| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
Dances With Mustangs
V6 vs V8 Brakes
Other than the fact they are Brembos, what's the differences between the V8 brakes and the V6? Did several searches but can't find anything on the forum that compares them.
Blue Angel is here!! ![]() 1SS/RS LS3 M6 IBM |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: the 2nd amendment home Join Date: May 2008
From the wiki...
2010 LS/LT OEM Brakes: * ABS * ventilated front and rear rotors * single piston front calipers / single piston alloy rear calipers * Rotor diameter (front) (in / mm): 12.64 / 321 * Rotor diameter (rear) (in / mm): 12.4 / 315 * Rotor thickness (front) (in / mm): 1.18 / 30 * Rotor thickness (rear) (in / mm): 0.9 / 23 2010 SS OEM Brakes: * ABS * ventilated front and rear rotors * four piston fixed Brembo aluminum front and rear calipers * Rotor diameter (front) (in / mm): 14 / 355 * Rotor diameter (rear) (in / mm): 14.4 / 365 / 315 * Rotor thickness (front) (in / mm): 1.26 / 32 * Rotor thickness (rear) (in / mm): 1.1 / 28
-- Benjamin Franklin Great Racing Quotes "Never run out of real estate, traction and ideas at the same time." "I was doing fine until about mid-corner when I ran out of talent." "Don't brake until you see God, just don't meet him" |
Thanks!
You're very welcome
| Thread Tools | |
| Help me make a decision about a camaro v6 or v8 | thejoker1232 | General Automotive + Other Cars Discussion | 15 | 07-30-2010 12:38 PM |
| V6 vs V8 shifter? | Cmlloveless | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 7 | 03-07-2010 10:44 AM |
| should i get a v6 or a v8 | thejoker1232 | General Automotive + Other Cars Discussion | 7 | 10-02-2009 09:20 AM |
| Gas Mileage question: V6 vs V8 | MyCamaro5 | 5th Gen Camaro SS LS LT General Discussions | 1 | 09-10-2009 01:56 PM |
| V8 appearance vs. V6 Discussion! | jpsuperman81 | 5th Gen Camaro SS LS LT General Discussions | 19 | 08-08-2009 09:01 AM |
