Flowmaster Exhaust
Old 11-07-2009, 05:39 PM   #1
StangKiller-SS
Drives: GM products
Track times/0-60 times w/ V6?
Just curious what kind 1/4 mile times and or 0-60 times some of you guys have been getting out of the V6 Camaro and with what mods added? Just wondering because while I think the 14:1 compression ratio will hold the V6 down performance wise, but I think the 300hp + some bolt-on's and stuff. I'm kind of curious as to what the V6 may be capable of. I'm not looking for V6 vs. V8 or anything like that I just want to see some real track numbers for the V6 or modded V6's.
StangKiller-SS is offline   Reply With Quote
Old 11-07-2009, 05:44 PM   #2
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
There is a thread on this already. Search is your friend.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 11-07-2009, 05:46 PM   #3
1320junkie
Drives: The Imperial Army
If you browse some in the drag racing section you will see a few times...One member I know has run a 13.76 in the 1/4 and i've seen it done faster
Old 11-07-2009, 06:01 PM   #4
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
With the V6? Fastest I could find is 14.3 and that was member scrming. I mean
there is little to no one going down the track in the V6 and no one with a stick doing it. At least not on this forum.
Old 11-07-2009, 06:13 PM   #5
1320junkie
look in the drag racing section..but the quickest ive seen in person is 13.59
Old 11-07-2009, 06:29 PM   #6
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Wow... A V6? What was the DA? I'm running 14.3 with the DA in 1400 to 1600 range IIRC... Ran 14.3 again today... haven't calc. the DA yet... Need to buy a weather station!
scrming is offline   Reply With Quote
Old 11-07-2009, 07:24 PM   #7
dagolfguy
dagolfguy's Avatar
Drives: 2010 Camaro 2LT RS
Scrming,
Did do you still have the V2 exhaust on the car? If so, it looks like the performance is not markedly different between the more aggressive system and the more subdued version?
dagolfguy is offline   Reply With Quote
Old 11-07-2009, 07:36 PM   #8
scrming
scrming's Avatar
Originally Posted by dagolfguy View Post
Scrming,
I'm actually putting together every thing from today together to update the 2.0 thread...
But yes, there appears to be no difference between 1.0 and 2.0 when it comes to performance...
Old 11-07-2009, 07:53 PM   #9
StangKiller-SS
Drives: GM products
Thanks for the reply's so far guys! I've just been very curious about the 1/4 mile times bc my Firebird while being lighter & being a V8 is good for low 13's w/ 300hp. It just makes me wonder what 300hp V6 may be capable of with some bolt on performance mods as it's the most potent & technologically advanced V6 GM has produced.
Old 11-07-2009, 07:57 PM   #10
scrming
scrming's Avatar
I believe the car's torque management system is holding my car back a bit... During a shift the timing goes from mid-20s to -8 degrees... I'm pulling a 2.0 60' and trapping at 97 MPH yet my ETs are 14.3 to 14.5... With that 60' time and trap speed I should be closer to the 13s...
Also remember.. while the V6 is rated at 304HP, the torque is only rated at like 273 ft/lbs... and my 2LT RS tipped the scales at 3840 WITHOUT the driver...
Old 11-07-2009, 11:52 PM   #11
kga10734
Don't Feed the Troll
kga10734's Avatar
Drives: 2010 Camaro 2LT/RS & 1999 Corvette
Not trying to sound mean or nasty about it but, why would you even care? It says in your signature you have a SS on order.
kga10734 is offline   Reply With Quote
Old 11-08-2009, 07:30 AM   #12
scrming
scrming's Avatar
Sounds like just plain curiosity... I think some of it may be all the talk about the 300HP has a lot of people curious on how that translates to 1/4 mile times...
Old 11-08-2009, 08:26 AM   #13
StangKiller-SS
Drives: GM products
I'm curious bc with 300hp stock and 14.2 stock times I wonder what possibly some bolt ons could do to improve those times and possibly get into the 13's and low 5's 0-60. Someone on here once said that a Camaro is a Camaro whether it's got a V6 or a V8. We all already know that the V8 is limitless with performance and while the V6 may not be I still think the V6 probably has the capability to put down some decent numbers. I'm just one that likes to learn as much as I can about both the V8's & V6 of the 5th gen Camaro.
Old 11-08-2009, 08:38 AM   #14
scrming
scrming's Avatar
That's pretty much what I figured you were after!
I would say simple bolt-ons aren't show huge gains... a few HP here and there... BBK teased at a BIG GAIN with long tubes... but that also meant going to aftermarket high-flow cats... which is not an option for everyone...
I think we'll see some benefit when a tuner comes out for the LLT... I think reducing the effects of the torque management system will help quite a bit..
Right now my best times with an axle back and separate IAT sensor is 14.32. Looking at the DA and if I correct to sea level it put it at 14.03... Since the track elevation is 895 feet here, it's going to take some really good weather for me to get a 14.0... LOL!
I will add headers over the winter... tune hopefully before spring... so I'm hoping for 13's when the tracks open!
Although the track here is open to November 30th... so BBK if you want to send me some prototype Long Tubes to try out at the track, let me know! LOL!
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 380 11-06-2017 05:38 PM
V6 Camaro Owners! 2010 V6 Zex Nitrous System now available! Kris@BMCPerformance Forced Induction 3 01-23-2010 03:41 PM
SLP releases V6 Exhaust Systems...Order Now!! ZZcamaro V6 Bolt-Ons & Tunes 13 08-27-2009 11:51 AM
Car and Driver Drives the ZR-1 at GM's MCR test track drummerstevey General Automotive + Other Cars Discussion 13 09-02-2008 07:22 PM
What should I expect at the track tonight.... Bowtie Guy Z28 4th Generation Camaros 5 05-28-2008 04:20 PM
