Jason 98 TA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - New England
Old 11-03-2009, 07:46 PM   #1
Slowhawk
Drives: 1999 Trans Am
Fall specials for New England members
Got alot of requests recently so I put together some packages.
Cam special is back-
Cam of choice
Patriot Extreme Valve springs
Custom Length hardened pushrods
New timing chain
New Gaskets/fluids as needed
Professionally installed/tuned =$1854.12 . This includes all Ma state taxes,no surprises.
Options-free labor when doing Cam
Powerbond 25% pulley with Gates belts -$260
Ported/blueprinted,new GM oil pump -$130
160 T-stat -$55 F-body,97-03 Vette -$35 04+ cars
Now added-
Header special - Buy any Kooks or American Racing header through us and the install/ full tune is as follows -Saves atleast $400 minimum.
F-body -$500
97-04 Vette's -$600
05-09 Vette- $500
2010 Camaro -$500
GTO -$600
TBSS- $700
Most other trucks -$500
Slowhawk is offline   Reply With Quote
Old 11-04-2009, 05:42 PM   #2
Slowhawk
Thanks for the e-mails guy's. A common question has been the L99 Cam setup's. As I explained to a few is that we shy away from them due to the failures we've seen with lifters.The AFM/VVT setup requires a very week lifter so when a stronger spring is installed it increases the pressure on the lifter which can cause it to fail.Due to this we just don't feel safedoing them in these cars because we warrenty our work and don't like seeing an unhappy customer.
What we can do is get the cars power out to a 6 speed level.We put in new LS7 lifters with the correct holders,while the heads are off they get milled to raise compression,change the oil pump(known to fail on L99's)get rid of all the wiring ect for AFM and pretty much get the engine to LS3 status.
The L99's dyno around 320-330rwhp on our dyno.Getting it to 400-440rwhp is not a problem with changing everything over.
Old 11-04-2009, 07:04 PM   #3
tones2SS
tones2SS's Avatar
Thumbs up
Cam of choice
New timing chain
Now added-
F-body -$500
97-04 Vette's -$600
05-09 Vette- $500
2010 Camaro -$500
GTO -$600
TBSS- $700
WOW, those are great prices guys!!
Slowhawk, you should post this in the general thread as well, if possible!!
Camaro & Firebird Fall Cruise this Sunday October 25, 2009 in Southeast Michigan SlpDave USA - Great Lakes 1 10-25-2009 01:18 AM
