Cold Air Inductions
Old 11-02-2009, 07:11 PM   #1
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Second Blackstone Labs Oil Analysis.
I just recieved my second oil change analysis from Blackstone labs.
History on the engine..
From the dealer, I broke the motor in hard...real hard. I did not follow any of the GM mandated "break in" procedures.
Changed first at 890 miles, then again at 3984. The oil still had high levels of copper and silicon. I have the file on pdf. format if someone knows how to post it. Yes, they are higher than "average" yet not uncommon for a newly assembled engine.
Here is an excerpt from the analysis..
TOM: High copper and silicon are both common finds in new engines such as yours. The copper is from brass or bronze parts, while silicon is from sealers and sand-casted parts. Both should settle down nicely next time, and silicon should read at or below averages next time, but copper may take a while longer. Universal averages show normal wear levels from the GM LS-3 engine after about 3,500 miles use on the oil. No fuel or anti-freeze was present and all wear other than copper looks great. We see no reason this
won't be a nice engine for you at 3,984 total miles.
Copper was 188, average 56
Silicon was 28, average was 24
So as you can see, this was the end of the second oil change. All other wear items were within normal parameters. So with that, The first oil change analysis was 18 aluminum, average 5, Copper 290 average 56, silicon 57 average 24. I would recommend an oil change before, at or around 500-1000 miles and again at 2500-3000.
So for those of you who are on the fence about oil changes...here is the proof. The analysis does not mean those high numbers would cause harm or issues, but silicon can be an issue if not changed out. Silicon content in oil is similar to running a car without an air filter on a dirt road. Copper I am not so worried about.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 11-02-2009, 08:29 PM   #2
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
Banshee I don't know you my friend but you have too much time on your hands!
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 11-02-2009, 09:41 PM   #3
Banshee
Banshee's Avatar
Yes I do...and my LS engines have over 550k with no issues or engine failures.
And I change out oil at 1000k, 3000k and after that, 8000-9000 miles on synthetic, sometimes longer depending on what Blackstone Labs reports back.
Old 11-02-2009, 09:44 PM   #4
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
cool.
hot ss is offline   Reply With Quote
Old 11-07-2009, 11:30 PM   #5
GQ4Life
Drives: 2010 Camaro SS LS3
i want to do this for my car..'
ordered two kits.. i'll show report for selling my car.. thanxs
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 08:51 AM
Blackstone Labs OIL report at 1270 miles... 350 HRSS Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 49 12-02-2009 12:38 AM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 12:28 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 12:20 PM
