BORLA
Old 11-04-2009, 11:36 PM   #1
trenchdog73
trenchdog73's Avatar
Drives: 2010 2ss/rs Cyber grey camaro
Pulling to the right
Well I recently had a a flat on the rear passenger side tire. I ordered and Identical replacement from the dealer and took the rim in to the dealer to have it put on. I put the rim back on and have now noticing the car pulling to the right. The new tire was filled with air while the other three are nitro. The car had a slow leek and went flat in the garage so it didn't take any damage in getting the flat. I just wanted to know if anyone had any thoughts on why the car would seem to be out of alignment now.
trenchdog73 is offline   Reply With Quote
Old 11-04-2009, 11:39 PM   #2
coolman
Guest
how many miles are on the existing tires?
coolman is offline   Reply With Quote
Old 11-04-2009, 11:46 PM   #3
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Are you sure the pressures are correct on all 4?
Pulling to one side is indicative of low pressure if no other parameters have changed.
Unless they gave you a lower profile tire on the rear by mistake.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 11-05-2009, 09:08 AM   #4
trenchdog73
According to the on board the pressure should be ok all are abit low with the cold weather I think ill stop into the dealer and have him drain and fill the new one and fill the other three with nitro sense they do it for free. Ill also check out the measurements of the tire again all though im fairly certain it is the correct size.
Old 11-05-2009, 12:24 PM   #5
DangerZL1
Drives: Future ZL1 Owner
How many miles are on the original tires?
DangerZL1 is offline   Reply With Quote
Old 11-05-2009, 01:24 PM   #6
trenchdog73
2500
Old 11-05-2009, 01:27 PM   #7
coolman
Guest
Does it do it on every kind of road. I know both of ours seems like they pull when the road has a slight crown.
Old 11-05-2009, 02:32 PM   #8
drtwo
drtwo's Avatar
Drives: 2SS RS Yellow, Raptor, Vrod
disengage the traction control and stabilitrak, sometimes that seems to pull one way or the other and by shutting it off I have eliminated it.
2SS RS Rally Yellow, LS3, M6, sunroof, extra on the fast!
drtwo is offline   Reply With Quote
Old 11-05-2009, 02:53 PM   #9
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
I've noticed my car pulling to the right as well if the rear tire grabs the crown of the road.
Old 11-05-2009, 04:30 PM   #10
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
If you had said your car pulled to the left I would have mentioned a driver weight issue.
Seriously people check your tire pressure the old fashioned way to verify the computer.
tradosaurus is offline   Reply With Quote
Old 11-05-2009, 04:57 PM   #11
trenchdog73
I just picked up a digital pressure gage and checked all the tires, they are all low but even front are 31 psi the rear are 31.5, im going to stop by the dealer tomorrow and have them fill them back up sense they refill the nitro for free and im heading that way anyway. I dont think this would be the problem sense they still have even tire pressure correct?
Old 11-05-2009, 05:42 PM   #12
Banshee
Banshee's Avatar
It pulls to the right...the right wheel in the rear went flat. Have you driven the car on concrete freeway to nullify the crowning on heavily traveled asphalt which would pull car?
Also on freeways, left lane, car will drift to left, right lane to right.
Did you have a left to right 30 mph wind that day? Did you hit a pothole or curb?
The car is new. I automatically rule out calipers sticking. Either you think it pulls, or it pulls. WHat happens when you set the cruise to 70 and remove hands from wheel?
Old 11-05-2009, 08:44 PM   #13
bono83
bono83's Avatar
Drives: 1969 Chevelle, 2010 1LT
I would suspect that the fact that the replacement is filled with air and the others have nitrogen has something to do with it. If I'm not mistaken, the pressures will fluctuate differently as the tires warm up and cool down. Also, is the tire by any chance one directional and installed backwards?
Order: 5/23/09 - Deposit given with order at dealer.
1100: 6/26/09 - Order placed by dealer - no allocation
2000: 8/15/09 - Accepted by GM.
2500: 8/18/09 - Preferenced.
3000: 8/18/09 - Accepted by Production Control.
3100: 9/9/09 - Available to Sequence.
3300: 9/9/09 - Scheduled for Production.
3400: 9/19/09 - Broadcast.
3800: 9/29/09 - Produced.
4000: 9/29/09 - Available to Ship.
4150: 9/29/09 - Original Invoice.
4200: 10/6/09 - Shipped.
5000: 10/13/09 - Delivered to Dealer.
6000: 10/13/09 - Delivered to Customer.
bono83 is offline   Reply With Quote
SPEC Clutch/Flywheel Upgrades | Single & Twin Disc!! AJ@ECSMotorsports Transmission / Driveline 21 11-13-2010 04:58 PM
fuse pulling ?? 71cam Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 10-23-2009 09:11 PM
GFX pulling away in rear gmenfan75 Cosmetics and Lighting Modification Discussions 2 09-05-2009 01:31 AM
Pulling my hair out! RS Wheels bincamaro Wheels and Tires Talk Sponsored by The Tire Rack 14 09-03-2009 09:17 PM
Video of Red Camaro SS pulling out with exhaust note rray200 Camaro Photos | Spyshots | Video | Media Gallery 19 01-07-2009 12:46 AM
