SDTW Custom Wheels & Tires
Old 11-02-2009, 02:15 PM   #1
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
Need a clutch...
Any one have any suggestions? I've tried getting ahold of ECS about the fidanza stuff but they haven't answered their phones or pm's all day. So any other options out there for us people.
85 Buick TType - 5.3l GT4202r 10.86 at 126
boostedyards86 is offline   Reply With Quote
Old 11-02-2009, 04:37 PM   #2
DarricSS
DarricSS's Avatar
Drives: '10 Camaro SS
Here is the Lingenfelter.
http://www.lingenfelter.com/mm5/merc...egory_Code=C62
And might have more luck ordering through Summit for the Fidanza.
http://www.summitracing.com/parts/FI...ry=Liter%7c6.2
2010, SIM, 2SS/RS, LS3, CGM Stripes
DarricSS is offline   Reply With Quote
Old 11-02-2009, 04:41 PM   #3
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
Map Performance best price out there $1179.99 deliveried. 7.6 ceramic with alum fly
lawdogg149 is offline   Reply With Quote
Old 11-02-2009, 04:50 PM   #4
Kris@BMCPerformance
Kris@BMCPerformance's Avatar
Drives: 2006 Charger SRT8-Supercharged
Send a message via AIM to Kris@BMCPerformance Send a message via Skype™ to Kris@BMCPerformance
Give us a call we have a few options! RAM would be my first choice but we also carry Fidanza, Centerforce and others. Check out our Selection HERE or give us a call 877-BMC-RWHP!
BMC Performance-Forced Induction Specialists
www.BMCPerformance.com
877-BMC-RWHP
Vortech, Techco, Procharger, STS Turbo, Magnacharger Dealer/Installer!
Kris@BMCPerformance is offline   Reply With Quote
Old 11-02-2009, 06:21 PM   #5
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
Originally Posted by DarricSS View Post
Does the lingelfelter kit includes the flywheel?
Lingenfelter is now offering our new ZR1 twin disc clutch assembly & flywheel that gives you exceptional holding power without sacrificing smooth operation and comfortable pedal operation. This system does not exhibit any rattle at idle or chatter during engagement and has been tested at over 700 horsepower.
Included in this system:
- Lingenfelter 6 bolt flange flywheel, OEM spec steel design made in the USA
- GM ZR1 twin disc pressure plate assembly, clutch discs & bolts
- GM ZR1 clutch slave cylinder or actuator assembly
For 2010 Camaro applications you will need the Lingenfelter slave/actuator spacer part number L360031410
The Lingenfelter steel flywheel is also sold separately part number L360010105.
JM10 is offline   Reply With Quote
Old 11-02-2009, 07:15 PM   #6
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
i went with the lpe zr1 clutch because it come s with a steel flywheel and the clutch itself is a gm part that can be picked up from any dealer
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 11-02-2009, 09:07 PM   #7
DarricSS
DarricSS's Avatar
The only additional part you need is the Clutch Slave Actuator...it's listed at the bottom of the page on the first link:
"For 2010 Camaro applications you will need the Lingenfelter slave/actuator spacer part number L360031410"
Old 11-03-2009, 12:47 AM   #8
JM10
Se habla espaņol
JM10's Avatar
Can someone post the GM part number for the ZR1 clutch kit?
Thanks
JM
Old 11-03-2009, 10:14 AM   #9
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
PM sent....
Fidanza is the best out there right now.... I will be using their system on my build this winter. I would not sell it if I did not trust it.
ZZcamaro is offline   Reply With Quote
Old 11-03-2009, 10:24 AM   #10
kelleyperformance
kelleyperformance's Avatar
Drives: DD- 15' Chevy SS Sedan
ZR1 FTW!! the clutch pedal feel and driveability of the ZR1 is FAR FAR FAR superior to the OEM camaro, corvette, and z06- as well as LESS pedal effort
kelleyperformance is offline   Reply With Quote
Old 11-03-2009, 11:13 AM   #11
SupremacyCustoms
SupremacyCustoms's Avatar
Drives: black 2010 2ss/rs camaro
SPEC is good to whats your price range.
SupremacyCustoms is offline   Reply With Quote
Old 11-12-2009, 10:51 PM   #12
JM10
Se habla espaņol
JM10's Avatar
Thanks
JM
Anyone?
Old 11-13-2009, 09:20 AM   #13
BLKLIST
Boosted
Drives: Trailblazer SS, SRT-10
Katech's ZR1 twin disc with conversion aluminum flywheel is a good one:
http://store.katechengines.com/share...unt2=778388619
Fidanza's twin discs have proven very well:
http://www.lethalperformance.com/tra...7693_7694_7707
BLKLIST is offline   Reply With Quote
Old 11-13-2009, 04:44 PM   #14
oachalon
Drives: 2010 Camaro 1SS
I figure the day i go supercharged i will need a new clutch, but i love the pedal feel on the camaro. Does the zr1 clutch cause pedal feel to change, or is it pretty close?
oachalon is offline   Reply With Quote
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Coming Soon! RAM Twin Disc Clutch and Flywheel! Taking Pre-Order List @BMC Peformance Kris@BMCPerformance V8 Bolt-Ons & Tunes 7 02-18-2010 08:00 PM
Clutch "Sticking" Issue - Not Clutch Dust - Not Boiling Fluid Embalmer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 09-11-2009 10:52 AM
Vengeance Racing Introduces RPS Organic Street Twin Clutch for 2010 Camaro!!! Ron@Vengeance V8 Bolt-Ons & Tunes 2 08-05-2009 02:03 PM
Burned my clutch a bit with Launch Control.... Caution you guys... Embalmer 5th Gen Camaro SS LS LT General Discussions 49 04-23-2009 09:49 PM
