GM Parts House
Old 10-31-2009, 03:24 PM   #1
Dentyneice
Drives: 2010 Camaro 2ss
When to shift at the track
Took my car down to Atco's last night, first time going to any track let alone racing in one and was wondering when's a good spot to switch gears? I've been shifting at about 6k rpm on each range but I still ran a 13.83 on my best run.
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal
Dentyneice is offline   Reply With Quote
Old 10-31-2009, 03:35 PM   #2
dragrcr
2SS 6M
dragrcr's Avatar
Drives: 2010 2SS 6M
6000 is good. Because if you are seeing 6000 you are probably shifting a little higher. What was your speed?
dragrcr is offline   Reply With Quote
Old 10-31-2009, 04:02 PM   #3
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Lets see your timeslip. My guess is you getting off the line slow (60' time).
Old 10-31-2009, 04:12 PM   #4
Merc
In The Circle
Merc's Avatar
Now you have opened Pandora's Box the 60' time. So what's the best way to get the M6 to 60'
Old 10-31-2009, 05:35 PM   #5
DarricSS
DarricSS's Avatar
Drives: '10 Camaro SS
With the stock Camaro you will want to shoot for the best 60ft. time you can...Allot of people including myself were able to pull 2.0 60ft. times with the stock tires.
Air down your rear tires to around 25lbs. Hold down the traction control button for 7 seconds to turn traction control and stabili-trac off. Pull around the water box, back into the moist area and you got a couple options. Turn the tires over about 3 or so revolutions don't smoke them up like the imports tend to do...OR practice a couple launches (Launch, back up, Launch back up) you are trying to get pebbles and oil off the rear tires.
Pull up to the line and stage. Rev the engine to around 3500-4000 RPM and RIDE the clutch out at that RPM like you are driving out normal at a stop light. After around the first 60ft the clutch should be all the way out and at WOT. Shift as fast as possible at 6000-6100 RPM. You will chirp the tires in second and 3rd gear and will get some wheel hop in all 3 gears. With the stock gearing you will shift to forth gear pretty much right on top of the 1/4mile trap. I tried running through 3rd and not shifting to 4th and was slower.
If you do everything right you should pull a 13.0 @ 108mph or so, take a look at the 1/4mile list.
Good luck!
2010, SIM, 2SS/RS, LS3, CGM Stripes
DarricSS is offline   Reply With Quote
Old 10-31-2009, 05:44 PM   #6
Dentyneice
60ft @ 2.424
1/8 9.26
1/4 13.919
mph 107.62
and
60ft 2.417
1/8 9.188
1/4 13.836
mph 106.18
Old 10-31-2009, 05:51 PM   #7
1320junkie
Drives: The Imperial Army
Yeah you need to work on that 60
Old 10-31-2009, 06:16 PM   #8
FNKNSTN
Banned
Drives: A Black Car
You gonna win some money at a track, or what?
Anyone standing at the side lines without a stop watch is gonna say - "DAYUM! THAT'S A FAST CAR!"
0.4 seconds?
FNKNSTN is offline   Reply With Quote
Old 10-31-2009, 06:19 PM   #9
1320junkie
0.4 seconds?
.4 seconds can cause you to win or lose a race. Drag races are won or lost in tenths of seconds..so to drag racers those .4 seconds are very important and after you have been racing for awhile you can feel that difference.
Old 10-31-2009, 06:30 PM   #10
SGOS252382
SGOS252382's Avatar
Yeah, and people don't understand how many car lengths .4 of a second is going 105 mph crossing the 1/4 mile mark (a good 4 car lengths or so). I believe its something like 16 ft per .1 of a second at 110mph.
Old 11-01-2009, 04:30 PM   #11
CynAgain
CynAgain's Avatar
Drives: Chevy
Thanks for this detailed answer! I'm looking forward to giving this a shot in April!!!
Good luck!
Old 11-01-2009, 08:12 PM   #12
DarricSS
DarricSS's Avatar
The night I went to the track I tried just about every scenario available on the car.
Launch control mode. (2 quick taps of the button) Ran slow
Traction control off. (1 tap of the button) Ran slow limited timing or some granny feature
Then held the button down for 7 seconds turned everything off, did exactly what I listed in the above post, pulled a 2.0 60ft. And Ran my best time of the night first try. 13.3 @ 105mph at a DA of 3300+ corrected to optimum conditions that was a 12.84 @ 110.41 MPH wish i could have had the perfect conditions like some of the others on the 1/4 list
Riding the clutch out at 4500 RPM is the hardest part to get use too. Let the clutch out to fast and you do a burnout at the line (Did it...lol) RIDING the clutch out with a cringe on your face like you sucked on a lemon and pulling your best time of the night PRICELESS!
Good luck!
Old 11-01-2009, 08:20 PM   #13
CynAgain
CynAgain's Avatar
Drives: Chevy
Good luck!
OrangeChevyII says ride the clutch as well and you both proved it works. Sound good to me.
Time for some practice
Old 11-08-2009, 12:10 AM   #14
BLACK10
BLACK10's Avatar
my best was 13.13@ 114.3, ive got to try the 4k ride out next time.:(
Richmond Dragway Track Rental Nov 13th in Va GMRULZ USA - Southeast 2 11-15-2009 08:34 AM
Track time in Canada? logan1080 Canada 7 10-29-2009 07:53 PM
Mongillo Motors/Wretched Motorsports Track Rental - LVD June 26th Rob@WretchedMS USA - New England 6 07-23-2009 03:47 PM
Mongillo Motors/Wretched Motorsports Track Rental - LVD June 26th Rob@WretchedMS USA - NY / NJ / PA 5 07-15-2009 09:33 AM
What does making the track widths the same do? nathlo 5th Gen Camaro SS LS LT General Discussions 9 02-10-2009 01:26 PM
