Gen5DIY
Old 11-02-2009, 01:56 PM   #1
srevoal
Like the Batmobile Honey
srevoal's Avatar
Drives: Black 2SS/RS M6
Question Skip Shift Eliminator Problem. Need help.
I bought a skip shift eliminator for my 2ss/rs m6 and when I went to install it I noticed its connectors only had 2 pins. The car's connectors seem to be 4 pin connectors. Am I looking at the wrong spot or did they send me the wrong model? I've tried contacting the vendor but am getting no response. I don't want to use Paypal to get me money back if I'm just installing it in the wrong place.
Any help would be appreciated. Thanks
6/29/09 Preliminary Order - 1100
9/2/09 2000!
9/15/09 3000 10/05/2009
9/22/09 3300 10/05/2009
10/1/09 3400 10/5/2009
10/9/09 3800 2G1FT1EW1A9153975 ETA 10/23
10/24/09 IN MY GARAGE!!!
Big thanks to Viz for satisfying my obsession. It was more than worth the wait. Black on black 2SS/RS M6
srevoal is offline   Reply With Quote
Old 11-02-2009, 02:32 PM   #2
Camar0wn3d
formerly "wh0rsep0wer"
Camar0wn3d's Avatar
Drives: 2016 1SS Summit White
You're trying to install it in the wrong place...it's a 2-pin connector....lemme see if i can find you a picture.
2010 1SS/RS - CGM/Gray Interior - M6 (SOLD) Kooks 1 7/8" headers, Solo Mach-X, Vararam.
2012 2LS - Black A6 (SOLD)
2016 1SS Summit White A8
Camar0wn3d is offline   Reply With Quote
Old 11-02-2009, 07:16 PM   #3
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
it sounds like hes trying to plug it into the 02 sensors
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 11-02-2009, 09:30 PM   #4
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Hope these help. They helped me
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 11-02-2009, 09:37 PM   #5
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
and if you have trouble putting it in reverse afterwards, put it in the other 2-pin connector
Old 11-03-2009, 01:14 PM   #6
srevoal
srevoal's Avatar
Much more helpful than the manufacturer. Thanks for the help guys.
9/2/09 2000!
Old 11-15-2009, 06:24 PM   #7
srevoal
srevoal's Avatar
finally got around to installing the skip shift eliminator. Those pics were very helpful. No more unwanted 1-4
9/2/09 2000!
Old 11-16-2009, 12:00 PM   #8
Trailbreaker77
Trailbreaker77's Avatar
Drives: 2010 Transformers Edition
These pictures were a big help.
Thanks
Trailbreaker77 is offline   Reply With Quote
Old 11-16-2009, 12:46 PM   #9
IROCanSS
Drives: 89 IROC 350
I agree, these pics were a life saver. I happened upon this thread right before I installed my hurst and sse jumper. I would have for sure plugged it into the reverse selonoid because it is so obvious as to where the CAGS is tucked up on top.
Thanks!!
Old 11-16-2009, 01:13 PM   #10
3GPa
3GPa's Avatar
Drives: SOLD/2SS/RS Painted Rally Stripes
Yeah, I remember putting mine in and I was going to take pictures, but I forgot. I was sure happy when I put it back on the ground and it worked.
3GPa is offline   Reply With Quote
Old 11-16-2009, 02:20 PM   #11
Michael_Js
Michael_Js's Avatar
Great job! I don't even think to look at the DIC any longer to see the skip message
Old 11-28-2009, 07:48 AM   #12
Commissar
Drives: 2006 Pontiac GTO
Just out of curiousity, is this the same as on the GTO? If so will the 2.2k ohm resistor mod work? My dad is looking at getting a new camaro to compete with my goat, and don't see spending $30 on something that can be fixed for $0.99 from radio shack.
Commissar is offline   Reply With Quote
Old 11-28-2009, 08:16 AM   #13
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
http://jalopnik.com/5252686/how-to-d...or-seven-bucks
a 2.2K ohm 0.5 watt resistor from Radio Shack which costs about $1
Old 11-28-2009, 04:06 PM   #14
Commissar
Originally Posted by slick rick View Post
A 2.2k ohm resistor and some electrical tape worked for me for a couple years. Never drive in the rain or snow. Then had it tuned out via HP Tuners. Good to know they kept the same concept. Good easy to negotiate way around the gas guzzler tax!
Camaro Skip Shift Eliminator.... southerncarparts V8 Bolt-Ons & Tunes 12 01-14-2018 09:46 AM
Speed inc. skip shift harness installed Ringo V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 09-21-2009 03:21 PM
Skip shift function, or malfunction? AMERICANMADE 5th Gen Camaro SS LS LT General Discussions 53 09-18-2009 09:38 PM
SLP Skip Shift Eliminators Available @ MarylandSpeed! MarylandSpeed V8 Bolt-Ons & Tunes 0 09-18-2009 02:50 AM
Avoid skip shift in the break-in? Vash Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 7 05-27-2009 11:39 AM
