gasket in addition to the original and that took care of it. Bet that's what your hearing.
Speedy One.
Speedy One is offline   Reply With Quote
Old 10-29-2009, 06:57 PM   #9
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
You guys re-tightening after it's fully warmed up? Wear gloves and get in there to snug them up.
On my '68, I installed my Doug's with paper and aluminum gaskets to prevent the leaks. It helped after only installing the aluminum dead softs (which leaked).
1968 Camaro convertible, LS1 & T56, Texas Speed 228R cam, 3.73 posi, 17" Torque Thrusts
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust SOLD! Now in a 2016 Challenger Scat Pack Shaker, M6
ckaram is offline   Reply With Quote
Old 10-29-2009, 08:43 PM   #10
1-SS
Found it today it was a gasket leak on the bottom. Went and got a new gasket and the ticking is gone. I guess that’s what I get for using the old ones. Thanks for all the help.
Doug Thorley Shorty Headers :: +20rwhp, +35rwtq! Sean@Phastek V8 Bolt-Ons & Tunes 67 01-20-2014 09:25 PM
Doug Thorley Shorty Headers for 2010 Camaro Installed -WOW! Rallyman6 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 64 03-13-2011 01:36 PM
Doug Thorley Shorty Headers 1-SS V8 Bolt-Ons & Tunes 4 10-18-2009 01:13 PM
Doug Thorley Headers V6 shorty headers DOUG THORLEY HEADERS V6 Bolt-Ons & Tunes 5 09-10-2009 05:58 PM
