| 4th Generation Camaros 1993-2002 |
Thread Tools |
![]() Drives: 1995 3.8L Camaro Join Date: Mar 2008
4th Gen Audio Question (Bose)
I have been told that when replacing the factory Bose unit that just about everything needs to be replaced (Wires, head unit, speakers). How true is this and is there a head unit that can just go in and replace the factory Bose unit?
At Crutchfield when I look up head units for the Camaro, this is listed in the installation section. Your vehicle is equipped with an upgraded sound system. We recommend that you purchase an adapter to eliminate extensive rewiring when you install your new stereo. Without this adapter, you might have to replace your entire factory sound system, including the speakers.
Hey, you want to lay the fate of the world on the kid's Camaro? That's cool. I bought a car, turned out to be an alien robot. Who knew? |
AutoBot Scout
I think thats just a marketing ploy to get you to buy more stuff. i swapped out the factory speakers and head unit with an alpine setup and it sounds awsome. ask IrocZlover she heard it at the Titus Will show.
I know with the later Monsoon systems you can't just replace things at random. The speakers run at a different ohm than normal speakers, if you don't put in the right thing you can blow things out or it will sound like crap. You can use the stock wiring and rig something up to bypass the amp (since the amp is what determines the ohms. The head unit can be replaced easy, but you will lose SCV and steering wheel controls unless you get an adapter.
Of course, thats for Monsoon, could be completely different for Bose.
Iroc's Love Slave
Drives: 3 Camaros, 1 Vette, a Buick, & a 57 Join Date: Jul 2008
I know on my 95, which had the Bose setup, we changed out the head unit and speakers.
You can get an adapter to be able to easily plug the new head unit into the stock harness, so that isn't a problem. As for the speakers, you will be MUCH happier if you replace the original Bose speakers will quality aftermarket speakers. Some good 2 or 3 way speakers will sound a lot better. The other thing to watch out for is the sub in the back. If you have one then plugging it into an aftermarket head unit will make it pop very loudly each time you turn the stereo on. It has to do with how it is set up and wired. I replaced my with a Formed sub. |
Iroc's Love Slave
Oh, and Bumblebee, your system did sound good.
#6 |
Petro-sexual
Drives: Ultra-Grin Join Date: Oct 2006
I heard the same thing about the BOSE system on the LT1 cars. I had one in mine and was looking to add speakers in the areas there were none, but and audio guy told me the ohms were a PITA to deal with because they were like 6ohm speakers, or some 'ish, and that the head unit wouldn't play well with aftermarket speakers. I just left it alone because I didn't want to get speakers with too low ohm ratings and cook the head unit.
I don't really have much of a problem with my Monsoon in my LS1 car, but I do like the way my brother added a powered sub and box with and he just turned the bass off at the head unit, cranked up the upper end and used the sub for all the bass. It balanced out pretty good for OEM speakers, although some two or three-ways would definately have improved.
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
#7 |
www.Camaro5store.com
Check the other audio threads about the adapter also sold by Crutchfield. I think Alpine made one, JL makes one, Kicker, and a few others.
But why would you want to go and get rid of a BOSE unit??!!?? |
#8 |
Well obviously this may not happen due to problems addressed in another thread, but the reason I was looking to replace the head unit is that my CD player doesn't work that well when it gets too hot or too cold. It basically has a specific temperature that it likes. Problem is here in Idaho in the summer it is over 100 and in the winter it is below freezing so there are plenty of times that the CD player doesn't want to work. Tried a CD cleaner but it hasn't helped at all.
| Thread Tools | |
| Post up your 4th Gen. Camaro | 09'Z28 | 4th Generation Camaros | 1253 | 06-11-2013 02:38 AM |
| 4th Gen Miles Question | dobbins67326 | 4th Generation Camaros | 13 | 09-05-2008 10:37 AM |
| Condensation in late 4th gen headlights? | MAC | 4th Generation Camaros | 27 | 06-30-2008 01:53 PM |
| New 5th Gen Question... | marczsport | 5th Gen Camaro SS LS LT General Discussions | 26 | 06-15-2008 02:01 AM |
| Anybody with an Auto 4th gen? | Mr. Wyndham | Off-topic Discussions | 14 | 09-16-2007 12:46 PM |
