HURST
Old 07-10-2008, 01:32 PM   #1
kfbrinton
Drives: 2002 Blue RS 5 speed
2002 RS act like its out of gas
I was driving down the road and it just stopped like it was out of gas. Gage showed more than a half tank. Luckily is was in front of a gas station. Push it in and added gas just in case the gage was wrong. It started for a minute, sputtered and died. Tried again - got the same result. It acts like it is out of gas. I had it towed home! Suggestions?
kfbrinton is offline   Reply With Quote
Old 07-10-2008, 01:39 PM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Bad fuel pump, fuel filter? In that respect it would be out of gas ....oops, not funny.
But there are some very knowledgeable people around here that know more specific issues the 4thgens had than I do. I'm sure they'll be able to help.
Old 07-10-2008, 01:44 PM   #3
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
My first instinct would be fuel pump or fuel filter, too.
Anyway....Got air, fuel, spark?
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 07-10-2008, 02:08 PM   #4
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
I'd check the Fuel filter first, Fuel pump second, Fuel pressure regulator third.
Fuel filters are pretty easy, just hard to reach. I'm guessing the pump is in the tank? I've changed a fuel pressure regulator on a 5.7 vortech motor. I had to remove the upper intake ??? Damn I forget what it's called. The plastic, piece on top of the manifold itself... Anyway I had to take that off to get the FPR... The hardest part was the wireing harness.... Took about 2 hours. Not too bad if you like to turn your own wrenches.
Old 07-29-2008, 03:48 AM   #5
jm5877
jm5877's Avatar
Drives: 2002 Chevrolet Camaro (Black)
Yeah, fuel filter or pump, maybe injectors???. I had a problem with my '99 Camaro sputtering and dying when I put a couple tanks of lower octane gas in it. The check engine light came on, the works. Until that point I had put at least 91-93 octane in it. I put a bottle of fuel system cleaner in it and a full tank of 93 octane, then took it out on the interstate and ran it at about 110mph flat out for five miles or so, never had a problem after that.
Current Camaro:
2002 Coupe - V6 (Black/Ebony)
Previous Camaros:
1984 Sport Coupe - 4cyl (White/Blue)
1993 Coupe - V6 (Black/Charcoal)
1999 Coupe - V6 (Black/Charcoal)
Future Camaro:
2010 LT/RS Coupe - V6 (Black/Neutral)
jm5877 is offline   Reply With Quote
Old 07-29-2008, 01:01 PM   #6
Bumble Bee '77
AutoBot Scout
Drives: 2002 ZRS Camaro
Ive heard that the Optispark distributor on the 200* series Camaros, because of its placement can cause problems such as these. MSD makes a replacement thats fully sealed against the elements. Might want to check into that.
Bumble Bee '77 is offline   Reply With Quote
Old 08-18-2008, 10:38 PM   #7
MajorTom
MajorTom's Avatar
Drives: 2005 Pontiac GTO
I'm an apprentice mechanic and from my experience, that sounds like a fuel pump. Just like everyone said.. If it were a bad injector, it would most likely sound like you have a misfire.
Good news is, if you're not opposed to cutting a hole over the gas tank of your car, it's possible to change the fuel pump without taking the whole rear suspension (which according to shop manuals is the process required to replace the fuel pump) and pull the pump out there. If you do a google search for Camaro fuel pump replacement there are walkthrus available.
I believe that's for the LT1 engine. My buddy had one of those and it was a pain in the ass. The 3.8 liter like the OP has are much less difficult to deal with.
MajorTom is offline   Reply With Quote
Old 08-19-2008, 06:24 PM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Optispark is only on the Gen. II LT1 and L99
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 08-19-2008, 10:12 PM   #9
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
Is there a ping pong ball in your gas tank? Do you have any enemies?
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 08-20-2008, 02:02 AM   #10
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
what I was gonna say....mabe I should just stop posting....seriously though sounds like one of those three....Id go fuel pump first...but the fuel filter is a much easier/quicker fix if it is the problem.
TFord is offline   Reply With Quote
Old 08-27-2008, 10:59 PM   #11
oldchevyguy
Drives: 2015 SS/RS 1LE
optispark was only used on the LT1 1993-1997
oldchevyguy is offline   Reply With Quote
Punks puncture gas tanks Scotsman General Automotive + Other Cars Discussion 22 05-30-2008 03:19 AM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
Gas engines: Here to stay Mr. Wyndham General Automotive + Other Cars Discussion 0 05-05-2008 04:34 PM
Gas Guzzler Tax Roflmao Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 02-29-2008 06:29 PM
Gas is 3$ a gallon for good. 28Dennis General Automotive + Other Cars Discussion 35 10-02-2007 01:00 PM
