Caryle Racing
Old 10-29-2009, 08:11 PM   #1
aaron@reliablechevrolet
aaron@reliablechevrolet's Avatar
Drives: Every Camaro I Can
Ring gear
What is the size of the ring gear in a 2010 camaro
aaron@reliablechevrolet is offline   Reply With Quote
Old 10-29-2009, 08:36 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
from what we have been told it is 8.5-8.6",,
Old 10-29-2009, 10:38 PM   #3
OrangeChevyII
Drives: 2010 RS/SS2
8.95 is what the GM brochure says.
2010 SS/RS SIM
First to run 11's (11.83)on a stock long block.
First to run 11's cam only
First to run 11's all motor
First to run 10's (10.96) and did it with a 100% bonestock long block and a power adder (nitrous)
First to run 10's (10.55) on motor in 2010 Camaro
First to break into the 5's (5.97) 1/8th mile
First to cut a 1.5X sixty foot
First to cut a 1.4x sixty foot
First to car to cut a 1.3x 60ft
OrangeChevyII is offline   Reply With Quote
Old 10-30-2009, 01:39 PM   #4
Well I have three diffrent numbers does anyone know witch one is right
Old 10-30-2009, 02:25 PM   #5
camaro1
camaro1's Avatar
doesnt really matter at this point, no one has blown one up yet and there are no aftermarket ratios out yet!
L99, A6 (1st gear discussion?) SGOS252382 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 31 07-26-2015 11:56 AM
Ring Gear Size halo8hkk V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 28 11-04-2009 11:45 AM
Does any 6 speed owners see a need for a gear indicator? OHIOSS 5th Gen Camaro SS LS LT General Discussions 98 10-13-2009 09:36 PM
Piston to Valve Clearance? My First Camaro! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 08-18-2009 08:26 PM
Do you think it was right that the mustang got to use the trackpack in the comparison perfxn Chevy Camaro vs... 91 03-30-2009 10:44 PM
