Rick@Livernois
Old 11-02-2009, 01:34 PM   #1
55Designs
Drives: 2010
I want to do whatever I can to tighten up my steering feedback. Suggestions?
I already did my suspension 3 times just to try out different products on my roads. I am very happy right now with the suspension I just need to have it aligned up better.
What I dont like is the SS steering when going fast is very twitchy and loose and I really hate that. I want a heavy more weighted feel because its so sensitive now its all over the road at very high speeds.
I am going to put the larger 275/40 tires up front soon but there has to be something else I can do via the steering rack assembly.
Any ideas?
55Designs is offline   Reply With Quote
Old 11-02-2009, 04:54 PM   #2
camaro692
Drives: 2010 Camaro SS, G8 GT, HD FLHRX
When you said did your suspension what do you mean? I did DSE sway bars and they really tightened up the car!
[SIGPIC][/SIGP
camaro692 is offline   Reply With Quote
Old 11-02-2009, 05:27 PM   #3
55Designs
Drives: 2010
I did bars, springs bushings and shocks. I tried Coilovers etc already. Car is very tight in terms of body roll and its perfect. love the ride and side to side stiffness and look.
Steering is just not tight enough for me. On my Germany sports cars as you push hard through a turn the steering gets tighter keeping you in great control.
On the SS one twitch and the car is in the next lane. It feels over assisted or the ratio is too quick. I am not planning to autocross this car I just want tighter steering.
On some cars steering racks there is a nut that you turn which pushes a rod to adjust the feedback. I need to get under the car to see if this rack has that adjustment or not. I hope it does.
I am open to replacing the steering rack itself I just dont know who to call to send mine for modification.
Old 11-02-2009, 06:55 PM   #4
2010_5thgen
2010_5thgen's Avatar
Drives: 2012 Porsche Panamera 4
sway bars will help alot.
http://www.gofundme.com/n7ne44
2010_5thgen is offline   Reply With Quote
Old 11-02-2009, 07:10 PM   #5
BLACK10
BLACK10's Avatar
more negitive camber, but that will give you faster tire wear.
Old 11-02-2009, 07:28 PM   #6
55Designs
Drives: 2010
I got bars stiffest in rear and I will try the stiffest setting up front tomorow if I get time.
I am running -1.3 camber front and -.9 rear I dont know what my toe or caster is and we are going to take some negative camer out this weekend its excessive as it sits now.
I wonder how much the 275 tires will help up front when my new wheels arrive.
Oh I was under the car, on the drivers side (top side of rack) it looks like there is a rack adjustment nut. I need to take a closer look and may give it a tiny turn of adjustment.
Old 11-02-2009, 07:35 PM   #7
antivenom
antivenom's Avatar
Drives: Too many to list
march performance #P306
Regulator Kit Allows you to regulate pressure for power rack and pinion or gear box requirements.
right off of march performance website. you can use this to adjust the assist pressure where you want it. I have used these and they work very well.
antivenom is offline   Reply With Quote
Old 11-02-2009, 09:09 PM   #8
tyler20c
tyler20c's Avatar
Drives: Black 2010 Camaro SS/RS
Those wide tires up front will make a huge difference. I put wider tires on my mustang and it handled like a completely different car.
tyler20c is offline   Reply With Quote
Old 11-02-2009, 09:37 PM   #9
55Designs
Drives: 2010
Thanks for the heads up. Have you installed on on the Camaro yet? Going to look this up now.
Old 11-02-2009, 10:01 PM   #10
Rob@WretchedMS
Drives: His Wife Crazy
You need to add caster, and get a performance alignment.
You will likely need to have one of our bolt kits installed, and have the caster holes modified for use with our adjusters.
Everything else is a bandaid, not a fix.
PDUSA5420 Zeta Rear Camber & Toe Kit
PDUSACAMFNT Camaro Front Alignment Kit
PDUSACAMFULL Camaro Full Alignment Kit
Rob@WretchedMS is offline   Reply With Quote
How Many Camaro5 members does it take to change tighten spoiler nuts ffrcobra_65 5th Gen Camaro SS LS LT General Discussions 59 02-17-2010 06:31 AM
Bump steer, vague steering on center... Anyone else noticed?? JDBeck23 Wheels and Tires Talk Sponsored by The Tire Rack 17 09-25-2009 05:03 PM
steering is tight crowe98 4th Generation Camaros 5 09-17-2009 08:24 PM
Steering wheel leather cracking!! meliss7567 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-17-2009 02:13 PM
Power Steering - hydraulic or electronic steering? balonywolf 5th Gen Camaro SS LS LT General Discussions 20 02-28-2008 11:01 PM
