sjm autoprod
Old 10-28-2009, 04:03 PM   #1
kelleyperformance
kelleyperformance's Avatar
Drives: DD- 15' Chevy SS Sedan
ALL V8/V6 Camaro Fluid Capacities/Specs
i thought this might be a helpful thread. i know many of you like to do your own services. heres all the fluid capacities and fluid specifications for the camaro's-
Differential- (MUST be GL-5 approved fluid!)
Manual V6/V8: 1.0 qts............75W-90 Gear Oil GL-5(GM p/n 89021677)
^^Requires the use of LSD additive approx. .075 L/2.6 oz (GM p/n 1052358)
Auto V6: 0.9 qts............75W-90 Gear Oil GL-5(GM p/n 89021677)
^^NO LSD required, but if already premixed with your fluid is OK
Engine- (GM recomends using synthetic engine oil)
LS3/L99: 8.0 qts........5W-30 Synthetic Oil(GM uses Mobil 1)
V6: 6.0 qts........5W-30 Synthetic Oil(GM uses Mobil 1)
^^Capacities are WITH replacement of oil filter
LS3/L99 Oil Filter: ACDelco PF48.........K&N HP-1017........Napa Gold 7060
V6: ACDelco PF2129............K&N HP-7003........Napa Gold 7090
Cooling System-
LS3: 11.7 qts........ Dexcool 50/50 mix (Orange, NO Green Antifreeze!)
L99: 11.5 qts.......Same as above
V6: 11 qts.......Same as above
Transmission-
LS3: 3.65 qts..........Manual Transmission Fluid (GM p/n 88861800)
^^That p/n is apparently just a new number/name for Dextron III, which is what these transmissions have in them from the factory. DO NOT use Dextron VI or any types of gear oils (ie 75W-90)
L99/V6 Auto: 6.7 qts (pan/filter removal), 11.0 qts (complete flush)...........Dextron VI
^^I DO NOT recomend using aftermarket "shift kit" fluids^^
V6 Manual: 1.9 qts........75W-90 Gear Oil GL-5(GM p/n 89021677)
hope some of you all find this useful
kelleyperformance is offline   Reply With Quote
Old 10-29-2009, 09:13 AM   #2
27chris
SSMOKEM
27chris's Avatar
Drives: 2010 SummitWhite 2SS/RS Camaro
Thanks! Very good Info.
1100 = Preliminary Order: 9/04/2009
2000 = Accepted By GM: ?
3000 = Accepted By Production Control: 9/10/2009
3300 = Scheduled For Production On: 09/28/2009
3400 = Broadcast: 09/29/09
3800 = Produced: 9/30/09 2G1FT1EW0A9151456
4200 = Shipped:10/08/09
5000 = Delivered To Dealer 10/19/09
6000 (Delivered to customer): 10/20/09
27chris is offline   Reply With Quote
Songs About Camaros (for your driving pleasure) Emjay 5th Gen Camaro SS LS LT General Discussions 74 12-18-2014 12:42 AM
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 338 04-15-2009 05:33 PM
UPCOMING CAMARO IMPORTANT DATES CamaroScotty 5th Gen Camaro SS LS LT General Discussions 125 01-11-2009 12:31 AM
