BeckyD @ James Martin Chevy
Old 10-31-2009, 04:46 PM   #1
AnthonyD
AnthonyD's Avatar
Drives: 2SS/RS Black IO Int
Invisicord for SS
I recently installed Invisicord for my Escort 9500ix. Here are some tips for those wanting to do this (very basic electrical skills needed). First, take the mirror off the windshield. This is easily done by loosening the one screw located at the base of the bracket. You will need a torq screwdriver (found in any hardware store), size is T20. After removing the screw, pull the bracket up along the windshield to reveal the wire clip. The clip pulls out with a little force. You now have the open wires and bracket to work with freely.
You will find two rows of wires, one row will have a black wire with a pink wire on the same side. This side will also have wires taking up all holes. The other side should have an open pin hole.
Important***You will need to file down the pins on your invisicord to at least half. A simple metal file will do. Some additional filing may be needed.
Next, insert the black sheathed pin (ground) into the black wire hole on the bracket. It may take a little force and a pair of pliers may be needed. The pin should insert up to flared area (close to the black or yellow colored sheath). Next, insert the yellow pin into the pink wire hole. Reattach your bracket to the mirror, slide the mirror back on and done.
AnthonyD is offline   Reply With Quote
Old 11-01-2009, 07:10 PM   #2
ROE
Drives: 2008 cts
do u have pic
ROE is offline   Reply With Quote
Old 11-01-2009, 07:14 PM   #3
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
weird...I didn't need to file down anything.
I used the red wire (+) and the white/black stripe (-).
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 11-01-2009, 07:40 PM   #4
AnthonyD
AnthonyD's Avatar
powerfreak, thought it was weird also, but just couldn't get pins to go in. after 30 minutes of trying in the 90 degree florida heat (105 in the garage), decided to file to about half. Was still pretty snug. Sorry ROE, no pics. Too f*ing hot by the time I got it together.
Old 12-11-2009, 09:44 AM   #5
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv, A8, NPP, MRC
What is Invisicord?
What is Invisicord and what do you use it for?
Sorry...total noob to modding here...
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 12-11-2009, 10:00 AM   #6
POWERFREAK
I.AM.
POWERFREAK's Avatar
a pre-made power cord for a radar detector...plugs into the wiring harness for the rear-view mirror.
NY5thgen.com
Old 12-11-2009, 01:02 PM   #7
pnyklr
Drives: A Gift From My Wife
http://www.invisicord.com/index.html
-Funk
pnyklr is offline   Reply With Quote
Old 12-11-2009, 02:01 PM   #8
eynigush
SoCal C5 Family Member
eynigush's Avatar
Drives: 2010 Camaro SSRS Rally Yellow
What length Invisicord did you use? 8in? 10in? 12in?
Kooks 1 7/8 headers w/high flow cats
Magnaflow Cat-back Competition Series
Cold Air Intake by CAI Inc.
eynigush is offline   Reply With Quote
Old 12-11-2009, 02:44 PM   #9
POWERFREAK
I.AM.
POWERFREAK's Avatar
I went w/ 12
NY5thgen.com
Old 12-13-2009, 02:32 AM   #10
PnCRedJwl2SS
Howdy! Pete here...
Cool--thanks! Learn something new every day!
PnCRedJwl2SS
Ordered from GM
Old 12-13-2009, 02:37 AM   #11
cyberbro
cyberbro's Avatar
Drives: Not a Camaro at this time
Order Status:
2000 8/27/15
3000 9/3/15
2000 9/22/15 (Order changed)
2016 2SS With Auto, NPP, MRC, Nav, Split 5 Spoke Bright Aluminum.
cyberbro is offline   Reply With Quote
Old 12-13-2009, 09:39 AM   #12
POWERFREAK
I.AM.
POWERFREAK's Avatar
Originally Posted by cyberbro View Post
there was a whole install write-up posted..."search" is your friend.
NY5thgen.com
Old 12-31-2009, 06:12 PM   #13
phazer
phazer's Avatar
Drives: 2010 Camaro SS Bumblebee
I installed an invisicord today, I also have a escort 9500 ix. The invisord plugged in OK, and I have 12 V running to the cord. I plugged in an RJ11 port and tested it with my meter. But it will not power on my Escort (which works fine with the Cigarette plug) Any ideas. Is there more than one type of invisicord. I bought mine form southern auto parts along with the camaro bracket.
phazer is offline   Reply With Quote
Old 01-20-2010, 10:26 AM   #14
Dangeruss
Bayoucitymusclecars.com
Dangeruss's Avatar
Drives: Camaro LSX
Installed my Invisicord last night. Works great...no more hanging cord!
Here are a few of pics (sorry about the fuzzy one).
